Happy H79/H78dc3 owners thread - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1381 of 1401 Old 08-25-2010, 04:32 PM
Alex Balkan's Avatar
Hi -
I realize this thread has been dormant for a while, but hopefully some of you H79 owners are still out there.
I have an H79 which I would finally like to have professionally calibrated. I have an OPPO 980H (latest firmware) and a DirecTv HD DVR connected into an OPPO HDMI switch from which I have a cable going into the DVI input. That's the only input I'm using.
I see a number of old posts about the H79 losing calibration settings by defaulting from one setting to another. I realize it has something to do with PC-level RGB v. Video-level RGB, and some posters solved the problem with a Lumagen. I called OPPO to ask about this, and the rep said the OPPO's defaul is video-level (changeable via the Color Space Menu). He also said that he knew that with the H78 at least, some of the inputs were mislabeled, and perhaps that was part of the issue.
I don't fully understand the issue, but basically, I want to know whether I will be able to have the projector calibrated in a way that will "stick" without losing the settings and without having to purchase an expensive new piece of equipment. With all the accumulated experience on this issue, is there now a "best practice" I can tell the calibrator to follow to make sure this works out?
Many thanks in advance.
Alex Balkan is offline
post #1382 of 1401 Old 08-25-2010, 06:12 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Aside from the Video/PC level (bug IMO), the H7x's suck at resyncing. The Lumagen (HDP or above) in the chain makes it so the signal to the PJ is always constant. Same resolution (natiev 720p) same sync rate, etc. So the Lumagen "absorbs" all the electronic drama from varying soruces. And, unlike the Optoma, it does it instantly. Saw one for sale here recently, cheap. Can't recommend it enough for this PJ.
GetGray is offline
post #1383 of 1401 Old 08-26-2010, 08:02 PM - Thread Starter
guitarman's Avatar
Quoted: 14 Post(s)
Originally Posted by Alex Balkan View Post
Hi -
It never blanked out the RGB settings. You just have to settle on whether you use video brightness level or PC brightness level. Video is just hitting the DVI button on the remote, PC is after hitting DVI you hit resync on the remote. I would just tune up my basic blaces/whites, colors with Avia or DVE in video level brightness the straight DVI button on the remote.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #1384 of 1401 Old 08-27-2010, 05:21 AM
Quoted: 3897 Post(s)
Liked: 3331
If you are the original owner of this projector and bought a bulb in the first 36 months you may be eligible for reimbursement:
http://www.projectorsettlement.com/
Now if I could just get reimbursement for the other four I bought.
post #1385 of 1401 Old 01-19-2011, 02:36 PM
orion456's Avatar
Did anyone take advantage of the lamp lawsuit and actually get a new lamp?
Does this result mean that the lamps were at fault or the projector?
orion456 is offline
post #1386 of 1401 Old 01-19-2011, 04:00 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4127 Post(s)
Liked: 4216
No. I got a new projector instead............
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #1387 of 1401 Old 01-24-2011, 07:07 AM
Liked: 3331
The due date has expired for submission of claims. You needed to submit a copy of proof of purchase of both the projector and the replacement lamp. The replacement had to have been during the first 3 years of ownership.
I received a compensation check for $399 last week. It brings a smile to my face until I realize that today you can buy a sub $999 projector that performs as well as the Optoma H79 which sold street (AVS) +$6000 in the initial release.
post #1388 of 1401 Old 01-24-2011, 01:50 PM
orion456's Avatar
The submission due date has expired for submission of claims. You needed to submit a copy of proof of purchase of both the projector and the replacement lamp. The replacement had to have been during the first 3 years of ownership.
It's good you got something back, and almost 1/2 the price of a new projector, not bad -
Was the basis of the lawsuit that the H79 was defective or the lamps supplied were defective?
orion456 is offline
post #1389 of 1401 Old 01-24-2011, 08:56 PM
Liked: 3331
From memory the estimated bulb life in the marketing blurb was 3000 hours. There was an AVSforum survey of the actual experiences and only a few owners got the bulb to go past 1000 hours. Personally 750 was about my limit based on the 5 bulbs I went through while I had the projector in use.
