Vidiot Challenge!! 4:3 on 16:9 (w/ Sanyo 21N) - AVS Forum | Home Theater Discussions And Reviews
Old 04-18-2001, 05:33 AM - Thread Starter
wvrich's Avatar
I am considering the 21N but I have been kicking around the issue of displaying 4:3 images on a 16:9 screen.
Does the following make sense:
It would seem that if an XP21n was mounted at max zoom in a 16:9 set-up you should be able to just use the minimum zoom to show 4:3 images on the same screen without overshoot. Sanyo specs say the zoom ratio 1.3 to 1. If you have a 96" x 54" screen, a standard 4:3 image would want to be around 70" tall. If you take 70" and reduce it by 1.3 you would be at just under 54". This may be an ideal solution due to the fact that you will use the full rez no blanking etc. Whaddya think???
Through man's sweat and God's love, beer came into the world...
- Saint Arnoldus
wvrich is offline
Old 04-18-2001, 05:54 AM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
The other problem with this idea is that when zooming in or out most projectors have an offset which if the projector is mounted on the ceiling you don't have to place the lens in the center of where the screen is mounted, the lens can be at the top of the screen and still be centered top to bottom but, when you start using the the zoom I think you will always have to ajust the picture up or down. I'd wait for the 16x9 Sanyo.
Tom Bley is online now
Old 04-18-2001, 06:21 AM
Gary Lightfoot's Avatar
Quoted: 591 Post(s)
Liked: 345
As Tom said, if you zoom in or out, the image will move up or down in relation to the screen.
If you're using a htpc, then use YXY to position the image in the middle of the screen. It's a really usefull program. http://www.avsforum.com/ubb/smile.gif
Gary.
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
Old 04-18-2001, 07:22 AM - Thread Starter
wvrich's Avatar
I cannot see how you would get an image shift. I would think the image would shrink or grow proportionally on all sides. It is just a lens thing.
- Saint Arnoldus
wvrich is offline
Old 04-18-2001, 07:49 AM
Berway's Avatar
I tried to switch an XP21 between 16:9 and 4:3 on a 16:9 screen this morning. In 16:9 mode, the image is cropped on the top "and" bottom. So when you switch to 4:3, the image refills the equal size gaps on the top and bottom. At this point when you zoom all the way in, the top portion of the 4:3 image will fit within the 16:9 borders, but the bottom portion will stay several inches outside the screen border. Hope this helps.
Mike
Berway is offline
Old 04-18-2001, 08:23 AM - Thread Starter
wvrich's Avatar
Thanks for all the help. I guess that was just a remedy that was too easy... So of course it would not work!
- Saint Arnoldus
wvrich is offline
Old 04-18-2001, 03:56 PM
David Mendicino's Avatar
I to wouldn't...unless, the 16x9 immage was at the location of the zoom offset.
Like that which was mentioned, on my Sharpvision, when I zoom the image, the top stays in the same place. The bottom and sides move. However, I have lens shift.
However, would this not put a greater burden on the motor and gears. I don't think it was meant to be zoomed in and out all the time?
David Mendicino
Sharp xv-s55u (Don't laugh) :)
David Mendicino is offline
