Qubic Light's LED Projector Looks Good - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 05-10-2004, 01:06 PM
AnthonyP's Avatar
Rogo, you have to be at less then 1 screen width away
you can also put 1000 of those screens together to get a big screen
AnthonyP is offline
Old 05-10-2004, 04:18 PM
rogo's Avatar
Quoted: 1595 Post(s)
Liked: 1791
That would be a serious, serious pixel count... For all those looking for 4K x 2K, it'd offer that in spades. Of course, the "inter-screen screendoor" (i.e. the gap between those 2.3" panels) would be brutal.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
Old 05-11-2004, 07:34 AM
AnthonyP's Avatar
, I know we are talking more like 50-100 screens wide, and not a 4x4 or something like that Plasma wall. But how much border must be there (i.e. cannot get rid of it) right now it would be around 1" (half an inch per side)
Active Area (HxV) ------------------- 43.806 x 32.92 mm
External Dimensions (HxVxD) ---- 52.0 x 45.4x 1.72 mm
but I am sure with time that the border could be decreased a bit, especially if built to be "puzzle" pieces
on the other hand
http://www.kodak.com/US/en/corp/display/sanyoFlat.jhtml using 15" panels
if they have the same border limits, 100 of these panels in a 10X10 screen might not be bad
AnthonyP is offline
Old 05-11-2004, 07:40 AM
AnthonyP's Avatar
we can always call it the pane glass window effect
AnthonyP is offline
Old 05-11-2004, 02:38 PM
rogo's Avatar
Liked: 1791
On a semi-serious note, I do believe a tiled OLED array with zero borders will evventually be possible and that it is truly the path to mega displays with potentially giga-pixel resolution (certainly dozens of megapixels).
If you build it with joining connectors on the back of the substrate and can seal the OLED array with a <1 pixel seal (OLEDs need to block out air very carefully), it could be done because there doesn't need to be an inter-pixel grid that is fed from the display edge... The inherent panel is so thin, you can locate everything behind it.
rogo is offline
Old 05-11-2004, 10:18 PM
kelliot's Avatar
Many are claiming that OLED will be the way of the future, the main issue is the size of the panel that can be realized cost effectively in the short term.
Ken Elliott
kelliot is offline
Old 05-12-2004, 08:06 AM
AnthonyP's Avatar
I don't know if zero border would be possible, but I think if they bring it down to 1/8 of an inch (so that it is 1/4 of an inch in total it would not be too bad. An other idea (don't know if it would be possible) is to make the borders so that they overlap.
red=OLED
yellow= border of OLED#1,
blue= border of OLED#2
also since it is a light producer, there might be leakage at the borders so actual size might not be the same as perceived size (not sure of this)
AnthonyP is offline
Old 05-12-2004, 05:48 PM
rogo's Avatar
Liked: 1791
I think a zero border is possible. And without it, I don't believe the "tiled idea" has a chance of working.
The problem with LCD is that the panel needs to be sealed across a relatively thick area and also there is a need for there to be wiring along the edge of the display.
OLED displays are much, much thinner so the big seal isn't required. And OLEDs are emissive, not tranmissive (like TFT LCDs). So there is no reason the "edge pixel" needs any electronics beside it. It can be driven from the back solely. And the overall panel thinness allows for a "wiring layer" to sit behind the array of emitters without making the panel too thick overall.
Finally, with "printable OLEDs" being the grail that everyone in the industry is seeking to move toward, you are looking at an array on a flexible substrate that is theoretical printed like an ink-jet would make a photo. Unless there is something inherent I'm missing there, I don't see why you would need anything outside the "edge pixel".
Mark
rogo is offline
Old 05-12-2004, 11:19 PM
kelliot's Avatar
One issue with large OLED arrays may be refresh rate due to charging time. A large panel might have a considerable RC delay from wiring capacitance.
Ken Elliott
kelliot is offline
Old 05-13-2004, 09:30 AM
AnthonyP's Avatar
Mark, I agree with the holy grail. But there are many plasma walls today and those end up having much more then an inch in between them. I am also looking at it in shorter term. Obviously if you could print OLEDs on roll up screen then that is a totally different subject.
I think phase1 would be the equivalent of a plasma wall. You would buy 100 screens ( with each screen being a display in it's own rite) that will be in a box (not exposed circuitry) and then you bring them home place the cables on the wall to form a grid, then you install screen #1,1 and plug the cable in the back, put the second screen and attach #2,1 then you bring all those cables and attach them to a driver/scalar device. Obviously the one I described is the easiest to manufacture, but in theory the installer might not even need to use cables because it could be part of the screens casing (i.e. the two screens overlap where the connection happens (kind of click and connect) then electronics take care of the rest. If they are enclosed to begin with then the plastic must have some thickness and that will be shown in the display
Now when you get an OLED screen that can be rolled up, then yes, all the rest is moot, but until then I think I could be happy with an OLED screen that has a 1/4 or 1/8 of an inch line every couple of feet because moving an 8', for an example, screen that is rigid would be a pain.
