Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 429 - AVS Forum | Home Theater Discussions And Reviews
 39613Likes
post #12841 of 26709 Old 08-04-2016, 08:31 AM
Mike Garrett's Avatar
Quoted: 6930 Post(s)
Liked: 4615
Originally Posted by ChopShop1 View Post
2d is good for us Mike. I guess I could go pretty short throw....rather not, but could
At short throw a 150" wide screen would get you around 19/20FL. That is with high lamp and iris full open. Low lamp would get you around 14/15FL. That is larger than I would go, but I am more conservative than this. At 12' wide you would be able to close the iris down some. You would also be able to run in low lamp for a while.
mjgarrett100@gmail.com
Mike Garrett is online now
post #12842 of 26709 Old 08-04-2016, 08:32 AM
krichter1's Avatar
Quoted: 2048 Post(s)
Liked: 2293
Originally Posted by roxiedog13 View Post
Yup sure seems that way. I'll wait for the 1/2 price deal no hurry.
Have you tried the steps I recommended of adding in the Denon while everything was powered-off then powering back up in sequence? Do you get a picture (make sure 'Deep Color' is OFF on the Samsung too!)?
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is offline
post #12843 of 26709 Old 08-04-2016, 08:35 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3994 Post(s)
Liked: 4056
I have the HDFury integrral, did not know it also boosted the signal. I would have purchased the Gigabit HDM-GA1 accelerator if I could have found one for $200 US, like I said, it is not out there now. Just got a price from the Canadian distributor Pioneer Canada
ARE YOU READY ?? Canadian price $850, so I ordered 4 of course .
I haven't had one problem since I installed my HD Fury - also the best HDMI splitter I've used.
krichter1 likes this.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #12844 of 26709 Old 08-04-2016, 08:42 AM
ChopShop1's Avatar
Quoted: 325 Post(s)
Liked: 325
Back to the drawing board I guess...thanks Mike
ChopShop1 is offline
post #12845 of 26709 Old 08-04-2016, 08:45 AM
Wookii's Avatar
Quoted: 1283 Post(s)
Liked: 461
Presumably thats uncalibrated and brand new lamp Mike? I'd be surprised if you could hit 16FtL calibrated after a couple of hundred hours?
Wookii is online now
post #12846 of 26709 Old 08-04-2016, 08:46 AM
Liked: 4615
New lamp, open iris, high lamp and calibrated.
post #12847 of 26709 Old 08-04-2016, 09:02 AM
nathan_h's Avatar
Quoted: 1415 Post(s)
Liked: 921
Wow, this is actually really quite significant. It MIGHT go a ways toward explaining some stuff that seemed "strange" in my setup. Thanks for pointing this out.
I need to pay attention and see if it explains when I have been seeing. Previously I was pretty haphazard about whether to use Auto 2 or Fixed iris with HDR, because I was thinking there wouldn't be a significant difference (given how anemic the auto iris is).
I was attributing variation from disc to disc to the mastering of the content. But it could also be that I was something using auto iris and sometimes not.
Originally Posted by Javs View Post
Just a quick note regarding an HDR observation I have made in regards to the Iris setting on the JVC's. I don't remember reading about this behaviour, so here it is.
Although the Auto Iris is not supposed to work in HDR mode, if you have the projector in Auto Iris 2, the projectors iris is actually WIDE open no matter which manual Iris setting you had selected before switching on Auto 2.
I noticed this behaviour when setting clipping levels on the JVC, when I had the lamp on High mode, and set the Iris to -5 (Or any other setting for that matter) and I was in the JVC Menu, the iris was sure enough slightly closed at -5. Exit out of the menu (Iris set to MANUAL -5) and the peak white stays the same, iris stays slightly closed where it should be.
If you switch on Auto 2, then exit out of the JVC menu, the Iris will open fully. Hit JVC Menu button and Iris will close back down to -5 (Or whatever point you had set it).
To show this, I recorded a video. The JVC was displaying the Samsung 8500 Screensaver, the black screen with the Samsung logo floating around the screen. I then open and close the JVC Menu on the remote and you will see the Iris open and close. Closing when the JVC Menu comes up, and fully opening when I exit out of the menu. Which is actually the reverse of what you would see it do in SDR mode since the Sammy screensaver is almost a total black screen with only a logo floating around.
