what are all the cables needed for LP350? - AVS Forum | Home Theater Discussions And Reviews
Old 04-19-2001, 09:20 AM - Thread Starter
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 875
Hi all,
I'm planning to prewire about 30' run to ceiling for this projector before they sheetrock my new home. What do I all need and what do you recommend? Thanks.
tvuong is online now
Old 04-19-2001, 03:37 PM
arrow's Avatar
I have three cables attached to my projector.
Power
S-Video (from Lexicon MC-1)
VGA into Infocus Cable Wizard (Dish 6000 HD)
--Les
arrow is offline
Old 04-19-2001, 08:48 PM
JasG's Avatar
I curious about this too. Has anyone used a pure digital connection with a long run.
1. How long?
2. Where did you get the cable.
3. What is the connector on the 340/350? InFocus says M-1, is that DVI-I, DVI-D, P&D/EVC?
FYI, there is some info here, but has anyone found other suppliers & longer than 5M cables?
http://store.kayye.com/kayye/dviaccessories.html
Obsession in moderation
JasG is offline
Old 04-20-2001, 07:42 AM
hhawk's Avatar
Quoted: 14 Post(s)
And may I add a question on connections to the LP340/350? Since the S input and scaler are so good, would I gain anything by connecting my RGB outputs from my non progressive scanning Pioneer DVD player? Can such a connection even be made?
hhawk is offline
Old 04-20-2001, 08:33 AM - Thread Starter
tvuong's Avatar
Liked: 875
<font face="Verdana, Arial" size="2">Originally posted by arrow:
Power
--Les
</font>
Two questions:
S-video: Which cable brand are you using. How long is it to the projector from the MC1? Is it a good cable?
VGA: Now I'm completely new to this and don't even know what kind or how it looks like? Do you have VGA to VGA from your Dish 6000 to the LP350?
I'll need 30' run for both of these cables. Thanks again.
Old 04-20-2001, 09:16 AM
Brian Corr's Avatar
You may want to check www.markertek.com for cables. Good prices, good selection, good quality.
Brian Corr is offline
Old 04-20-2001, 11:02 AM
arrow's Avatar
HHawk,
The Infocus will take RGB (what I've been calling VGA). It does not take component. I'm not sure if it will look better.
Tvuong,
My S-Video cable is a 12' run. There's nothing special about it. I think I picked it up at home depot. For a 30' run, you'll have to get the cables specially made.
--Les
arrow is offline
Old 04-20-2001, 03:47 PM
Jay C's Avatar
Check out the cable prices at Studio Experience www.studioexperience.com, I needed a 30' S-Video (why does markertek call it S-VHS?), and they had one at a very good price. The quality is very high and I have not noticed any artifacts.
Jay
Jay C is offline
Old 04-20-2001, 10:45 PM
jerryd2's Avatar
I recommend running a large diameter PVC conduit from the projector to the source electronics. It is less costly than one good cable and will allow you to replace a cable that fails or add one in the future that you didn't think you would need. If I recall correctly, the 10 foot sections of 2.5 inch PVC conduit go for under $5 at Home Depot.
Jerry in Colorado
jerryd2 is offline
