new Monoprice SlimRun AV HDR optical HDMI - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #31 of 60 Old 04-22-2017, 05:32 AM
Mike Garrett's Avatar
Quoted: 6947 Post(s)
Liked: 4625
I have the 50'. No problem sending 4K with HDR at 24p. I do have the Oppo sending 12 bit 4:4:4. I do not have a 4K 60P source.
mjgarrett100@gmail.com
Mike Garrett is online now
post #32 of 60 Old 04-26-2017, 01:33 PM
ttn333's Avatar
Quoted: 27 Post(s)
Just a heads up. Monoprice is having a 20% off promo code for that applies to this cable. Use "CNET20". I just picked up a 30' run. Couldn't wait for the upcoming cable review and needed to install the cable now. Hope it works.
Edit: code expires 4/30/17
Denon x4300h ........................................Denon x2400h
Emotiva xpa-3 ........................................Elac Debut F5
Totem Mani-2 front...................................Elac Debut C5
Totem Mite-T center..................................Elac Debut A4
Totem Mite surrounds and Atmos................Klipsch r-12swi
SVS PC13 Ultra........................................xxxxx xxxxxxxx
ttn333 is online now
post #33 of 60 Old 04-26-2017, 04:28 PM
Javs's Avatar
Quoted: 3152 Post(s)
Liked: 2628
Can anyone stick a multimeter on both ends of the HDMI shield jacket and tell me if they get conductivity?
I will buy one in a second if it will get rid of my ground loop.
A ground loop which is created by the outer HDMI shield...
JVC X9500 (RS620) | OZTS Majestic 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | Rotel RMB-1555B | DIY Javelin Audio TPL-150 L/C/R | DIY Faital MTM TPL-150 Surrounds | DIY Dolby Atmos MKII Modules | DIY Quad 18" Subs 30cf Net
Shootout - JVC RS500 (X7000) & Sony 320ES | My Panasonic UB900 HDR and SDR Settings | My MadVR Settings
Javs is offline
post #34 of 60 Old 04-27-2017, 06:39 AM
Liked: 4625
I assume you are talking about the gold connector on each end. Yes, I did get conductivity. The number 5 pin is ground, but I have not found anything small enough to fit in the hole to check. I though small paper clips would fit, but they are too big.
post #35 of 60 Old 04-27-2017, 06:41 AM
Javs's Avatar
Liked: 2628
Yeaj the outside of the connector not the pins inside.
If you got conductivity on the outside then there is copper in the cable as stated earlier, thats a shame.
Wont fix ground loops.
Celerity cable needed then.
Wait Mike do you also have a celerity cable? Any way you can do the same test on that?
Javs is offline
post #36 of 60 Old 04-27-2017, 10:46 AM
BMac1203's Avatar
Quoted: 108 Post(s)
Liked: 68
I actually just got the SlimRun AV (not HDR) cable in the mail today....sigh....I didn't realize that the HDR version existed.
I have since requested an RMA and placed an order for the 50' HDR version.
Crossing my fingers that this passes 4:4:4 from my Denon 4300H to my JVC 420!
Media Room: JVC DLA-RS420, ST 125" 2.35:1 screen, Denon AVR-x4300h, Outlaw Audio 7125, Sony UBP-X800, Klipsch RF-7ii fronts, RC-64ii center, RS-62ii x2 surrounds && RS-41ii x2 backs, HSU VTF-3 MK5 x2 subs, Micca M-8C heights
Living Room: 65" Sony XBR65X900E; Vizio 45" 3.1 SB4531-D5 sound bar
BMac1203 is offline
post #37 of 60 Old 04-27-2017, 10:51 AM
Liked: 4625
We have one at the shop. Let me see what I can do.
Added
I had them check the Celerity cable we have and they said no continuity on it.
post #38 of 60 Old 04-27-2017, 04:11 PM
Javs's Avatar
Liked: 2628
Added
Thanks Mike, thats a shame.
The Monoprice cable is definitely out then for fixing any kind of ground loop.
Javs is offline
post #39 of 60 Old 04-27-2017, 06:00 PM
Liked: 4625
Celerity will work for you though.
post #40 of 60 Old 05-02-2017, 08:26 PM
Liked: 0
I purchased a 75 ft version of Monoprice Slimrun HDR. I was able to feed 4K@60Hz 10bit HDR 4:2:0 through it smoothly (playing "Man in the high castle" using Amazon Video - Roku Premiere+).
But I was not able to make ARC work. Did anyone manage to make ARC work?
Richard Wong is offline
post #41 of 60 Old 05-02-2017, 09:17 PM
Moderator
rboster's Avatar
Quoted: 1212 Post(s)
Liked: 1308
Thanks for the feedback
Ron
rboster is offline
post #42 of 60 Old 05-02-2017, 10:19 PM
Anthony Cler's Avatar
Quoted: 17 Post(s)
ARC doesn't work with optical HDMI.
