My Ruby test at home - Page 16 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #451 of 487 Old 12-18-2005, 08:50 PM
Alan Gouger's Avatar
Quoted: 47 Post(s)
Liked: 83
Originally Posted by ColorChange
Simply put, the auto iris usually gains in dark level detail and loses in brightness detail. If the film was shot with little near 100IRE you probably won't notice.
The Lumagen scaler has a 11 point gamma/grey scale adjustment. You could individually go into the 90 & or 100ire and tame it down a little. I wonder if that would help.
Alan Gouger is offline
post #452 of 487 Old 12-18-2005, 08:54 PM
Iamjcl's Avatar
Quoted: 145 Post(s)
Liked: 32
Greg,
Yeah, I guess you summed it up pretty well - I should have re-read the review. But I guess we've been batting around the term "compression" and I think I would call it "blown whites". I do understand that its squeezing some detail that is in the signal closer together, so in theory anyway, it should look better than blown out whites, but that is the effect I see. You are right - there is a choice between modes, but the potential is clearly there to mitigate the issue in the "auto" mode. Its a killer PJ despite my bringing this up.
- Chris
Iamjcl is offline
post #453 of 487 Old 12-19-2005, 10:05 AM
NIN74's Avatar
Originally Posted by CKL
By the way, HS60's dynamic iris doesn't have the problem of white level compression. I don't know why Sony apply different DI operation at both new release projector.
Intreresting. How would you rate the ruby vs HS60 then?
Sound and video is not magic, it is pure physics. Physics that can be magical
NIN74 is offline
post #454 of 487 Old 12-19-2005, 12:23 PM
HoustonHoyaFan's Avatar
The HS51 does have "brightness compression". This was pointed out in Bill Cushman's excellent WSR review over a year ago. I never became the same kind of issue as with the Ruby. I don't recall any HS51 owner doing A/B and obsessing over it.
I looked at the HS51 for the Star Wars "brightness compression' scene gregr referenced in his Ruby article. There was clearly some loss of details in the Rocket nozzle using IRIS-AUTO, during an A/B. The positive benefits are so obvious that an inocucous slight less loss of bright level detail is trivial price to pay.
For me the "brightness compression" issue is similar to DLP's low level dithering issue. Technically a real issue, in the real world movie watching, much ado about nothing!
HoustonHoyaFan is offline
post #455 of 487 Old 12-22-2005, 11:01 PM
glenned's Avatar
[quote=ChrisWiggles]yeah noah:
Yes, one reads that, however for digital projection it is largely B.S.
It is true for film projection where light is projected through film and onto a screen. The film provides the color for the image. An accurate and complete spectral range in the light source is essential for the colors to be full spectrum and accurate in the image on the screen.
Digital projection creates a color response in the human eye/brain by an entirely different mechanism. Digital projection (as with CRT TVs and other types of video displays) only diplays three colors directly on the screen: Red, Green, and Blue.
All the those other colors you see are your brain's interpretation of different combinations of just those three colors. You could just as well use three monochromatic lasers, one each for R,G,B to do the same thing. You can't get any further away from full spectrum light than that!
That's not correct at all.
QUOTE]
O.K, Chris. What part of the above do you think is in error?
Glenn
glenned is offline
post #456 of 487 Old 12-22-2005, 11:11 PM
glenned's Avatar
Originally Posted by scaesare
Glenn-
Any direct experience as to if Xenon bulb wear more "evenly" across the spectrum as compared to other bulb chemistries?
Sorry, I don't, but I think that William P. answered this earlier in the thread.
Glenn
glenned is offline
post #457 of 487 Old 12-23-2005, 12:28 AM
glenned's Avatar
Originally Posted by noah katz
Glenn,
Aren't primaries monochromatic, i.e., points in the CIE color space?
So you're saying a point in that space can be represented by various combinations of multiple other colors?
The standard primaries are defined as single points in color space. They are not defined as single wavelenths of light.
Our whole video system is patterned after the function of the human eye/brain. The eye has three types of color sensors (three types of cones). One type of cone is most sensitive to Red light, one to Green, and the last to Blue light.
