Dead pixels and DLP? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-13-2004, 12:56 PM - Thread Starter
savagez3's Avatar
I know that LCD projectors suffer for dead and stuck pixels, which is one of my reasons for avoiding that technology.
Has anyone had a problem with dead pixels on a DLP projector? It was my understanding that DLP did not suffer from dead pixels in the same way that LCD does, but is that the case? What is the replacement policy on dead pixels in a DLP projector?
savagez3 is offline
post #2 of 13 Old 01-13-2004, 01:02 PM
new teq joe's Avatar
dlp dose not have dead pixels the problem with dlp is rain bow affects because they use a color wheel and as i under stand it the faster the wheel the less the rain bow effects
new teq joe is offline
post #3 of 13 Old 01-13-2004, 01:04 PM
Andrikos's Avatar
sz3,
look for manufacturers that offer a zero defect pixel policy.
I know inforcus is one of them.
If you get a dead pixel, they'll replece it for you.
Next projector will have LEDs, >=1080 res, >=10 bit color, >14bit CR, >9 bit ANSI CR, >=120Hz, >16ft.L on 12ft 2.35:1 screen, <$12bit price
My 1st line array design
My ongoing Line Array Design
Andrikos is offline
post #4 of 13 Old 01-13-2004, 01:19 PM - Thread Starter
savagez3's Avatar
Many thanks, I will look into that. I wonder if BENQ has a good policy - anyone know?
savagez3 is offline
post #5 of 13 Old 01-13-2004, 01:34 PM
Carl Brinkman's Avatar
DLP absolutly does have dead pixels, just way fewer than we see on LCD and LCOS projectors.
The majority of manufacturers specifically exclude dead pixels from their warranty but some like Marantz have been known to replace them on occasions anyway. Only InFocus and Runco will guarantee to replace if you have a dead pixel to my knowledge.
Check out the specific manufacturer closely. Some do have unwritten policies depending on how many dead pixels and the location but call the manufacturer directly to find out. Don't just take a dealers word for it unless they will put it in writing.
Carl Brinkman is offline
post #6 of 13 Old 01-13-2004, 01:50 PM
Darrel Johansen's Avatar
I have no dead pixels on my SharpVision 12K and had none on my previous SE-13HD.
Of course, the odds of getting a dead pixel might be greater on an LCD because there are three panels instead of one.
Darrel Johansen is offline
post #7 of 13 Old 02-09-2004, 11:09 AM
astrojeff's Avatar
I have 2 dead pixels on my Sharp 12K. I am going to contact Sharp to see if they will do anything about it.
Jeff
astrojeff is offline
post #8 of 13 Old 02-09-2004, 12:56 PM
derekjsmith's Avatar
Liked: 116
I have a lazy pixel on my Sharp 10k. After about 3 hours of use, I have a single pixel that won't always switch to ON in bright scenes. If I shut the PJ off and restart it the lazy pixel is OK for another few hours. :confused: This started showing up after about 500 hours. I know these mirrors switch using static electricity so it may be that the static just builds up to a point where it does not work and by restarting the PJ it dissipates the static.
Derek
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #9 of 13 Old 02-09-2004, 01:55 PM
freychris42424's Avatar
I got a dead pixal on my X1 a while ago, and on a 800 x 600 pj they are very annoying, but luckly now I have XGA. I've heard that only 1 out of 10 sanyo Z2 have zero dead pixals.
Chris
freychris42424 is offline
post #10 of 13 Old 02-09-2004, 03:12 PM
Art Sonneborn's Avatar
Quoted: 238 Post(s)
Liked: 295
Do dead pixels occur at triple the rate in LCOS compared to LCD? I've not seen a thread on LCOS dead pixels.
Art
My HT
iRule rules my theater
Art Sonneborn is online now
post #11 of 13 Old 02-10-2004, 03:17 AM
Orangelo's Avatar
I got a dead pixel on my Yamaha DPX-1000 and had the unit exchanged. The seller run a specific guarantee on dead pixels.
BenQ has a specific policy on dead pixels dor their DLPs, something like 1 black / 0 white, if I remeber correctly.
Orangelo is offline
post #12 of 13 Old 02-10-2004, 06:25 AM
Ericbres's Avatar
Here is a quote from BenQ Technical Support (for the 8700 anyway):
Dead Pixel Requirements: PE8700
Dark Pixel - 0 dark pixels allowed in Zone A(Middle portion of the image)
<= 2 dark pixels allowed in Zone B(Surrounding portion)
No Adjacent Dark Pixels
Light Pixel - No Light Pixels Visible.
Ericbres is offline
post #13 of 13 Old 02-10-2004, 10:27 AM
Huey's Avatar
I've got 2 dead pixels on the masked edge of my NEC LT150 XGA DLP (one on and one off right next to each other). I never turned it it as 1) it's masked at the far edge so you can't see it 2) I don't like abusing return policy for minor issues especially when you can inherit new problems (dust, shipping damage, etc.) as well as missing your PJ for 2-4 weeks. Blasting air on the DMD panel, running static/snow signal, and 2 years later they remain. So yes, DLP can get dead or stuck mirrors although 1/3 as rare as LCD due to single panel. It's also less of a problem than LCD technology.
Huey ;-]
Huey is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
