lp 340 filter - AVS Forum | Home Theater Discussions And Reviews
Old 05-17-2001, 05:47 AM - Thread Starter
jmeitz's Avatar
I remember someone mentioning about a filter for a lp340 to give it better blacks and colors. Does anyone remember what type this was and how to change it?
jmeitz is offline
Old 05-17-2001, 06:10 AM
Walter Kircher's Avatar
That are neutral grey filters. You get them at a photography-shop in several diameters and levels. It helps to achieve a better black level with bright projectors.
Best regards, Walter
Graz, home town of the Terminator...
Walter Kircher is offline
Old 05-17-2001, 07:05 AM
Ryan0751's Avatar
Is there a way to combine this with some sort of mask for the 340 to help alleviate the halo effect?
Ryan0751 is offline
Old 05-17-2001, 09:07 AM
scottyb's Avatar
Quoted: 20 Post(s)
Ryan, Yes!!! Send me an email with your phone # and I'll call you and explain what I did to do this. It takes me too long to explain. If you don't want to send your # send email and I'll send you mine.
Scott
scottyb@scottyb.com
scottyb is offline
