LP340/350 FAQ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-04-2001, 12:41 PM - Thread Starter
Ryan0751's Avatar
I saw an LP340/350 FAQ mentioned on this forum, but a quick google search didn't retrieve anything. Where is this FAQ located? Thanks!
Ryan0751 is offline
post #2 of 4 Old 05-04-2001, 12:51 PM
AlMark's Avatar
AlMark is offline
post #3 of 4 Old 05-05-2001, 07:15 PM
gregorm's Avatar
Hi everyone,
Sorry about the lack of updates to the FAQ over the past 3 months - I've been super-busy at work and as evidence I've only put about 100 hours on my LP350 http://www.avsforum.com/ubb/smile.gif
I just took some time and went through the FAQ and updated it - here's a summary of the updates:
- replacement of LP340 with LP340-C[rap] noted
- more detailed report on deinterlacer and it's limitations
- focus problems noted, suggestions listed
- bulb explosion problem noted
- rare minor 16:9 scaler bug/glitch found and noted (maybe PAL only)
- device compatability chart updated (ATI Radeon, Dreamcast WinCE games, 15KHz RGB incompatabilities noted)
- Strange occasional mis-detection of 640x480 RGB as 1024x768 bug discovered! (can we get Infocus to fix it?)
- some wording changed in various sections
Just in case I change the name of the FAQ html file in future, use this URL to get to it:
http://www.gregorvision.com/lp350
(and I've added a link to that to my otherwise horribly out of date front door)
Enjoy your projectors!
-GregorM
gregorm is offline
post #4 of 4 Old 05-07-2001, 12:23 AM
niggenz's Avatar
gregorm,
I wish I had read your FAQ before I bought a Radeon Card with DVI out, but I can finally report that there are some of us that have made the Radeon's DVI output work with LP340/LP350 projectors. See this thread:
http://www.avsforum.com/ubb/Forum12/HTML/010130.html
Still is sux tho. But you might want to update your FAQ.
HTPC: Intel NUC (DC53427HYE) running OpenELEC/Win7 Dual Boot
Projector: Optoma HD131Xe
Receiver: Onkyo TX-NR809
Screen: Elite Spectrum Electric 125"
Media Server: NAS4Free Core 2 Quad 2.40GHz
niggenz is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
