D-ILA FAQ - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 82 Old 07-22-2000, 06:29 AM - Thread Starter
Don O'Brien's Avatar
This is an attempt to create a D-ILA FAQ for all the interested parties.
G15, 20 G150CL Specs and link to a download of the manual
http://pro.jvc.com/prof/jvchome1.html
(under "presentation systems" select "video/data projectors".
Email AVScience for the best current pricing and avalability or visit the AVScience quikstore
http://www.avscience.com/cgi-bin/quikstore.cgi
Lens Calculator (10/22/03)
http://www.jvcdig.com/lens_calculator.htm
D-ILA Ceiling Mounts Manufacturers Premiere
http://www.premiermounts.com/
Peerless
http://www.peerlessindustries.com/LCD_projo_mount.htm
Chief
http://www.chiefmfg.com/default.asp
-DIY mount (specs and pictures)
http://www.theaterphile.com/construction.htm
Ceiling mount problem solving
http://www.avsforum.com/ubb/Archives...10-000923.html
<A HREF="http://www.avsforum.com/ubb/Archives/Archive-000003/HTML/20010420-10-002945.html" TARGET=_blank>http://www.avsforum.com/ubb/Archives...10-002945.html
</A> http://www.avsforum.com/ubb/Archives...10-002907.html
http://www.avsforum.com/ubb/Archives...10-002786.html
Dilard Software for D-ILA projector V2.1 (4/15/01) (RS232 control, 16:9 modifications and positioning, optimizing pixel clock and phase, correcting pixel shift problems, black level,8 bar wizard
http://www.dilard.com
D-ILA without mods on a 4:3 screen
http://www.avsforum.com/ubb/Archives...10-000582.html
D-ILA with Crystal Image
http://www.avsforum.com/ubb/Archives...10-000408.html
Importance of Scaler and/or HTPC with use of a D-ILA
http://www.avsforum.com/ubb/Archives...10-000790.html
CI and DILA (settings, resolution, AR, ISCO)
http://www.avsforum.com/ubb/Archives...10-000704.html
Clamp setting with CI and D-ILA
http://www.avsforum.com/ubb/Archives...10-001239.html
DTC100, ISCO, D-ILA scaler problem-interlace mismatch in 4:3
http://www.avsforum.com/avs-vb/showt...ghlight=hybrid
1080iHDTV hybrid interlaced/progressive scheme
HDTV resolution enhnaced by an isco lens with a D-ILA
http://www.avsforum.com/ubb/Archives...10-000385.html
D-ILA + DTC100=wow (reprise)
http://www.avsforum.com/ubb/Archives...10-003311.html
16:9 screen without mods (prior to Dilard),DTC100, HTPC
http://www.avsforum.com/ubb/Archives...10-000613.html
Quadscan and overscan
http://www.avsforum.com/ubb/Archives...10-001599.html
The vigatec Scaler and D-ILA
http://www.avsforum.com/ubb/Forum23/HTML/000707.html
4/16/01 New Calibration by William and AVS
http://www.avsforum.com/ubb/Forum10/HTML/005517.html
http://www.avsforum.com/ubb/Forum10/HTML/005467.html
Calibration information from JVC
http://www.avsforum.com/ubb/Archives...10-002663.html
http://www.jvcdig.com/technology.htm
D-ILA Isco1
http://www.avsforum.com/ubb/Archives...10-000524.html
panamorph throw distance, height, tilt, vertical offset ( home 751 vs 752 lens)
http://www.avsforum.com/ubb/Forum10/HTML/006794-2.html
D-ILA lens calculator and technical white papers from JVC
http://www.large-screen.com/jvc_publ...ublicmain.html
D-ILA and cabling
http://www.avsforum.com/ubb/Archives...10-001006.html
D-ILA with HTPC Vs. CI
http://www.avsforum.com/ubb/Archives...12-001548.html
Serial port control of the D-ILA Key2Serial
http://www.avsforum.com/ubb/Archives...10-000982.html
D-ILA manuals and technical description of the Projectors design
