JVC D-ILA Monitor on HTPC - 640x480 only?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-19-2001, 10:18 PM - Thread Starter
Dave T's Avatar
Not sure if this is best posted on the HTPC forum, but I'll give it a shot here.
I'm trying to "tell" my HTPC that it has a D-ILA projector connected to it. When I set the Monitor to JVC D-ILA, it won't let me set the resolution above 640x480. I tried a couple other monitors, and they will "take", but I want to set the resolution to 1360x1024. I'm going to look for ideas in the famous "Pixel Perfect Timings" thread tomorrow, but if anyone knows what might be causing this, I'd very much appreciate your input.
- Dave
Dave T is offline
post #2 of 4 Old 05-19-2001, 10:28 PM
Mark Hunter's Avatar
Hi Dave,
When you say "set the monitor to JVC D-ILA", do you mean with PowerStrip?
Mark Hunter
Technical Director, Home Theater Products
Datacolor, Inc.
Mark Hunter is offline
post #3 of 4 Old 05-20-2001, 04:20 AM
Phat Phreddy's Avatar
I am guessing you are setting the monitor type in System Properties -> Device Mangler (oops Manager http://www.avsforum.com/ubb/wink.gif) -> Display...
If so try selecting standard monitor and setting the resolution up that way....
You may also use PowerStrip for the use of 16:9 resolution settings (I guess you knew this) and PowerStrip also has a way of making Monitor.INF files but I have never used it...
PhatPhreddy@Bigfoot.com
HTPC without using windows... GUI Front Ends for Home Theater
Phat Phreddy is offline
post #4 of 4 Old 05-20-2001, 07:11 AM - Thread Starter
Dave T's Avatar
Hi, Guys. Thanks for the replies.
Mark: I was setting it pretty much as Phreddy said - through "Display Properties" - "Settings" - "Advanced" - "Monitor".
Phreddy - I think I tried that and it didn't let me change to D-ILA resolution, but I'll try again.
The strange thing is that it will let me attempt to set higher resolutions - it seems to "know" the resolutions that the "JVC D-ILA" monitor supports, but when I pick one and hit "apply", the screen blanks for a second (which is normal), and then it reverts back to 640x480. When I try another monitor type, this doesn't happen. BTW, it happens if I try to change resolution either through Display Properties, or through Powerstrip.
- Dave
Dave T is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