I then switch the Iris to manual mode and do the same, you will see the iris perfectly still, no change... I do this a few times in the video, Auto, Manual and then back to Auto again, each time I open and close the menu a few times...
Pretty odd!
So just a PSA. If you actually wish to set the Iris on anything other than fully open in your HDR modes, DO leave the Iris setting on Manual, dont switch it to Auto 2 thinking it may do something, well your right, it will raise your blacks and open right up!
Here is the video...
https://www.youtube.com/watch?v=adrLvxYmOqs
My current setup.
My favorite movie review podcast, the Next Picture Show.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is online now
post #12848 of 26709 Old 08-04-2016, 09:21 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4056
The problem with a screen that large is you miss out on the outstanding contrast you get when you close the iris down. Limit your screen size to 135" diagonal and maybe a 1.3 gain, and the picture is incredible, IMO.
roxiedog13 likes this.
post #12849 of 26709 Old 08-04-2016, 09:36 AM
Liked: 4615
You don't know chopshop. Go big or go home.
post #12850 of 26709 Old 08-04-2016, 09:40 AM
krichter1's Avatar
Liked: 2293
Let me inject here too if you plan on running UHD/HDR I wouldn't go any larger then 110-120" or you will be disappointed with the results, especially if you are going to be over a 15' throw (assuming as you said you are going to stay w/ a unity gain material; AT or otherwise).
Kevin
post #12851 of 26709 Old 08-04-2016, 09:41 AM
Wookii's Avatar
Liked: 461
Couldn't agree more Craig. I have the opposite problem - an AT screen with a negative gain (around 0.75). My screen is 110" wide (2.35:1) and I can no longer get 16FtL on high lamp and iris fully open (maxes out at 14.1FtL) now the lamp has aged.
I am hopefully going to secure a high gain screen soon to remedy the situation.
post #12852 of 26709 Old 08-04-2016, 09:54 AM
henrich3's Avatar
Quoted: 585 Post(s)
Liked: 502
Hi All, Thinking about an x950r/rs600 as a place holder for a while until more 4k dlp/laser development occurs more affordably.....what is the largest non gain screen any of you are using them on successfully, light controlled?
I have an RS600 and a 126" diag. 16x9 Stewart SnoMatte 100. I have good brightness in 2D using low lamp and the iris open (Auto 2 mode). For 3D and UHD/HDR I use high lamp and iris open (Auto 2). I wouldn't be happy with the dimmer image of 3D or UHD/HDR if I had a significantly larger unity gain screen. For 2D I'd use high lamp if my screen was larger.
henrich3 is offline
post #12853 of 26709 Old 08-04-2016, 11:29 AM
DLCPhoto's Avatar
Quoted: 899 Post(s)
Liked: 261
Right on Mike!
With your help, I have the Screen Innovations 160" 2.35:1 (equivalent 129" 16:9) screen, Solar White with 1.3 gain, with the less powerful RS400, and I am pretty damn impressed with the image: 2d and 3d!
Watched Despicable Me in 3D, and Edward Scissorhands in the last few days, and it was spectacular! Maybe I'd be even "more" blown away with the picture quality on a smaller screen, but where's the fun in that!!
mskreis likes this.
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, each powered by a bridged Adcom GFA-555; Center JBL LSR-308
Dolby Bed (4): Wharfedale Diamond II's, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLC Photography
DLCPhoto is online now
post #12854 of 26709 Old 08-04-2016, 11:44 AM
roxiedog13's Avatar
Quoted: 1815 Post(s)
Liked: 752
Nope, haven't tried yet, have been at the cottage . Biked 70 Kilometers last night so wasn't up to the task when I got back. Tomorrow night maybe if the rain finally shows, been to bloody nice.
Dedicated Theater: Sony VPL VW 675ESB , Panamorph Paladin Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Anthem 1120 AVR , 7.2.4 Atmos, Panasonic UB900, Oppo 203
Lumagen Pro 4440 , Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is online now
post #12855 of 26709 Old 08-04-2016, 11:46 AM
roxiedog13's Avatar
Liked: 752
Well then, since I have two of these HD Fury devises will have to give that a go too . As I said, so much equipment , so little time.
post #12856 of 26709 Old 08-04-2016, 12:06 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4056
Originally Posted by DLCPhoto View Post
Right on Mike!