D-ILA and Hushboxes
http://www.avsforum.com/ubb/Archives...10-000386.html
Whisper Flow hush box (4/15/01)
http://www.avsforum.com/ubb/Archives...10-002706.html
http://www.avsforum.com/ubb/Archives...10-002777.html
http://www.avsforum.com/ubb/Archives...10-003451.html
http://www.whisperflow.com
CFM calculations
http://www.avsforum.com/ubb/Archives...10-000723.html
Material Sources
http://www.avsforum.com/ubb/Archives...10-000933.html
http://www.avsforum.com/ubb/Archives...10-001359.html
Hushbox Installations (thanks to msoo)
http://www.avsforum.com/ubb/Archives...10-002718.html
(MSOO) http://www.avsforum.com/avs-vb/showt...hreadid=124304
Mark Foster http://www.avsforum.com/avs-vb/showt...threadid=70097
Chris Satterlee http://www.avsforum.com/avs-vb/showt...hreadid=124354
D-ILA comparison to other projectors pro/con
10ht
http://www.avsforum.com/ubb/Archives...10-001024.html
Projector Central review (comparison to 10HT and Sharp 100)
http://www.projectorcentral.com/cons...cfm?ci=jvc_g11
CRT (Sony 1292)
http://www.avsforum.com/ubb/Archives...10-001226.html
D-ILA vs. CRT help me choose
http://www.avsforum.com/ubb/Archives...10-002961.html
Mark Foster pro/con
http://www.avsforum.com/ubb/Archives...10-000427.html
Digital Proj shootout (D-ILA, Sony10ht, Seleco HT250, Dwin Transvision)
http://www.avsforum.com/ubb/Forum10/HTML/005384.html
Sony G90 vs a maximally tweaked D-ILA (very long, but excellent in spots)
http://www.avsforum.com/ubb/Forum2/HTML/006116.html
DILA with HTPC- Alan Gouger's view
http://www.avsforum.com/ubb/Archives...10-000443.html
BlackLevel DILA vs. DLP
http://www.avsforum.com/ubb/Archives...10-000824.html
D-ILA and IR control (discrete on/off codes)
http://www.avsforum.com/ubb/Archives...10-003020.html
D-ILA and progressive DVD with 16:9 screen
http://www.avsforum.com/ubb/Archives...10-001240.html
D-ILA and image latency ("Burn-in")
http://www.avsforum.com/ubb/Archives...10-000721.html
D-ILA and adjusting tracking and phase with HTPC (2/3 down in the thread)
G1000,G10, G11 any difference?
http://www.avsforum.com/ubb/Archives...10-002159.html
D-ILA and Curved Screen compatibility
Planar Focus
http://www.avsforum.com/ubb/Archives...10-001038.html
Curved Screen problem solving (dreamer driven)
http://www.avsforum.com/ubb/Archives...10-001766.html
D-ILA mods information (scaler modification/AR switching)this method of modifying the scaler is no longer available
http://www.avsforum.com/ubb/Archives...10-000817.html
The Stewart Grayhawk screens
-Beta Testing-extensive thread on issues such as screen size, desirable screen brightness, etc (input from D. Stewart)
http://www.avsforum.com/ubb/Forum9/HTML/000583.html
-Grayhawk data at Stewart
http://www.stewartfilm.com/engineeri.../grayhawk.html
D-ILA and R Martin Calibration (no longer available)
http://www.avsforum.com/ubb/Archives...10-001902.html
http://www.avsforum.com/ubb/Archives...10-000570.html
Calibration of DILA projectors can now be done:
1) Dilard with appropriate hardware
2) William Phelps
3) Cliff Plavin-
Cheers,
Don O
Don O'Brien is offline
post #2 of 82 Old 07-22-2000, 07:52 AM
Mark Hunter's Avatar
Outstanding, Don! This post immediately got a bookmark from me (and I don't give those out very often)!
Maybe we can convince David to give this a "special place" within the "DLP, LCD, D-ILA Projectors" forum, so it doesn't get buried deep in the site in a few days.
