Can't remember/understand Thow calculator - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-02-2017, 04:53 AM - Thread Starter
D_B_0673's Avatar
Quoted: 58 Post(s)
Can't remember/understand Throw calculator
I have a 10 yr old RS1 (JVC) at about 19' woth a 106" 16x9 screen, and will be upgrading soon
I don't remember how to interpert the Throw range.
Can you place a PJ anywhere within the listed range for a given screen or do you have to pull the PJ back or forward to only one spot to make it fit your screen.
I don't remember that being the case.
I think I remember setting my PJ, and then manipulating the lens to make it fit the screen, is that correct?
thanks
dan
Used to know all this, but have really been away for a number of years
Dan
D_B_0673 is offline
post #2 of 3 Old 08-02-2017, 09:07 AM
Mike Garrett's Avatar
Quoted: 6700 Post(s)
Liked: 4388
thanks
dan
The calculator give you a range that you have to set the projector in. The range is measured horizontally from lens to screen. As you move closer to the short end of the throw, you gain brightness. The range for your RS1 with 106" diagonal 16:9 screen is 10'-3" to 21'-3". A new RS520 would have a range of 10'-9" to 21'-6".
mjgarrett100@gmail.com
Mike Garrett is offline
post #3 of 3 Old 08-02-2017, 10:02 AM - Thread Starter
D_B_0673's Avatar
Quoted: 58 Post(s)
thanks Mike,
dan
Dan
D_B_0673 is offline
