Remote IR sensor for G11, where can I get one? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-19-2001, 01:07 PM - Thread Starter
anderdea's Avatar
I will be building a hush box for my JVC G11. The owners manual indicates that an "infrared remote sensor extension unit" can be plugged into the remote port (small mini type audio plug format) at the side of the projector. The other end can then be put through a small hole in the box. Has anyone used this method? Where can I get the sensor extension?
I left a message with JVC, but know response.
Thank, Don
anderdea is offline
post #2 of 4 Old 04-19-2001, 01:18 PM
bluhorizan's Avatar
Don, I didn't receive a warrenty card with my projector and just talked with a real live person at JVC who confirmed that the sales receipt is all that is needed to honor the 2 year warrenty. I had previously left a message and got a phone call message back with erroneous info. I was able to talk with an actual person just a few minutes ago in their professional division; Good luck.
JVC 800-582-5825 or 973-315-5000
bluhorizan is offline
post #3 of 4 Old 04-19-2001, 02:31 PM
jaron's Avatar
try www.smarthome.com they carry all sorts of IR sensors
jaron is offline
post #4 of 4 Old 04-25-2001, 05:34 PM
dreamer's Avatar
Quoted: 917 Post(s)
Liked: 243
How do you identify what will work with a G11 ?
We are talking about just a sensor on one end and a mini-plug on the other, right ? None of the documentation I have for my projector and nothing I've found on the web has any specs for this item.
Most of the stuff at SmartHome is either bit parts that seem to need integrating into some other controller, or two-piece extenders where you have a powered sensor unit that converts to RF which is picked up by the second unit which recreates the IR signal through a blaster to be picked up by the sensor on the equipment you want to control.
For a hushbox, all we are interested in is a new sensor that can be attached to the ouside of the hushbox with a wire lead running back to the jack on the G11. Or have I misinterpreted what this jack is for ?
Kirk Ellis
G1000 D-ILA, HTPC, Panamorph (soon I hope),
Dish 6000 (HBOHD,SHOHD,CBS,NBC,ABC,WB,FOX,UPN, KCET -- does it get any better ?)
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