Ideally, a link on the top of the forum to this FAQ that would be always available would be fantastic. What do you think, David?
Anyway, great work, Don! This is what all of the folks just getting into D-ILA need to become familiar with the technology. Instead of wading through the current posts "dazed and confused", they can jump to the FAQ and get the background on the state of things.
Mark Hunter
Technical Director, Home Theater Products
Datacolor, Inc.
Mark Hunter is offline
post #3 of 82 Old 07-26-2000, 07:11 PM - Thread Starter
New additons to the FAQ
12/31/2000
HTPC topics
G400 timings and D-ILA http://www.avsforum.com/ubb/Archives...12-000678.html
MPACT2 and D-ILA http://www.avsforum.com/ubb/Archives...12-002438.html
Geforce and D-ILA
Fixing image instability http://www.avsforum.com/ubb/Forum12/HTML/002648.html
16:9 screens and no mods with GEforce http://www.avsforum.com/ubb/Forum12/HTML/002856.html
Powerstrip http://www.entechtaiwan.com
3/9/2001 The newest version of powerstrip has Mark R's pixel perfect timings included. Thank you Ashley and Mark R.
YXY http://www.keohi.com/keohihdtv/htpc/yxy_windvd.html
Pixel Perfection with D-ILA and HTPC (adjusting tracking and phase "Milori and Rejohn) http://www.avsforum.com/ubb/Forum10/HTML/002952.html
Unmodified D-ILA with HTPCs, Timings for 1360x768, and 1360x580 (Mark Rejohns perfect timings for the D-ILA with a Geforce and Powerstrip)
http://www.avsforum.com/ubb/Forum12/HTML/004731.html http://www.avsforum.com/ubb/Forum10/HTML/002905.html
[This message has been edited by Don O'Brien (edited 03-09-2001).]
Cheers,
Don O
post #4 of 82 Old 07-28-2000, 09:09 PM
Jeffrey's Avatar
Hi everyone-
I just thought I would bump this one up to the top. IT IS WORTHY!
Thanks Don. You saved me a lot of time.
Jeff
Jeff
Jeffrey is offline
post #5 of 82 Old 07-28-2000, 10:00 PM
Laurence's Avatar
Thanks for this excellent contribution Don.
Laurence is offline
post #6 of 82 Old 07-28-2000, 10:19 PM
Alberts's Avatar
Whewwwwww!!!! Some much to read and so little time to cover it all. I'll have a very busy weekend. Thanks Don....Great Job!!!
[This message has been edited by Alberts (edited July 29, 2000).]
Alberts is offline
post #7 of 82 Old 08-03-2000, 05:43 PM
Jeffrey's Avatar
Moving on up.
Jeff
Jeffrey is offline
post #8 of 82 Old 08-03-2000, 06:12 PM
I would like to nominate Jeffrey as the DILA FAQ policeman...
Whenever this FAQ gets too low in the forum, it is your job to move it back up! If it should ever fall off the first page of topics...you're fired!
Mark Hunter
Datacolor, Inc.
post #9 of 82 Old 08-03-2000, 08:52 PM
tstites's Avatar
Don,
Nice work and I appreciate the mention of my site, www.large-screen.com, in your listing.
Although keeping the site up to date is not my day job, I'll do my best to keep pertinent information available. Feel free to send me anything you might like to see readily available there, I'm certainly open to suggestions.
This forum has become a valuable resource in helping drive the development of D-ILA based HT units...stay tuned.
Tom Stites
Region Manager, East Coast
JVC Visual Systems Division
"My opinions do not necessarily reflect..."
Tom Stites
"Speaking only for myself...."
tstites is offline
post #10 of 82 Old 08-08-2000, 05:54 PM
Jeffrey's Avatar
To the top.
Jeff
Jeffrey is offline
post #11 of 82 Old 08-12-2000, 03:25 PM
Alberts's Avatar
Time to move it back to the top
Alberts is offline
post #12 of 82 Old 08-17-2000, 11:04 PM
dreamer's Avatar
Quoted: 1072 Post(s)
Liked: 322
I had to go down three pages to find this today ! Far too low, and time to pop again. Seems to need it about every five days.
