Custom stand for heavy projector with round base and pipes - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By AV Science Sales 5
post #1 of 7 Old 06-23-2015, 07:17 PM - Thread Starter
jaydaman93's Avatar
Liked: 0
My church needed a custom stand for our new projector because we werent allowed to mount as its a rental. So i designed a mount to hold our epson g6770wu projector which weighed 22.5 lbs. I bought the heaviest base i could find with a 1.5 inch npt in the middle. then i used the regular ceiling mount pipes to create a column going up with multiple pieces(including one adjustable piece), then used a 90 degree connection to go off to the side and then another column going down. Then a ceiling mount was screwed on to the pipe. All pipes were 1.5 npt connections. The base is 50 lbs. I also added a 45 lb olympic weight to sit in the center of the mount to have a total of 95 lb base. I was afraid it wouldnt be stable as the projector load is displaced from the center of mass. It looks fine with the final setup. I wanted to post exactly what i did for anyone else trying to do something similar. The projector ended up costing around 7000 with a long throw lens, standard lens, and extra bulb. The mount ended up being 600 with extra backup pipes. I have attached a picture for the setup. It was the preliminary trial with lighweight projector and no extra weight. I will post final setup later with the long throw lens. The final setup had the projector set on stand in the balcony projecting over a railing to the front of the church. I also attached my final list of items used to make the stand.
jaydaman93 is offline
post #2 of 7 Old 06-24-2015, 06:16 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1779 Post(s)
Liked: 942
I made a stand for my projector in my family room, since the projector was mounted in front of a window. I used a ceiling mount and inverted it. So the ceiling plate is the base. I then installed a piece of angle on the lower tube, to bolt to the wall. I took a threaded collar and welded it to a flat plate. The flat plate is screwed to a shelf. This shelf is then screwed to the inner pipe. This allows the projector to be used as various heights from 40" to 70". I also installed some gas struts inside the tubes, so that there is very little weight to pick up when you want to raise or lower the projector. Picture shows it in partially raised position for use on HP screen. Shelf is white, because when I first built it, I used a white projector, Epson HC400. Then later a Marantz VP-12S4.
Name:	Projector stand.jpg
Craig Peer likes this.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Sony, JVC, Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, SVS & Def Tech, Denon, Marantz, Yamaha & MiniDSP.
AV Science Sales 5 is offline
post #3 of 7 Old 06-24-2015, 08:06 AM
Craig Peer's Avatar
Location: In my home theater ( when I'm not rock climbing, cycling or kayaking ) - Sacramento CA area
Quoted: 940 Post(s)
Liked: 668
Very clever, excellent execution !
Craig Peer, AV Science Sales. Call me on my direct line - 585-671-2972, 8:30am - 4:30pm PST, Monday - Friday
Email me at craig@avscience.com http://shop.avscience.com/
Yes, we sell Home Theater gear right here at AVS !!
JVC, Sony, Epson, DPI, SIM2, SV Sound, Martin Logan, RBH, and many more!
Craig Peer is offline
post #4 of 7 Old 06-24-2015, 08:12 AM
Seegs108's Avatar
Quoted: 1628 Post(s)
Liked: 585
Is there some sort of question you want answered or are you sharing your custom stand project?
Seegs108 is online now
post #5 of 7 Old 06-24-2015, 09:11 AM
AVS Club Gold
Liked: 942
I think he is just sharing and since I had one I built several years ago, I thought I would put it in this thread.
post #6 of 7 Old 06-25-2015, 04:31 AM - Thread Starter
jaydaman93's Avatar
Liked: 0
That is cool. You should post instructions and materials list. Also I was posting my creation because I didn't find anything like what I did or the above after searching for a long time
post #7 of 7 Old 06-25-2015, 07:52 AM
AVS Club Gold
Liked: 942
I made mine several years ago and the products I used are no longer available. I had several mounts sitting around left over from a school that I built, where we installed projectors and screens in all of the classrooms. All you would need is:
3' to 5' adjustable drop tube: http://www.chiefmfg.com/Products/CMS0305 (can use different length if wanting larger or smaller)
A base plate. You could use something like this: http://www.chiefmfg.com/Products/CPA330
A top plate to fasten the shelf to: http://www.chiefmfg.com/Products/CMA110
A wood shelf, sized to fit the required projector. You also would need a small piece of 3"x3" angle iron for the wall clip. You would weld to side of lower tube. Rather than pay the high price of a large gas strut, I purchased two smaller gas struts and stacked them. http://www.indgassprings.com/volume-...choose-fitting You need to size for your needs. In my case I used 40 pound gas struts so that it could support the weight of projector, shelf and tube. To lock the position in place I used a spring loaded clevis pin. I ground down the pin so that it was only 1/4" long. Pin could not go all the way through the tubes, since gas strut is inside the tubes. The pin is just long enough to lock the inner tube to the outer tube. Since the tubes have hole spacing every 3", different heights are available for the shelf.
custom stand , epson stand , heavy base , mount , projector
