100% fade to black with Digishutter pro 1.0 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By Dj Dee
  • 1 Post By Highjinx
  • 1 Post By Dj Dee
  • 1 Post By Dj Dee
  • 1 Post By blee0120
  • 1 Post By airscapes
  • 1 Post By Dj Dee
  • 1 Post By D_B_0673
post #1 of 22 Old 08-06-2017, 01:41 AM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
100% fade to black with Digishutter pro 1.0 on digital projectors, is something i have been looking for after going digital form CRT along time ago.
I have the pleasure to test out this funny fantastic idea, to get stray light form the projector to disappear then only with 0 IRE.
I cant stand the grey on screen when it shall be black in my opinion.
This Digishutter pro 1.0 is under testing/development and improvements done after observation.
Have tested it now for some days, and can just say that extremely cool, and just love it.
On JVC this look very good, because the extreme high on/off, and iris that "almost" make it totally black.
I have now a JVC RS520.
On a DLP/ SXRD/ or other than D-Ila you will think that your projector died. This because of grey not black.
Digishutter pro 1.0 have its own HDMI, so clean untouched Blu-ray or UHD signal.
Sending up some Pictures and a little film to show how this work. More info will come
Javs likes this.
AKA Diddern on some other forums, Here at AVS always been DJ Dee :)
Dj Dee is offline
post #2 of 22 Old 08-06-2017, 04:59 AM
Javs's Avatar
Quoted: 3405 Post(s)
Liked: 2902
Very cool.
JVC X9500 (RS620) | OZTS Majestic 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | Rotel RMB-1555B | DIY TPL-150 L/C/R | DIY MTM TPL-150 Surrounds | DIY Dolby Atmos Modules | DIY Quad 18" Subs 30cf
Shootout - JVC RS500 & Sony 320ES | My MadVR Settings
Javs is online now
post #3 of 22 Old 08-06-2017, 05:41 AM
Highjinx's Avatar
Quoted: 643 Post(s)
Liked: 275
Excellent idea, had a similar idea many a year ago.
Much simpler than yours though. A photo cell could be user calibrated/adjusted to set fade to black levels for ones particular setup. The cell facing the lens area.
The shutter was to have two horizontal V's that would close or open as required, but due to it's cross over action would act and appear more like an iris.
Good luck with this. Perhaps you could licence this to projector manufacturers. High time they incorporated full fade to black in lamp based projectors.
Dj Dee likes this.
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is offline
post #4 of 22 Old 08-06-2017, 06:11 AM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
This is not my creation , but something I have wanted for many years with digital projectors. But the effect is fantastic.. And now working on 3 more.
Highjinx likes this.
Dj Dee is offline
post #5 of 22 Old 08-06-2017, 05:51 PM
Highjinx's Avatar
Quoted: 643 Post(s)
Liked: 275
Cool! Does your contact intend to commercialize this?
Highjinx is offline
post #6 of 22 Old 08-07-2017, 07:07 AM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
We have to see, right now it has a high cost. But the result of it is extremely good. And the feeling of it is just like I want it in my cinema.
But I have always liked the total darkness when no info in picture.
Dj Dee is offline
post #7 of 22 Old 08-07-2017, 07:11 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Would be cool if he posted an instructable so we could build our own.. Looks like all off the shelf stuff in there..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #8 of 22 Old 08-07-2017, 10:15 AM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
I'm technical, but this was far over my understanding. Also some programming that would make this impossible for me to do.
Dj Dee is offline
post #9 of 22 Old 08-07-2017, 10:28 AM
zombie10k's Avatar
Quoted: 3874 Post(s)
Liked: 3954
ask your friend to send one over to the US for a viewing
this makes the most sense on a JVC with high native and the clamped iris on a FTB. It would likely be too noticeable on a lower native projector even with a good DI.
Can it handle UHD sources?
did you used to own a VW100 as well?
zombie10k is offline
post #10 of 22 Old 08-07-2017, 11:48 AM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
"ask your friend to send one over to the US for a viewing "
I cant promise that yet
You are right high on off is useful, because of the shock you get on low on/off projectors like DLP. But a good working iris will help some. Look strange from grey to completely black.
