URGENT: How to clean Compaq mp1600? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-30-2001, 12:43 PM - Thread Starter
rickforrest's Avatar
Just received a used mp1600. Picture is gorgeous, but in the lower right hand corner of the picture is the shadow of a hair/fiber that is waving (in the airflow of the fan or color wheel).
I urgently need to know - how can I safely remove this? I don't have a manual. I have a 5 day inspection period - if I can fix this problem I will probably keep it. If I can't fix it, it's going back.
thanks,
rick
[This message has been edited by rickforrest (edited 05-30-2001).]
rickforrest is offline
post #2 of 2 Old 05-30-2001, 12:46 PM - Thread Starter
Also -
Is there a way to find out total hours on the projector? I found total hours on the bulb, but since it's easy to reset that, I was hoping to find out total hours on the projector.
thanks,
rick
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
