Dual projector - hookup tips? - AVS | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Seegs108
post #1 of 16 Old 05-26-2015, 02:36 PM - Thread Starter
stanger89's Avatar
Quoted: 592 Post(s)
Liked: 309
So, I'll be joining the multi-PJ group soon, I've seen lots of recommendations here to use multiple projectors to take advantage the best attributes of both.
Question is, how do you hook that up? HDMI splitter? Any HDCP issues?
Some background, I've got a Darbee, Lumagen Radiance XE 3D, Anthem AVM 50V 3D, Planar 8150, and soon to have RS4910. I've got all my sources connected to the Radiance which feeds my Planar through the Darbee. The other HDMI out of the Lumagen feeds my Anthem with audio.
I tried hooking up two projectors recently (that's another story), to do so I hooked the second projector to my Anthem, and passed video through that too. Now that worked well, or so I thought. I ran into trouble when I tried to play Blu-ray and then I ended up having what I can only assume is an HDCP issue.
I guess my question is, did I do something wrong, should I expect that to work. Would an HDMI splitter work better, or work at all? Can you feed one signal from a BD player to multiple displays or does HDCP prevent that?
See what an anamorphoscopic lens can do, see movies the way they were meant to be seen
stanger89 is online now
post #2 of 16 Old 05-26-2015, 04:12 PM
jjcook's Avatar
Quoted: 113 Post(s)
Liked: 30
When I had my Radiance XS, I was switching all my sources on the AVR and then using one output from the AVR into the Lumagen and out to the 2 projectors. I'm not sure about the XE but it was my understanding with the XS that I could output the digital audio over coax from the Lumagen into the AVR and thus retain the two Lumagen HDMI outputs for video to the two projectors, had I been using the Lumagen to switch sources.
For Sale: Panamorph DC1 anamorphic lens
For Sale: Navitar SSW065 short throw conversion lens
WTB: Triad InCeiling / InWall Gold Omni SE's or Silver MiniMonitors
Small HT: JVC RS4910, Mits HC7900DW, Falcon 2.35:1 100-wide, Triad Gold Omni SE & Silver Surrounds, PSA XS15-base, Marantz SR7008, Oppo 103D, Lumagen 2143 (soon), Tivo Mini, HTPC
jjcook is online now
post #3 of 16 Old 05-26-2015, 06:22 PM - Thread Starter
stanger89's Avatar
Quoted: 592 Post(s)
Liked: 309
I could do that, but the Lumagen seems to handle HDMI/sources much better than my Anthem. And while I could spit out coax, that would preclude passing HD audio to my Anthem.
post #4 of 16 Old Yesterday, 09:44 AM
Craig Peer's Avatar
Location: In my home theater ( when I'm not rock climbing, cycling or kayaking ) - Sacramento CA area
Quoted: 863 Post(s)
Liked: 631
You can try an HDMI splitter. I'll send you mine. I had issues with Blu Ray not syncing, but I have a 1080p projector and a 4K projector, which may be part of the problem. I believe Mike has two projectors being used with no issue - maybe he can chime in.
Craig Peer, AV Science Sales. Call me on my direct line - 585-671-2972, 8:30am - 4:30pm PST, Monday - Friday
Email me at craig@avscience.com http://shop.avscience.com/
Yes, we sell Home Theater gear right here at AVS !!
JVC, Sony, Epson, DPI, SIM2, SV Sound, Martin Logan, RBH, and many more!
Craig Peer is online now
post #5 of 16 Old Yesterday, 09:57 AM - Thread Starter
stanger89's Avatar
Quoted: 592 Post(s)
Liked: 309
Yeah, depending on if I'm sensitive to the lag on the 4910, the 4910/8150 combo may be a permanent setup. If I decide I need a "gaming" projector, well given what I could likely get for the 8150 and what a replacement would cost, I might as well just keep the far superior 8150
post #6 of 16 Old Yesterday, 09:59 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1647 Post(s)
Liked: 860
I am doing it the easy way. A prepro with dual HDMI output. I did used to have a Lumagen in the mix, but only used it on one projector. At that time I was using a dual output AVR. Before that I used a splitter with a 1080P projector and a 720P projector and experienced problems every now and then. Though I used that same splitter with a 1080P TV and a 720P projector in another room and it worked fine there. The more stuff you have in the chain, the more likely you are to have problems. Though I did get AVR, 6' HDMI cable, Lumagen Mini, 30' HDMI, Darbee, 6' HDMI cable, projector to work fairly reliable on one side. Other side was straight from AVR to second projector The HDMI cables were before Redmeer was available.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Sony, JVC, Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, SVS & Def Tech, Denon, Pioneer, Marantz & Yamaha .
AV Science Sales 5 is online now
post #7 of 16 Old Yesterday, 10:48 AM
kaotikr1's Avatar
Quoted: 37 Post(s)
Liked: 44
I have 3 moniotrs connected to my setup.