So far handle 4K UHD 4.2.2 BT2020 12 bit, like I have it now.
Full 4.4.4 12 bit is already fixed.
Yes I had Sony VW1000 and VW1100, but switched to a JVC RS600 and now RS520. Loved the Sony VW1100 but now its JVC
Dj Dee is offline
post #11 of 22 Old 08-07-2017, 12:07 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
looks like an Arduino in there.. piece of cake to program and of course he could just post the code in the instructable.. https://www.instructables.com/
Don't think it is all the "complicated" Just not sure how to monitor a digital video signal.. but the logic is loop, sleep fraction of millisecond, check pin, if level of pin x = y then run code to move stepper motor to closed position sleep and loop back to beginning, if pin x is no longer y, mv stepper motor open.. repeat forever Rather simple, but the devil is in the details!
Guessing he converts the signal to analog so as he can measure a voltage.. a quick google tells me 0% is 0 volts in analog.. So on the right there looks like HDMI to VGA/composite adapter with 2 wires going to the Arduino knock off, purple to an analog pin and red to ground if the pins are the same as the uno. Digital pin on the opposite side of the arduino is controlling the stepper.. Not sure what the other parts are with HDMI cables connected.. Maybe some processing so as to time the external iris with the internal video processing?
As to using this with Non JVC I think it would work fine with the planar. When I get a fast fade to back, takes a couple of seconds for the eyes to adjust ..
If he does not make this into a business, I would like to try building one if he is willing to share the design and code..
Doug
post #12 of 22 Old 08-07-2017, 12:11 PM
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 328
Are there mucj of a difference from the 600 going to the 520?
blee0120 is offline
post #13 of 22 Old 08-07-2017, 11:01 PM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
Had a heavy side by side before changing.
No microscopic difference. Why I picked the rs520, it had no bright corners.
Dj Dee is offline
post #14 of 22 Old 08-07-2017, 11:56 PM
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 328
Plus, its cheaper. My 520 has none as well.
Dj Dee likes this.
blee0120 is offline
post #15 of 22 Old 08-08-2017, 03:15 AM
D_B_0673's Avatar
Quoted: 101 Post(s)
I guess I don't understand fade to black.
How can that possibly work while watching a movie, it does not move fast enough.
dan
Dan
D_B_0673 is online now
post #16 of 22 Old 08-08-2017, 03:26 AM
Highjinx's Avatar
Quoted: 643 Post(s)
Liked: 275
dan
This can move almost as fast as a a dynamic iris does, but can block light 100% for those moments.
Highjinx is offline
post #17 of 22 Old 08-08-2017, 05:19 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
dan
It is not an external iris, just a lens cover for when there is zero content in the video signal, such as just before the credits roll or between commercials.
Not often that you hit 0% within a movie and if you do it will be a fade most likely. This would not move unless there was 0 visible content in the signal and then block the stray light that give you the slight gray glow. It's bang for the buck is very limited if the cost is high in my opinion.. however former CRT owners probably would disagree.
I still would like to build one just for the fun of it!
Dj Dee likes this.
Doug
post #18 of 22 Old 08-08-2017, 08:00 AM
D_B_0673's Avatar
Quoted: 101 Post(s)
Never had a DI yet, just assumed they worked really fast during a movie
dan
Dan
post #19 of 22 Old 08-08-2017, 10:07 AM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
Fade 2 black is the same as good night
Dj Dee is offline
post #20 of 22 Old 08-08-2017, 10:42 AM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
This was the beginning of this project, fun to see how extremely much better the product has become.
Dj Dee is offline
post #21 of 22 Old 08-08-2017, 10:56 AM
D_B_0673's Avatar
Quoted: 101 Post(s)
thanks
dan
Dj Dee likes this.
Dan
post #22 of 22 Old 08-15-2017, 11:00 AM - Thread Starter
Dj Dee's Avatar
Quoted: 212 Post(s)
Liked: 91
Final adjustments are going to be done tomorrow. Will be around 50% quicker shut and open, and some more small adjustments.
Dj Dee is offline