When light falls upon the cones, each cone is stimulated in particular way. This stimulation pattern is interpreted by the brain as color.
The points in CIE color space represent specific stimulation patterns (which is just another way of saying that they represent specific colors).
Any particular stimulation pattern can be created by a variety of different light wavelenth combinations. That is why three lasers (R,G, and B) can be used to create the same stimulation patterns in the eye as xenon light that has been filtered into R,G, and B. The lasers in combination will be comprised of just three wavelengths of light. The filtered xenon light in combination might be comprised of 400 wavelengths of light. Yet, they can both ellicit the same stimulation patterns in the eye, though through very different spectral signatures. When this happens, you can't see any color difference.
The CIE has defined the exact points in color space for the R,G,B primaries. If a display has accurate primaries, it will make accurate color provided that all the other ingredients (color decoding, gamma tables, etc) are executed properly.
Glenn
glenned is offline
post #458 of 487 Old 12-23-2005, 01:00 AM
CKL
CKL's Avatar
Taking the moving white bar at AVIA as an example, Ruby makes it be less visible while HS51 and HS60 don't show the same situation. I didn't compare all the scenes mentioned by Greg in WSR. I'm not aware HS51 and HS60 has the same degree of brightness compression.
CKL is offline
post #459 of 487 Old 12-23-2005, 01:14 AM
CKL
CKL's Avatar
Originally Posted by gregr
Can you be more specific about what you mean by slightly different x-y coordinates? I'm trying to find out if they have changed the Real Color Processing function. The difference in the red primary coordinates for Wide and Normal in the pre-prod unit was effectively zero. The red primary needs to be moved by about 0.043 for x.
Sorry I didn't write down the exact coordinates of three primary colors. But comparing both CIE charts, Wide colorspace shifts the green to the right hand side a little bit while Normal colorspace shows the green on the exact point of NTSC standard. Wide colorspace has similar red as Normal colorspace which is located slight below the NTSC standard. For the blue, Wide colorspace shifts it to just above the 0.1-y gridline while Normal colorspace is just below the 0.1-y gridline.
CKL is offline
post #460 of 487 Old 12-23-2005, 08:09 AM
wm
wm's Avatar
Location: Spaceship Earth, usually on the California deck
Wouldn't this be the broadcast industry? REC-709, etc. Not a CIE function. :)
wm_avs6 (at) meier-phelps (dot) com (Note - new address! Please do not use AVS PM)
Optimized by William PhelpsÂ
wm is offline
post #461 of 487 Old 12-23-2005, 09:55 AM
glenned's Avatar
Yes, thanks for the correction.
Glenn
glenned is offline
post #462 of 487 Old 12-24-2005, 01:07 AM
thomasclaus's Avatar
CKL,
I found that the Normal and Wide color space showed slightly different x-y corrodinates at the CIE chart where Normal was closer to NTSC standard.
I did not find this. However, I am glad that someone put this up, because I am a little confused about the "Wide" mode compared to the "Normal" mode. I expected the Wide mode representing a HDTV colorspace and normal mode respresenting something near NTSC etc.
The manual says something cryptic like "natural colors" (wide) vs. "Hi-Vision" colors (normal).
When I measured both modes I did not find any (!) difference in the x,y coordinates of the primaries and secondaries (slight variations begin at the 3rd decimal place or so).
VW-100 was fed via HDMI. Maybe this feature does only affect other inputs and/or signals?
In order to correct the oversaturated colors I had to fiddle with the RCP feature and with the global saturation controls. I can post some charts of the different modes and the results after RCP+saturation, if needed.
Thomas
The saw is family
thomasclaus is offline
post #463 of 487 Old 12-24-2005, 02:17 AM
CKL
CKL's Avatar
My measurement is carried out via HDMI input. What tools are you using to measure the primary colors?
To correct the oversaturated colors, the item of Color adjustment can't solve the problem?
CKL is offline
post #464 of 487 Old 12-24-2005, 03:03 AM
gregr's Avatar
Quoted: 20 Post(s)
Thomas,
I measured no CIE x,y differences for the primary colors (to 3 digits), and only a difference in the yellow complementary color, when switching from Wide to Normal. The major difference in switching from Wide to Normal was a reduction in the brightness of the primaries, but not the x,y values. In addition, I was only able to make very small changes to the x,y values of the primaries using the RCP function. I was able to make larger changes to the complementary colors. I duplicated these results with 3 different measuring devices.