Anthony Cler is offline
post #43 of 60 Old 05-02-2017, 11:27 PM
Liked: 0
Do you know how they manage to make ARC work for Celerity? I was hoping this cable can do the same magic (at 1/2 the price)
post #44 of 60 Old 05-03-2017, 12:05 AM
Quoted: 17 Post(s)
I'm not sure how the Celerity cable passes ARC. I don't believe optical HDMI cables are bi-directional, so I don't see how ARC would work.
post #45 of 60 Old 06-14-2017, 08:28 AM
fp43's Avatar
They have to be bi-directional for CEC to work. Bi-directional is no problem for fiber in other applications, not sure why it would be a problem for HDMI.
What am I missing?
fp43 is offline
post #46 of 60 Old 06-20-2017, 01:32 PM
gaspimp's Avatar
Some optical HDMI cables will run a few copper pairs for things like ARC, CEC, alongside the fiber for bidirectional comms.
gaspimp is online now
post #47 of 60 Old 06-20-2017, 01:43 PM
Quoted: 17 Post(s)
Good to know. Thanks!
post #48 of 60 Old 06-29-2017, 06:38 AM
fp43's Avatar
FWIW, I bought the 75' SlimRun AV HDR from Monoprice. It works well @ 4k60p, CEC works fine, but does not support ARC. I ordered a Toslink at the same time and ran it alongside the SlimRun cable, TV audio works on the AVR as expected.
fp43 is offline
post #49 of 60 Old 07-04-2017, 09:39 PM
mobius's Avatar
Quoted: 50 Post(s)
Liked: 41
I've had mine hooked up for around a week now, and it works great. Not unexpectedly, it's much easier to pull and maneuver compared to 24awg HDMI cable. I don't have a 4K source or TV yet, but I will soon enough.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling that thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a...
mobius is offline
post #50 of 60 Old 07-09-2017, 08:10 AM
Newbie789's Avatar
Quoted: 305 Post(s)
Liked: 91
Question Any failures of monoprice SlimRun AV HDR for HDMI?
Has anyone had any failures of these cables? I am planning to do an in-wall installation and am wondering if I should should run 2 cables, having one for backup...
Newbie789 is offline
post #51 of 60 Old 07-09-2017, 12:17 PM
rak306's Avatar
Quoted: 557 Post(s)
Liked: 223
I would run smurf-tube or similar to be able to pull a cable later. You can guarantee that in 10 years time, whatever we have today will be obsoleted and require a new cable then.
rak306 is offline
post #52 of 60 Old 07-09-2017, 03:15 PM
Newbie789's Avatar
Quoted: 305 Post(s)
Liked: 91
If I do a surf tube and want to use it later for an hdmi how long are the intervals between pull boxes?
post #53 of 60 Old 07-09-2017, 06:00 PM
rak306's Avatar
Quoted: 557 Post(s)
Liked: 223
Im no expert, but I would expect it is going to depend on how straight the run is. You certainly dont want sharp bends with either fiber or HDMI cable.
Newbie789 likes this.
rak306 is offline
post #54 of 60 Old 07-14-2017, 11:32 PM
Newbie789's Avatar
Quoted: 305 Post(s)
Liked: 91
I just ran (4) 100ft slimrun av hdr cables through house. They are very very delicate. The outer rubber coating can easily damaged. We ended up pulling 3-4 ft at a time to avoid damage.
The cable is very light and flexible. Make sure you unroll the entire cable television on the floor and walk the cable through your hand at least 5 times to eliminate the twists from the roll shape it's shipped in. The cable loves to twist and it's very thin = bad combination.
I'll be able to let everywfknow soon if they work after being ran through the framing.
post #55 of 60 Old 07-18-2017, 09:12 PM
Newbie789's Avatar
Quoted: 305 Post(s)
Liked: 91
Cables work great at 100ft for 4k@60hz 4:4:4
post #56 of 60 Old 07-21-2017, 12:35 PM
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Thinking i was getting a deal, i picked up a used Celerity on ebay, its a 35' DFO, one hitch its a 16gbps...... The new ones are 18gbps :0/ Time will tell, i dont have a 4K player or streamer yet
kgveteran is offline
post #57 of 60 Old 07-21-2017, 01:28 PM
Quoted: 20 Post(s)
Liked: 6
pulled the trigger and cable works great @30ft.
makaman is online now
post #58 of 60 Old 07-21-2017, 01:57 PM
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Which one ?
post #59 of 60 Old 07-21-2017, 01:59 PM
Quoted: 20 Post(s)
Liked: 6
SlimRun AV HDR Cable for HDMI Enabled Devices, 4K@60Hz, YUV4:4:4
post #60 of 60 Old 07-21-2017, 04:30 PM
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Figured a passive cable would get cooked up somewhere
