Optoma H77 Review & Screenshots - Page 127 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 06-06-2009, 06:22 AM
Quoted: 3255 Post(s)
Liked: 2743
I just bought a new Orsam bulb on ebay from purelandsupply and it is identical to the Phillips down to the font used on the serial number of the glass reflector housing. Search optoma H79 bulb and it should pop up. I've only used the bulb two nights but it works fine. You do need to install it in the housing but that really isn't that hard just remember how everything comes apart and put it back the same way. I had my bulb in less than 24 hours from time of ordering via UPS.
doctorG4 likes this.
Old 06-06-2009, 07:21 AM
gvera's Avatar
Thanks for your comments, I had some doubts with the Osram but now I'm going for it!!!
gvera is offline
Old 06-10-2009, 10:36 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
So we are now getting cheap 250watt lamps? Sounds great to me cause the H78/79 I have is the best thing I got. The H77/78/79 is a top notch HD design from Optoma. One of the best they ever made and they made some great projectors. I had the HD8200 1080p Dynamic black PJ in my home for a test. That one is grrrrreat!
Next up Lasers and LEDs. Till later
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
Old 07-05-2009, 04:43 AM
simonbran's Avatar
I have been following this thread as my H79 bulb was getting so dim we could barely see the films. I too have just ordered the bulb from Pureland (via Ebay). It was easy to fit and my projector is transformed! I live in the UK and it is impossible to buy just the bulb from local suppliers here. (I didnt get it shipped to the UK as I have friends in the US but they do offer an international service.)
simonbran is offline
Old 07-20-2009, 03:22 AM
feyris's Avatar
About the fan/temp issue:
I bought a temp sensor that I put in the bulb room. (just behind the bulb)
Without any extra fan, I have 98°C, I added a low rpm silent 120mm fan, the temperature is now 82°C .
I hope it will help to longer the bulb life
feyris is offline
Old 07-20-2009, 10:34 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3038 Post(s)
Liked: 2969
That's a good tip. Other than the bulb dimming problem, these were good projectors that throw a nice 720p picture. Between adding a fan and cheap E Bay replacement bulbs owners should be able to get more life out of their machines.
May LED make bulb dimming a thing of the past...............
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
Old 12-18-2009, 08:37 AM
icm2006's Avatar
Anyone looking for H-77, 78, 79 lamp modules with new bulbs or and entire upgraded
H-77 contact via PM. Thanks
icm2006 is offline
Old 04-22-2016, 10:35 AM
lewke's Avatar
Quoted: 24 Post(s)
Anyone still currently using one of these?
My H77 color wheel just shattered, anyone need it for spare parts?
lewke is offline