Is that also what you measured?
CKL - The primaries lie well outside the Rec 709 and Rec 601 standards.
Greg Rogers
Video Engineer/Product Designer
gregr is offline
post #465 of 487 Old 12-24-2005, 05:16 AM
Greg,
This is exactly what I experienced.
Yup, this is true especially for Green. However, in conjunction with the saturation control I was able to correct all primaries and secondaries.
All measurements were taken with a Gretag Eye-One.
Here´s comparison factory-vs.-my-trials-charts. factory default: "Cinema" mode, colortemperature "mid".
Thomas
The saw is family
post #466 of 487 Old 12-24-2005, 05:32 AM
lovingdvd's Avatar
Quoted: 2860 Post(s)
Liked: 608
Greg,
Thomas
Thomas - thanks for posting those charts. Great job on this - it looks nearly perfect.
Can you please post more specific details on how you used which controls to achieve this?
Also - I have a EyeOne and never had much luck getting it to give good CIE measurements with my Sharp 10K. So hearing you were able to achieve this with the EyeOne is very encouraging. Perhaps the difference is that the Ruby is much brighter than the 10K which may make the readings from the EyeOne more reliable under that circumstance?
lovingdvd is offline
post #467 of 487 Old 12-24-2005, 06:20 AM
lovingdvd,
unfortunately I am a bit in a kind of hurry, because of some christmas preparations for my son, family things etc., so I will not be able to look into the specific numbers in the projector today.
First of all I set the whitepoint to D65 by changing the gain values for R,G,B. In order to move the green (and also red) primary significantly I had to reduce the overall saturation ("Color"). This shifted all primaries and secondaries into the right direction - as a beginning.
Next, I chose "Green" (RCP: Color select), I left position and range unchanged in order to make sure (respectively: I hoped...) that the whole spectrum "around " the selected color is changed.
The "RCP Color" control sort of affects the distance of the selected primary from the whitepoint. In the case of green I ended up at a value of -46 or so.
The "RCP hue" control sort of rotates the selected primary around the whitepoint, so one can shift e.g. green towards yellow or towards cyan as desired.
Please take notice that I say "sort of" in both cases, because these controls do not act perfectly the way I would have expected them to do.
Having changed all the primaries I did the same thing with the secondaries.
In the end it worked somehow, although one loses a lot of luminance by correcting the Gamut. For example I measured around 10 ftl. for the green primary at its factory setting (wide mode). After my changes I ended up at around 8,5 ftl. for green.
On the other hand one can compensate this, because I found quite a lot of headroom in the gain-controls until green and blue limited it (almost simultaneous).
Factory settings (cinema, mid, auto-iris); 78,74 inch wide screen; 1,0 gain; 15 foot throw distance resulted in 14,9 ftl. at 100 IRE full white.
Measurement after RCP color correction, D65 whitepoint, RGB-level correction resulted in 20,2 ftl. at 100 IRE full white.
All this is just some very rough and very early trials with the Ruby without looking into the factory-mode or so. I wished that someone will get a documentation about the factory-mode someday...
Thomas
The saw is family
post #468 of 487 Old 12-24-2005, 07:35 AM
darinp2's Avatar
Quoted: 1135 Post(s)
Liked: 1766
Thanks for the info Thomas. Unfortunately, I think some of those controls are gone for 1080p48 input into the DVI as it seems to be treated as a computer signal.
I read the review, but didn't recall if there was a recommendation for which mode to use in there. After getting the Ruby one of the first things I did was set it to Normal, but it sounds like Wide might be the better choice in general. Do I have that right?
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #469 of 487 Old 12-24-2005, 11:40 AM
darinp2,
you are right: saturation control is gone when feeding the Ruby with DVI. However, wouldn´it be possible to reduce saturation at the external scaler or HTPC and input the already less saturated signal into the Ruby? RCP is still available when using DVI.