AnthonyP is offline
Old 05-13-2004, 03:46 PM
rogo's Avatar
Liked: 1791
Right, now we are on a very similar page. Let's start building it ASAP.
rogo is offline
Old 05-13-2004, 10:08 PM
OLEDman's Avatar
A beautiful tiled OLED display was shown in May of last year by Sony at the Society for Information Display (SID) Conference. Here is the link to pictures of many of the OLEDs on display. The 20"D Sony was made of four smaller displays with a nearly invisible seam. It looked great.
However, the best OLED that I have seen is from Samsung SDI. The picture is #5 on the same page. 15.5" diagonal WXGA. Fantastic.
I will be at this years conference in Seattle at the end of the month and expect to see a lot more OLEDs on display.
OLEDman
OLEDman is offline
Old 05-13-2004, 10:09 PM
OLEDman's Avatar
OLEDman is offline
Old 05-13-2004, 10:37 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
What's "aperture ratio" ?
Peter M is online now
Old 05-14-2004, 12:06 AM
rogo's Avatar
Liked: 1791
Aperture ratio = fill factor = the percent of each pixel that is active / illuminated vs. the percentage that is inter-pixel "stuff". 33% is bad. But on emmissive displays, it might be tolerable, at least initally.
Mark
rogo is offline
Old 05-14-2004, 09:34 AM
AnthonyP's Avatar
I guess this is the Sony that you are talking about
we are actually talking displays that can be hooked together, and not OLED panels that are hooked together in one device (i.e. if that screen was 6'-10' wide it would be impossible to move)
does anyone know what this is all about?
this is cool
AnthonyP is offline
Old 05-14-2004, 10:13 AM
dcottle's Avatar
AnthonyP
The Japanese term in the middle picture (kagami) means mirror.
Does that explain it better?
Dave
dcottle is offline
Old 05-14-2004, 10:20 AM
Davandron's Avatar
Anthnony & Dcottle
They are showing a display which emmits on BOTH sides. This has to do with cell phones, where they are working towards double sided displays to reduce costs.
Davandron is offline
Old 05-14-2004, 11:29 AM
rogo's Avatar
Liked: 1791
The inherent OLED panels are a fraction the thickness of LCD. In fact, some of the prototype monitors have been thinner than the top of a laptop lid, even at 15" or so.
rogo is offline
Old 05-14-2004, 12:32 PM
Davandron's Avatar
Found a GREAT application note on pulsed operation vs continuous operation of LEDs
http://www.stockeryale.com/i/leds/lit/app001.htm
Also I've been continuing to update the Advantages post, those interested might want to check it out. I've got a quick link in my signature.
Old 05-14-2004, 01:38 PM
AnthonyP's Avatar
dcottle- Davandron thanks, that did help, I did not realize the smaller picture was the reflection (almost looked like the smaller pic was producing the larger one.
Davandron: cannot see how that would work (except for icons or if the screen gets flipped L/R when open ) if there is writing that is readable from the front it will be written the wrong way on the back.
AnthonyP is offline
Old 05-14-2004, 02:10 PM
rogo's Avatar
Liked: 1791
The screen gets flipped when it's opened. It's not perfect, of course, but given the way cell phones are used, it's kind of brilliant. Not only will it save several dollars per phone, it will save several millimeters in thickness and also several milliamp hours in battery use.
rogo is offline
Old 05-14-2004, 02:35 PM
Davandron's Avatar
Anthnony,
Trust me on it, what they are planning works. ;^)
It's for the flip phones that currently have two displays. When its closed you see the outside display, when open the inside display. They want to make it one display that you can see from both sides and then they will mirror and flip the text/images based on whether its open or closed.
Guess its easier to understand if you can hold one...
Old 05-14-2004, 02:53 PM
Davandron's Avatar
More than one way to skin a cat
There is something I've been trying to figure out how to add to the Advantages post, that could be understood by most people why LEDs are an advantage. I'm going to try it here and hopefully work it out before it goes into the other post. If you all understand it then maybe you can help me rephrase it appropriately.
In all systems, the goal is to control the energy reaching the screen at one point relative to another point on the screen. But the energy levels must be more varied than simply full on vs full off. This could be called an analog function; a system that contains significantly more than two states.
But a digital system only knows two states, so for a digital system to produce an analog output it takes advantage of averaging over time and is called Pulse Width Modulation.
So a Full On for 1/9th of the time, then Full Off for the remaining 8/9ths of the time would average out to 11% of Full On (a mostly Off system).
A system like I just described could have 10 analog states (0%, 11%, 22%,... up to 100%) and makes use of a single variable.
