CI problem on Start-up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-12-2001, 03:35 PM - Thread Starter
Stephen.Sands's Avatar
I just had my Crystal Image installed. Up to now I hadn't used it with my G11. The problem is that when I turn it on with my Crestron set-up (I'm assuming the same would be true with a Pronto), the CI doesn't pass the picture to the G11. If I wait an unplug and then re-plug it, everything then works fine. Anybody know want the problem is or what I'm doing wrong? Is it a power supply problem? When this happens, only my Dish Sat. on pass-through works.
Stephen Sands
sands@starband.net
JVC-G11
Pioneer Elite FV-07 DVD
Adcom GTP-760 Processor
Crestron Controller
Pioneer Elite PD-F17 CD
Adcom GFA-7500 Amp
Dish Sat.
JVC HR-S4800U VCR
Stephen Sands
sandss@optonline.net
Stephen.Sands is offline
post #2 of 4 Old 05-13-2001, 09:27 PM
anson's Avatar
I've had a few startup problems myself, mostly of the "wrong input" or "wrong output format" variety. Is it possible that your IR startup sends the CI into choosing the wrong input? Next time you try this, try forcibly selecting an input, and if that works consistently, you may have to program your Crestron to do this for you...
anson is offline
post #3 of 4 Old 05-16-2001, 07:11 PM - Thread Starter
What are your input/output set-ups? I would appreciate it if you could describe them. Thanks in advance.
Stephen Sands
sands@starband.net
JVC-G11
Crestron Controller
Adcom GFA-7500 Amp
Dish Sat.
JVC HR-S4800U VCR
Stephen Sands
post #4 of 4 Old 05-17-2001, 07:11 AM - Thread Starter
Can someone describe to me their set-up using a non-modified G11/CI combo. It particular, what are the G11 and CI settings and which inputs are used? Has anyone used Dilard to "modify" the G11 in this situation and how? Thanks.
Stephen Sands
sands@starband.net
JVC-G11
Crestron Controller
Adcom GFA-7500 Amp
Dish Sat.
JVC HR-S4800U VCR
Stephen Sands
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