My "feeling" was that the projector pushed the bulb to it's limits. They pumped up the most brightness they could get and kept the fans quiet which meant that it ran hot. There was a thread with an add-on fan modification which a number of guys tried.
The actual Phillips bulb was used in other projectors not just the Optoma H77, 78 and 79 series.
post #1390 of 1401 Old 04-22-2016, 09:33 AM
lewke's Avatar
Quoted: 45 Post(s)
Liked: 25
Anyone still currently using one of these?
My H77 color wheel just shattered, anyone need it for spare parts?
lewke is offline
post #1391 of 1401 Old 05-09-2016, 11:41 AM
lewke's Avatar
Quoted: 45 Post(s)
Liked: 25
I guess I'll unload this next electronic recycling day
lewke is offline
post #1392 of 1401 Old 05-09-2016, 12:44 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4216
Wow - you got some time out of this projector.
post #1393 of 1401 Old 05-09-2016, 01:45 PM
lewke's Avatar
Quoted: 45 Post(s)
Liked: 25
Yeah, being in our vacation home it only saw about 100 hours of usage a year. That said it will be replaced with another projector that we've gotten some good time out of, a Epson HC1080 that I finally replaced at home with a refurbished Epson 5020ub.
lewke is offline
post #1394 of 1401 Old 05-10-2016, 04:06 AM
Monkey_Man's Avatar
Quoted: 93 Post(s)
Liked: 51
Lol, I still use mine once a year at Halloween for my halowindow display http://www.hallowindow.com/ http://atmosfx.com/ Works like a charm. To think it used to be the jewel of my HT.
Monkey_Man is offline
post #1395 of 1401 Old 02-07-2017, 11:57 AM
orion456's Avatar
Just an update.
I still have my two H79s with new lamps working fine (knock on wood). One has about 1500 hours the other 800 and the color and brightness are fine. The fan I put on the outlet is working very well and keeps the whole system a lot cooler than without the fan.
orion456 is offline
post #1396 of 1401 Old 02-07-2017, 05:02 PM
Monkey_Man's Avatar
Quoted: 93 Post(s)
Liked: 51
Originally Posted by orion456 View Post
Just an update.
I spoke too soon. Fired mine up for the Halloween display "clunk, clunk, clunk" then the color wheel exploded. Grrrr
post #1397 of 1401 Old 02-13-2017, 02:30 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4216
Just an update.
I'm surprised you have gotten that many hours out of the lamps. Mine always dimmed too much by 1000 hours, if that !
post #1398 of 1401 Old 02-14-2017, 08:35 AM
orion456's Avatar
The lamps are new, but they only cost $50 now so its not a problem. One projector is only showing on a 60" screen so there is plenty bright for that one. The other is 100" screen and in the dark it still produces a nice image. Knock on wood they survive a while longer.
orion456 is offline
post #1399 of 1401 Old 07-21-2017, 08:39 PM
Monkey_Man's Avatar
Quoted: 93 Post(s)
Liked: 51
I couldn't give up on my trusty hallowindow H78 projector. So I picked up a H79 off eBay for parts and my H78 is back up and running with a new bulb and now the fan mod to boot. Feels like 2005 all over again.
Craig Peer likes this.
post #1400 of 1401 Old 08-11-2017, 09:30 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4216
Amazing it's still chugging long. I'm on my 6th projector since I had my H78.
post #1401 of 1401 Old 08-11-2017, 12:39 PM
fleaman's Avatar
Quoted: 77 Post(s)
Liked: 121
That's some love you got there
720p PJ in a 4k world!
I remember lusting for the H79/H78 back when I had my Optoma H30 and H31.
I then moved on to a 1080p Mits HC3800 and recently (about 6 months ago) a used JVC RS57/X700.
You can get a used JVC X500 (RS49, RS4910) for about $2k or less and I've seen RS46/X35's go for about $700-$1200!
I got lucking with my low hr RS57/X700 for $2k and it came with an extra new sealed in box OEM lamp. Yet the original lamp in the PJ only had 500 hrs on it. Runs super silent too. Way better lens, etc.
The blacks....oh the blacks......the Dark Force is calling you Luke.....
fleaman is offline