LED projectors would have TWO variables to control the amount of energy reaching the screen; they can modulate the mirror and they can modulate the LIGHT iteself!
Why is this a big deal? Well, when combined it allows for some strange timing conbinations.
Lets go back to our 1/9th example and add something else; lets say that during the 1/9th we have the light at 50% intensity and then during the other 8/9ths we have it at Full Off (0% intensity). Our average is 5.5%, not 11%
So if we wanted 11%, how would we do that? There are now two methods:
1.) 1/9th Full On, 8/9ths Full Off
2.) 2/9ths 50% On, 7/9ths Full Off
Lets apply this concept to the 8-bit red channel of a projector. Normally, to display the very dim color of 1/255 red, we would need to flip the mirror on for (1/30 of a second) x (1/3 of that time for red) x (1/255) = ~43.6 microseconds (or uS) of 100% light.
This means that our system has be be able to flip the mirror on and then off again in 44uS to display that 1/255 shade of red (the 1/255 is also called the Least Significant Bit, or LSB, time)
But with the LED, we can use approach number two from above! We know that by halving the Light during the LSB, we are able to double its duration and still get the same amount of energy... with one small kink; since we don't gain any time, we have to make up for that doubled LSB by increasing the length of the system:
(50% light) x (1/30) x (1/3) x (2/256) = 86.8 uS of 50% light (equal to 43.4 uS of 100% light)
Ah-ha! will yell the critics, you've got less energy and now your system isn't accurate! Well, not entirely...
To increase the duration of the LSB I redivided the rest of the time, and this creates a shift. The next bit would be 2/256 at 100% instead of 2/255, then 4/256 at 100% instead of 4/255, and so on until you got to the MSB of 128/256 instead of 128/255
What this means is that Full On (255/255) becomes 255/256 of the maximum energy possible in 256 of 256 periods... but the light is never off in all of that time... we lose 1/256th of the maximum energy possible in that doubled-LSB, because theoretically we could have had 100% instead 50%. But the system runs at our 100% light level definition.
The linearity problem's root is that we were at first saying 1/255th of the energy but then applied that to a 1/256th system (the LSB+1 was 2/256)
To solve the linearity problem on the LSB, the light source is run at 50.195% or (1/255) / (2/256)
OK so I'm trying to point out that there are now two variables and that allows for either relaxed timing or enhancing grayscaling... should I just talk about dynamic range instead? Its difficult for me to teach because the concept is so new to me....
Old 05-14-2004, 02:56 PM
AnthonyP's Avatar
I understand, all I said is that it would need to flip the info depending on if the phone is closed or open assuming that when it is closed you are reading the outside and when open the inside.
AnthonyP is offline
Old 05-14-2004, 05:38 PM
OLEDman's Avatar
To answer Andrikos, OLEDs can be very thin. The organic layers are on the order of 100nm. What accounts for the bulk of the thickness is the glass (or plastic) substrate and the glass or metal encapsulant. OLEDs must be hermetically sealed, so they are typically fit with a metal or glass cap.
As far as the mechanical durability of the OLED, it is entirely dependent upon the substrate and the encapulating layer. The OLED layers are extremely delicate.
OLEDman
OLEDman is offline
Old 05-15-2004, 09:31 AM
OLEDman's Avatar
Contrast ratios are very good, >1000:1. Peak brightness can be exceptionally high, but running an OLED at high brightness is currently an issue across the industry. For this and other reason,s I don't imagine OLEDs will be appearing in RP or FP applications anytime soon (unfortunate for readers of this forum). They are really ideal for high definition video because of the very short response time (unlike LCDs), their excellent color gamut, and their wide viewing angle.
Aperture ratio isn't as big deal in emissive displays as it is for transmissive displays. For OLEDs, it determines how hard a pixel has to be driven to achieve an overall display brightness. Today's OLEDs have limited aperture ratios because the emission occurs through the transistor layers on the substrate. The pixel circuitry takes up a portion of the display real estate. This does not scale with display size, so it could be a problem for small, high resolution devices.
Tomorrow's OLEDs are more like LCOS chips. They emit upward, away from the substrate, so apertures can approach 100%.
OLEDman
OLEDman is offline
Old 05-15-2004, 01:54 PM
AnthonyP's Avatar
Can you poke the screen with your finger or a pen?
yes, have you seen the Chameleon remote?
AnthonyP is offline
Old 05-17-2004, 06:40 AM
Huckster's Avatar
Is this on/off or ANSI? If ANSI, this is breakthrough. If on/off, this is troubling.
This technology emits light, right? It should have an extremely high on/off CR (like CRTs) since it shouldn't emit anything when showing black.
Huck
Huckster is offline
Old 06-16-2004, 09:11 AM - Thread Starter
vsv
vsv's Avatar
vsv is offline
