Epson 5040UB vs JVCRS500 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 42 Old 05-03-2017, 08:44 AM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
What projector would be better for strictly sports viewing? Dark room, but occasionally have some light. 126" 1.3 gain fixed screen. 12 feet away.
Sent from my XT1650 using Tapatalk
4k UHD HDR = Heaven
sn1ffb0 is offline
post #2 of 42 Old 05-03-2017, 09:01 AM
Mike Garrett's Avatar
Quoted: 7094 Post(s)
Liked: 4797
If you are not running frame interpolation, then the RS500 would be the better projector. But if all you are doing is sports, you really are using very little of the added advantage of the JVC's much higher native contrast, since sports are bright content. So for the money, I would go with the 5040.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 42 Old 05-03-2017, 03:51 PM
LumenChip's Avatar
Quoted: 171 Post(s)
Liked: 78
12 ft away is at the limit of the max zoom for both projectors, consider using a smaller screen or moving the projector a foot further from the screen.
LumenChip is offline
post #4 of 42 Old 05-03-2017, 04:10 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2582
if you're only watching sports, as in 100% of the time, I don't think either projector is the best choice. Go with a bright, decent quality DLP projector. It will offer the kind of image quality sports require; excellent motion performance, high ANSI contrast and plenty of brightness. LCD-variant projectors like the two you're asking about offer less performance in these areas compared to a DLP projector. Something like a Vivitek H5095 or even their LED variant, the H9090, with the short throw lens option would be excellent choices in my opinion.
Seegs108 is offline
post #5 of 42 Old 05-03-2017, 04:43 PM
Quoted: 66 Post(s)
Agreed. My BenQ HT2050 is awesome for sports. You won't care about the poor black levels of DLP, and you also won't see rainbows, as those are only a problem for white objects against a dark background.
bochoss is offline
post #6 of 42 Old 05-03-2017, 05:16 PM
AMartin56's Avatar
Quoted: 2166 Post(s)
Liked: 1137
Another vote for what's suggested above. Personally I can't go with DLP since RBE gives me headaches so I'd go with the 5040. The JVC is definitely overkill for sports especially since you are likely to have some lights on. And movies would look decent on the Epson if you ever decide to mix them in.
AMartin56 is offline
post #7 of 42 Old 05-03-2017, 06:31 PM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
What about a Runco LS-5?
4k UHD HDR = Heaven
sn1ffb0 is offline
post #8 of 42 Old 05-03-2017, 06:36 PM
Quoted: 172 Post(s)
Liked: 57
I went from an Epson 5020 to a Benq W1070 because the motion on the Epson was terrible with sports.
jsil is online now
post #9 of 42 Old 05-03-2017, 06:37 PM
Seegs108's Avatar
Liked: 2582
I see you have a 12 foot throw distance. The LS-5 won't work at your screensize with that thrown even with the short throw lens option.
Seegs108 is offline
post #10 of 42 Old 05-03-2017, 06:41 PM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
4k UHD HDR = Heaven
sn1ffb0 is offline
post #11 of 42 Old 05-04-2017, 10:05 AM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
I had the W1070 for a short period of time and didn't think the picture was all that great. Any other DLP recommendations?
4k UHD HDR = Heaven
sn1ffb0 is offline
post #12 of 42 Old 05-04-2017, 11:04 AM
Quoted: 172 Post(s)
Liked: 57
Sorry that's the only DLP projector that I've used.
jsil is online now
post #13 of 42 Old 05-04-2017, 08:31 PM
aka: HarperVision
Dave Harper's Avatar
Quoted: 1599 Post(s)
Liked: 747
I think the Epson 5040 is easily the best option for the money out there right now. You can get amazing HDR if you ever want that, it's brighter than the RS500 and the sports I've watched on it so far in Natural Mode were very nice too.
Dave Harper is online now
post #14 of 42 Old 05-05-2017, 10:11 AM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
4k UHD HDR = Heaven
sn1ffb0 is offline
post #15 of 42 Old 05-05-2017, 10:12 AM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
What about an LS-3? My room is 22 feet long. I can move it back if need be.
4k UHD HDR = Heaven
sn1ffb0 is offline
post #16 of 42 Old 05-05-2017, 10:42 AM
zombie10k's Avatar
Quoted: 3881 Post(s)
Liked: 3962
these are still excellent projectors today. I use it for gaming / TV along side of my JVC which is used primarily for movies.
you can usually pick these up for ~1500 on ebay and the OEM lamps are still available for ~$80 so it's cheap to run these for extended periods of time.
zombie10k is offline
post #17 of 42 Old 05-05-2017, 10:46 AM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
Zombie, would you recommend any other DLP besides a Runco LS-3 for 100% sports viewing that is under $2,000?