I use 1 output on my pre to my lumagen, which has dual outputs to my 2 projectors, then I use the other output on my pre to my pc monitor that I keep at my rack.
If you do any type of fast input gaming, you will notice the lag and want to have a gaming projector.
kaotikr1 is offline
post #8 of 16 Old Yesterday, 11:52 AM
AVS Club Gold
Liked: 860
I guess I could do three, since I have a 23" monitor at my rack, but I don't use the monitor that much, so I just plug it in when needed.
post #9 of 16 Old Yesterday, 12:32 PM
Seegs108's Avatar
Quoted: 1524 Post(s)
Liked: 549
Hmmm two at the same time? Every man's dream. Not sure about hookup tips though. You just need to find two that are into that.
Using an HTPC would be a great option. My graphics card supports 4 unique or cloned displays in use at the same time. You can use two for video and one for strict audio if you wanted.
d.j. likes this.
Seegs108 is online now
post #10 of 16 Old Yesterday, 01:51 PM - Thread Starter
stanger89's Avatar
Quoted: 592 Post(s)
Liked: 309
I know you and zombie, as well as others, tend to have more than one projector "functional" in your system at a time. I sorta got it to work, but ran into some HDCP issues, and well running one path through my Anthem doesn't seem that clean.
I could go to the anthem first I guess, and then just feed everything through the Lumagen and have that split it, but my systems been so much more stable with the Lumagen doing all the switching, plus I'd have to change all the macros in my URC remote. I suppose the stability could have been cabling, so maybe that's an option. I don't really need the Lumagen's per-input calibrations so that's not a big deal either.
HTPC won't help with:
  • Xbox 360
  • Xbox One
  • SageTV HD300
  • Chromebox (OpenELEC)
  • Blu-ray Player
I kinda hope I can be happy with just one projector, because mounting will be interesting too. My HT "area" (speakers seating etc) is only about 11.5' wide by ~20-22' long and 7.5' high, but it's in an open half of the basement so there's no wall at the back until you get to at least 35' from the screen, so they've got to be ceiling mounted, or sitting on a box taking up the whole "bar" area I do have some ideas though, might have to get a bit creative with the ceiling tile though.
post #11 of 16 Old Yesterday, 02:00 PM
Seegs108's Avatar
Liked: 549
  • Xbox 360
  • Xbox One
  • SageTV HD300
  • Blu-ray Player
Haha I'm just so used to using my PC for everything. You could always game exclusively on PC, get a cable card for your PC, dual boot with ChromeOS/Windows on the PC and watch your blurays on the PC (PowerDVD/MPC-HC) .
I've been using a Lumagen XD for a little while now for its autocalibrate feature with chromapure. It's a great little device and once they come out with a 4K input lumagen I may buy one.
post #12 of 16 Old Yesterday, 03:09 PM
Craig Peer's Avatar
Quoted: 863 Post(s)
Liked: 631
  • Xbox 360
  • Xbox One
  • SageTV HD300
  • Blu-ray Player
I've had two projectors before. I didn't want to sell my NEC HT1000, so I used it for 1.78:1, and my then new Optoma H79 for 2.35:1 -
The stepped soffit was vented into the attic, and had hidden access panels to get in. Why the room was white - well, hadn't gotten that part worked out with the wife ( now ex - wife ).
Now it's much easier - with a large offset projector like some single chip DLP's, I could add a third one !
post #13 of 16 Old Yesterday, 06:40 PM - Thread Starter
stanger89's Avatar
Quoted: 592 Post(s)
Liked: 309
No Halo, Forza, Gears of War on the PC. I didn't really intend to get sucked into Xbox exclusive games, but they seem to be the ones that resonate with me.
Don't need Cablecard, already use a PC for my DVR, with SageTV. But the SageTV HD300 does a much better job with TV than any PC setup I've come across, probably partially because my Lumagen handles the deinterlacing and scaling. And I've found no DVR that can come close to SageTV.
PowerDVD is very nearly the worst software I've ever used. MPC-HC is nice, but not the most remote friendly.
You've got a bit more ceiling height than I do. If I didn't have it right over my bar, you'd almost have to duck to walk under my Planar.
post #14 of 16 Old Yesterday, 06:51 PM
AVS Club Gold
Liked: 860
  • Xbox 360
  • Xbox One
  • SageTV HD300
  • Blu-ray Player
Two ceiling mounts, with one projector right behind the other, with the lens of the lower projector, just clearing the front projector.
post #15 of 16 Old Today, 04:29 AM - Thread Starter
stanger89's Avatar
Quoted: 592 Post(s)
Liked: 309
Yup that was kinda what I was thinking.
post #16 of 16 Unread Today, 03:39 PM
Highjinx's Avatar
Quoted: 20 Post(s)
I find a HDMI switch works better than a splitter........
.......in my case.
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is online now