One can run larger screens - especially if you are willing to change lamps more often. Maybe some day we will have laser projectors with contrast better then we have with todays JVC's, and 4000 lumens. Think of the big screens you could have then. A man can dream* !
* except I'm limited by my throw distance, so I'll hope and dream for the rest of you !!
post #12857 of 26709 Old 08-04-2016, 09:16 PM
grassy's Avatar
Quoted: 86 Post(s)
Liked: 38
Hi guys I will hopefully be joining you soon with an x9000 and a 145 inch majestic scope screen. Have been following this thread with interest and learning along the way. Hopefully will get a demo of one in Brisbane Australia soon and then go from there.Thanks for everyone's input so far.
alebonau likes this.
Fame is a mask that eats into the face.
grassy is offline
post #12858 of 26709 Old 08-05-2016, 02:04 AM
alebonau's Avatar
Quoted: 1438 Post(s)
Liked: 968
congrats @grassy ...
the x9000 will be a beauty ! I sure love my 7000
grassy likes this.
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
post #12859 of 26709 Old 08-05-2016, 04:53 AM
DLCPhoto's Avatar
Quoted: 899 Post(s)
Liked: 261
Rather than starting a threadjack here, I created a new thread on a topic that is relevant to RS400/500/600 owners, and I would love the input from some of the very experienced users in this thread:
Projector Calibration: Relationship to Editing in Photography
Don
Manni01 likes this.
DLC Photography
post #12860 of 26709 Old 08-05-2016, 07:40 AM
ChopShop1's Avatar
Quoted: 325 Post(s)
Liked: 325
Thank you for all of the replies guys! I've got time and am anxious to see the true 4k JVL units once they arrive.
post #12861 of 26709 Old 08-05-2016, 07:50 AM
roxiedog13's Avatar
Liked: 752
My guess is unless you need a super big screen that you will not need the 4K JVC. I would certainly expect the picture to calm down a little with 4K and no eshift but the difference will be
probably be minimal not worth the projected 450% increase in price for many.
Smart move to wait though, who knows what will be available from other manufacturers, the actual specs and pricing etc., is all guess work at this point. There is a lot of truth in the rumors
no doubt but best to wait and see.
post #12862 of 26709 Old 08-05-2016, 07:52 AM
Liked: 4615
He needs the lumens for the size screen he wants. That is why he is talking about waiting.
post #12863 of 26709 Old 08-05-2016, 09:10 AM
zombie10k's Avatar
Quoted: 3686 Post(s)
Liked: 3814
any idea how expensive it will be to get one of the Panasonic's to the US from Canada?
zombie10k is online now
post #12864 of 26709 Old 08-05-2016, 09:29 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4056
Aren't they available here in just a few weeks ?
post #12865 of 26709 Old 08-05-2016, 09:35 AM
zombie10k's Avatar
Liked: 3814
that's like a year for the impatient..
post #12866 of 26709 Old 08-05-2016, 09:35 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4056
Watched Star Trek in 4K with a friend that had been wanting to re-watch that movie last night. His impression ( first 4K he's seen in my theater ) - better detail, clearer looking. I'm not watching with HDR - and let me tell you, there are several scenes where the black levels in that film are just jaw dropping ! Space scenes look " out of this world " good ( pun intended ).I wanted to yell out " there's the JVC money shot ", but I stifled myself !
I'm using low lamp and manual iris at -7, auto iris 1.
Tom Bley and krichter1 like this.
post #12867 of 26709 Old 08-05-2016, 09:40 AM
Liked: 4615
that's like a year for those with ADHD..
Fixed your quote for you.
When it comes to this stuff, we all have this to some degree.
post #12868 of 26709 Old 08-05-2016, 09:40 AM
roxiedog13's Avatar
Liked: 752
My guess $30.00 would cover the freight but don't forget "free trade" that may cost you for duty and taxes . If you can sneak one across the border with a friend or ship as a gift you can avoid the
"free trade" costs.
post #12869 of 26709 Old 08-05-2016, 09:42 AM
roxiedog13's Avatar
Liked: 752
I bought the Samsung cuz I could not wait. The Panasonic now available in Canada and the Samsung just opened.
post #12870 of 26709 Old 08-05-2016, 10:15 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4056
I'd be more impatient except my budget is limited right now. I'll just bide my time with the Sammie until Oppo is good and ready with theirs.
jvc-rs500u synch/display issue? , RS600
