Ceiling Mount Frustrations I need help finding a new one. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Craig Peer
post #1 of 8 Old 03-21-2017, 04:21 PM - Thread Starter
frontside720's Avatar
Quoted: 18 Post(s)
I have my new Sony 665 set up and I'm having the same projector mount issues.
My mount is solid to the ceiling but theres a lot of wobble to the mount. My local AV store installed it and it's the second one. I'm at the point where they are completely incompetent in resolving my issue and I would like to look into it on my own.
My projector is heavy 30lbs and needs to hang about 12inches so I can clear a bulk head. They have some tape thing rigged up but it's not working the way I want.
Can anyone recommend a high quality projector mount that I can make minor adjustments to so I can get it dialled in just right?
It appears that they put electrical tape around the telescoping portion but it's not working. Here's my current electrical tape massacre they did...
frontside720 is online now
post #2 of 8 Old 03-21-2017, 05:25 PM
Tom Bley's Avatar
Quoted: 616 Post(s)
Liked: 549
I think you should look at Chief Mfg. I've owned one and plan on getting another one for my JVC. Lol I hope that electrical tape is to help support the down rod. Looks like it's just holding wires to the extension pole.
Tom Bley is online now
post #3 of 8 Old 03-21-2017, 08:52 PM - Thread Starter
Quoted: 18 Post(s)
haha no electrical tape is not for any support. It is there at the top to stop the wobble.
post #4 of 8 Old Yesterday, 10:18 AM
stanger89's Avatar
Quoted: 2833 Post(s)
Liked: 1467
Chief RPMx, I'm very happy with mine, wish I'd gone that route a lot sooner.
http://www.chiefmfg.com/Series/RPMx
Also, FWIW, you can just use standard plumbing black pipe/fittings for the tube and ceiling plate, Chief uses standard NPT fittings.
stanger89 is online now
post #5 of 8 Old Yesterday, 10:42 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3245 Post(s)
Liked: 3207
I hate to insult anyone's setup, but that mount looks like a piece of crap !
Try this - http://www.chiefmfg.com/Products/RPMA020 or this - http://www.chiefmfg.com/Products/RPA020
Lygren likes this.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #6 of 8 Old Today, 07:21 AM - Thread Starter
Quoted: 18 Post(s)
I agree, it's terrible.
I'm going to go with the Chief.
So many options on the ceiling plate.
post #7 of 8 Old Today, 07:34 AM
Mike Garrett's Avatar
Quoted: 5798 Post(s)
Liked: 3737
If you would like help with parts selection, shoot me an email. I actually have the same mount. Purchased it many years ago. Took one look at it and never pulled it out of the box. Still sitting in the box it came in, in my garage. it is a piece of junk.
mjgarrett100@gmail.com
Mike Garrett is online now
post #8 of 8 Old Today, 08:27 AM - Thread Starter
Quoted: 18 Post(s)
Ordered a new setup from Chief.
Thanks for the recommendations!!
