LP340V Versus LP340B - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-18-2001, 05:57 AM - Thread Starter
Ryan0751's Avatar
How does one tell the difference between the 340V and the new 340B's? There is no marking on the unit as to what type of unit it is. Infocus is sending me a replacement 340 to fix the "timer reset" firmware bug, and I want to make sure the one I'm receiving is also a -V unit.
Ryan0751 is offline
post #2 of 7 Old 05-18-2001, 06:05 AM
leckian's Avatar
The B is targeted to business users and has an inferior video processor. Stick with the original InFocus LP340 (discontined)or the still current Boxlight CD-455M.
Lenny
leckian is offline
post #3 of 7 Old 05-18-2001, 06:08 AM
leckian's Avatar
Ryan the B model should be labeled that way. If it isn't it is probably the original model. To be absolutely sure buy the Boxlight CD-455M
Lenny
leckian is offline
post #4 of 7 Old 05-18-2001, 06:17 AM
David A. Frattaroli's Avatar
Leckian, Ryan already has the Infocus 340. It's being replaced by Infocus.
David A. Frattaroli is offline
post #5 of 7 Old 05-18-2001, 06:21 AM
leckian's Avatar
Yeh I read his post too fast. The B model should be be labled.
leckian is offline
post #6 of 7 Old 05-18-2001, 07:02 AM - Thread Starter
Ryan0751's Avatar
There must be a way to tell by the serial number... does anyone on here work for Infocus?
Ryan0751 is offline
post #7 of 7 Old 05-18-2001, 09:09 AM
leckian's Avatar
Ryan-
The LP340B is a different projector from the one you purchased. I don't think InFocus will replace your projector with a diffrent model without your permission. You will be able to tell the difference because the B is one solid color and the original 340 is two tone, plus the box will be labeled.
Lenny
[This message has been edited by leckian (edited 05-18-2001).]
leckian is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
