Help for setting up new DLA-G15U - AVS Forum | Home Theater Discussions And Reviews
Old 04-29-2001, 01:06 PM - Thread Starter
nerbe's Avatar
I live in Dallas and would like to have my projector set up correctly for home theater use. I'm using an old Srewart screen (4:3, 99" diagonal) that I acquired about 8 years ago for use with an Ampro CRT projector and main sitting location is about 13' from the screen. I am using a DVDO Iscan V2, thinking about replacing it with a Faroujda Native Rate processor for the G15 (though most threads suggest a HTPC). My inputs are a Pioneer CLD-99 laser disk player, RCA DTC100 receiver for broadcast & satellite HD reception and a Panasonic DVD-A110 U/CA player (Svideo connection, no component).
I've read about JVC's factory tweaking, Dillard software, etc. Any suggestions as to how I could have someone (or myself) set the projector up to provide the best possible picture (ship it somewhere or someone in the Dallas/Plano area do it)?
Also any help with suggestions for a screen (Grayhawk and should it be 16:9 or 4:3); DVD player; and as mentioned above a processor and somehow having the projector set up correctly.
Neil
nerbe is offline
Old 04-29-2001, 04:25 PM
Vlubbers's Avatar
nerbe
Have you read the D-ILA FAQ that Mr. O'Brien has slaved over?
Mostly, I think you need to narrow this puppy of a question down a bit.
Sony G90-->D-ILA--> LCD-->Vango LED DLP
Vlubbers is offline
Old 04-30-2001, 08:40 AM - Thread Starter
nerbe's Avatar
Thanks, Just downloaded the FAQ. I'll review it and then simpilfy my question.
nerbe is offline