Kirk
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
post #13 of 82 Old 08-18-2000, 10:51 AM
Maybe David Botts (the webmaster of this site) can "pin" this post to the top of the group, so we don't have to massage it to the top as often.
It shouldn't be hard to "hard-code" a link at the top of the forum that links straight to this FAQ.
How about it, David?
Mark Hunter
Datacolor, Inc.
post #14 of 82 Old 08-25-2000, 04:51 PM
Daniel Hutnicki's Avatar
wee, love that feeling
Daniel Hutnicki is offline
post #15 of 82 Old 08-28-2000, 06:29 PM
CCLAY's Avatar
This DILA FAQ is the best!. I have a friend coming over with his HTPC to hook up to my G11, so I thought I'd better have this close to the top.
Chris
My Home Theater is a work in progress.
CCLAY is offline
post #16 of 82 Old 08-28-2000, 09:57 PM
up up and away
post #17 of 82 Old 08-29-2000, 10:53 AM
look, up in the sky, its a bird, its a plane, no its D-ila FAQ
post #18 of 82 Old 08-30-2000, 05:11 PM
weeeeeeeeeeeee
post #19 of 82 Old 09-05-2000, 06:58 PM
karos's Avatar
up
karos is offline
post #20 of 82 Old 09-06-2000, 02:47 PM
hey, why are we moving
post #21 of 82 Old 09-13-2000, 05:10 PM - Thread Starter
Sending it to the top with a few additions.
Don O
Cheers,
Don O
post #22 of 82 Old 09-17-2000, 06:52 AM
propeller_beach's Avatar
...moving to the top
propeller_beach is offline
post #23 of 82 Old 09-20-2000, 08:03 AM
Moving up...with a comment...
Don, can you add the very informative ProjectorCentral review of how DILA compares with DLP and LCD to the FAQ? It goes into the pros and cons of the G11 vs. the Sony 10HT vs. the Davis/DreamVision DLPs.
As you might have guessed, the review says that:
  • The DILA makes more noise and heat than other digital projectors.
  • The bulbs are more expensive.
  • The picture quality simply blows away the other digital projectors!
  • If you can put up with #1 and #2 above, have a price range of &lt;$10,000 and have high-quality feeds (DVD, HDTV), the DILA
    "totally smokes the Sony VW10HT and the Sharp DW100U. There is simply no contest."
    (ProjectorCentral quote from the article)
  • The article goes into more detail on each of the above.
Anyway, I thought that would make a good addition to the FAQ, for anyone doing comparision shopping. It helps you to decide what the pros and cons are of the different technologies. If ultimate image quality outweighs any of the cons, it sounds like the current choice to beat.
Mark Hunter
Datacolor, Inc.
post #24 of 82 Old 09-20-2000, 08:51 AM - Thread Starter
Mark,
I added to my first post under the "comparisons" section. Thanks for the link. Hope all is going well with your progress on the Dilard software. We all appreciate the amount of time and effort you are expending on our behalf.
Don O
Cheers,
Don O
post #25 of 82 Old 09-23-2000, 11:50 AM
Jeffrey's Avatar
Jeff
Jeffrey is offline
post #26 of 82 Old 10-02-2000, 07:38 PM
Moving up.
Mark Hunter
Datacolor, Inc.
post #27 of 82 Old 10-06-2000, 06:14 AM
tdemelle's Avatar
bloo00OOP!
Todd
tdemelle is offline
post #28 of 82 Old 10-13-2000, 05:49 PM - Thread Starter
Back to the top
Cheers,
Don O
post #29 of 82 Old 10-16-2000, 10:25 AM
Mark Hunter
Datacolor, Inc.
post #30 of 82 Old 10-17-2000, 12:49 AM
Max Spivak's Avatar
Where are we going? And what are we doing in this handbasket?
Max Spivak is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