4k UHD HDR = Heaven
sn1ffb0 is offline
post #18 of 42 Old 05-05-2017, 11:07 AM
Seegs108's Avatar
Liked: 2582
If you have 22 feet, the either an LS-3 or LS-5 will work. The LS-5 is a better projector.
Seegs108 is offline
post #19 of 42 Old 05-05-2017, 11:07 AM
stanger89's Avatar
Quoted: 3695 Post(s)
Liked: 2055
If you've got the room to move it, go with the LS5, it's a great machine, one of the best single chip DLPs ever made, even to this day. I've still got my Planar 8150 (became the LS5 when Planar bought Runco and rolled the whole HT line under the Runco banner).
There's a number of good DLPs out there, the Sharp Z30000, Runcos, DPIs, Barcos. The higher end Viviteks are quite good too. The problem is, "new" they're generally still quite expensive if you can find them, so your best bet is used.
Keep an eye out for some of the LED ones from Runco, DPI, Vivitek too. For bright content, they'll keep up with anything out there today.
stanger89 is offline
post #20 of 42 Old 05-05-2017, 11:10 AM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
What about the Planar 8150 with the darkchip4?
4k UHD HDR = Heaven
sn1ffb0 is offline
post #21 of 42 Old 05-05-2017, 11:24 AM
stanger89's Avatar
Liked: 2055
Those only exist in myth and legend. Unless you're Seegs or Zombie and made your own. There wasn't ever a Planar with the DC4 DMD. That said the Planar 8150 is every bit as good as the LS5, it's just a different name sold under a different brand/distribution channel.
post #22 of 42 Old 05-05-2017, 11:24 AM
zombie10k's Avatar
Liked: 3962
The Planar 8150 is a DC3 projector. There's only 2-3 custom 8150's out there with the DC4, I have one of them. it's not a major difference though and still worth pursuing.
http://www.ebay.com/itm/1080p-Runco-...-/152382053772
Dave Harper likes this.
post #23 of 42 Old 05-05-2017, 11:40 AM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
If I can get a Planar 8150 and a Epson 5040UB for the same price, sports only, what would you choose?
4k UHD HDR = Heaven
sn1ffb0 is offline
post #24 of 42 Old 05-05-2017, 12:15 PM
zombie10k's Avatar
Liked: 3962
I would pick the DLP. The Epson would be brighter if you needed the extra light for higher ambient light viewing but from your description of darker room with some ambient light on the 126" with some gain it will be fine.
I prefer the .95 DLP pixel structure vs. the wide gap on the Epson LCD's which I find distracting.
.95 Planar / Runco
Epson 5040
post #25 of 42 Old 05-05-2017, 12:17 PM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
[quote=zombie10k;52767889]I would pick the DLP. The Epson would be brighter if you needed the extra light for higher ambient light viewing but from your description of darker room with some ambient light on the 126" with some gain it will be fine.
Thanks for the help and sorry for a million questions, but what about something like a Digital Projection E-Vision 4500 vs the Planar?
4k UHD HDR = Heaven
sn1ffb0 is offline
post #26 of 42 Old 05-05-2017, 12:24 PM
zombie10k's Avatar
Liked: 3962
that is a very bright projector designed for high ambient light or large screens. In low lamp you may have to run an ND filter to block some of the light. it's a .65 vs. 95 DLP and has less contrast than the Runco which is more designed for a HT application with controlled light.
that ebay price is good but not sure if that projector makes sense for your room.
post #27 of 42 Old 05-05-2017, 12:32 PM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
Thanks. Enough questions. I'm either going for a Planar 8150 or Runco LS-5 since they are the same.
Bluescale likes this.
4k UHD HDR = Heaven
sn1ffb0 is offline
post #28 of 42 Old 05-05-2017, 12:54 PM
Seegs108's Avatar
Liked: 2582
Even almost 10 years later the PD8150 puts out a competitive image when you factor in it's price on the used market and what you can find new +/- $1000.
Seegs108 is offline
post #29 of 42 Old 05-05-2017, 02:44 PM
Liked: 4797
For 100% sports, I would say DLP, but with that said, I bet once you get the projector, you will do more than just sports watching on it. Big screen movies in your home can be really special.
post #30 of 42 Old 05-05-2017, 03:03 PM - Thread Starter
sn1ffb0's Avatar
Quoted: 87 Post(s)
Liked: 41
I have my JVC RS500 for that
4k UHD HDR = Heaven
sn1ffb0 is offline
