Back From The Dead: Sony VPL-VW100 Ruby Squeal - AVS Forum | Home Theater Discussions And Reviews
Old 09-25-2016, 02:25 PM - Thread Starter
gumart1's Avatar
My VPL-VW100 is getting older but still puts out a really nice image and so I'd like to keep her going. With about 1500 hrs on my bulb, it started making the well known "chirp" sound. The sound disappears when I turn the PJ off while the fans are still running. Instead of replacing the bulb, I'd like to experiment with removing the heat sink compound, which may help according to this forum.
I searched the old threads, but can't find the procedure for this or for removing the bulb from the housing. Any links or help would be appreciated.
gumart1 is offline
