dila settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-30-2001, 05:12 PM - Thread Starter
karos's Avatar
What's the difference between ST clamping and bpclamping? I dont think i see a difference? How can one illustrate the effect of this setting?
karos is offline
post #2 of 3 Old 04-30-2001, 05:25 PM
kyrill's Avatar
Good question. The instructions book did not explain, but suggested that it is not so important, if you do not have complaints in the setup.
What you see, will never be what you see
kyrill is offline
post #3 of 3 Old 04-30-2001, 09:04 PM
CCLAY's Avatar
Actually, it does explain it.
Quote: "if with some PCs or workstations the screen becomes unstable such as being too dark or too bright, try to switch to ST."
My take is on that is leave it alone unless you have that scenario.
Chris
My Home Theater is a work in progress.
CCLAY is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