Thomas
The saw is family
post #470 of 487 Old 01-11-2006, 08:47 PM
mariner888's Avatar
Hi Darin,
Greetings and thanks for sharing your success feeding 1080p 48Hz signal to a RUBY using DVI. I am thinking of setting up a simple PC-DVI-RUBY system for movie playback, and would be most grateful if you could help me out with some outstanding questions.
1. I assume you have also run the RUBY at 50 and 60 Hz refresh rate and the RUBY had no problem accepting all three. Were you able to get Sony to confirm this?
2. Were you able to detect any sign of judder when using different refresh rates, perhaps using the Judder Test software written by another forum member Arca? This is to confirm that no frame rate conversion is involved.
3. Did you use Powerstrip for refresh rate adjustment, and if so would you be kind to share the timing used? Was it just a simple matter of changing pixel clock, or did you have to fiddle with the porches as well?
4. Was the OSD able to display precise horizontal and vertical frequencies of the input signal?
5. Any means for black level calibration, or video level selection between 16-235/0-255 to match with the VMR/Overlay output of the graphics card?
Thanks agains and best regards.
mariner888 is offline
post #471 of 487 Old 01-12-2006, 01:08 AM
precsmo's Avatar
hi, am new here, and thanks for the useful review on the sony ruby. can someone kindly advice if this projector is suitable for my diagonal 160" screen??
precsmo is offline
post #472 of 487 Old 01-12-2006, 01:37 AM
kuebler's Avatar
Quoted: 16 Post(s)
No, it's not by a wide margin. You can find a lot of Ruby brightness discussion by searching the forum.
Falk Kuebler
kuebler is offline
post #473 of 487 Old 01-12-2006, 09:31 AM
samalmoe's Avatar
am using ruby on a 139 inch wide hipower..just fine
samalmoe is offline
post #474 of 487 Old 01-12-2006, 09:54 AM
kuebler's Avatar
Quoted: 16 Post(s)
I'm really impressed. Maybe I have a night vision deficiency, without having known it up to now :D
Falk Kuebler
kuebler is offline
post #475 of 487 Old 01-12-2006, 10:28 AM
samalmoe's Avatar
it is a 2.8 gain screen
samalmoe is offline
post #476 of 487 Old 01-12-2006, 11:11 AM
lovingdvd's Avatar
Liked: 608
Right 2.8, maybe 3.0, around its max gain. However its important to note for anyone unfamiliar with the HP, its only a 2.8-3.0 gain screen is you have almost zero angle formed between the lens to screen and screen to eye (which basically means that the pj needs to be shelf mounted right above your head).
post #477 of 487 Old 01-12-2006, 11:34 AM
kuebler's Avatar
Quoted: 16 Post(s)
Thanks. I'm aware of that ;)
I use a High Power too, but at 165" I have no chance with the Ruby, unfortunately. But maybe I should not make such statements before having been at the ophthalmologist ;)
Falk Kuebler
kuebler is offline
post #478 of 487 Old 01-13-2006, 07:45 AM
samalmoe's Avatar
no, i dont think ruby would work at that size screen, but who knows.... a little lasik-ectomy might just work
samalmoe is offline
post #479 of 487 Old 01-13-2006, 08:38 AM
dna
dna's Avatar
There must be at least a thousand posts on the Ruby and screens the past couple months. I think I've posted a hundred of them myself. I have a 133" diagonal High Power. When I first got ruby the picture was too bright for me and I suspect it would have been perfect on a 160" diagonal screen. After about 100 hours on the bulb I can already see a noticeable drop in brightness. Now I would say that its brightness is just about ideal on my screen and would guess it would be on the dim side of OK on a 160" screen.
However, by all accounts I can expect significantly more drop in light output as the bulb continues to age. Based on GregR's and other's measurements, I've lost over 10% output so far and have another 40% loss to go, most of it in the next couple hundred hours. By that time my screen brightness will be around 10 to 12 fL which for me on the low side of good and on a 160" screen it would be around 7 to 9 fL which is lower than most on this forum would like. That level would be considered a very acceptable level by people used to CRT projectors. Keep in mind that this assumes getting 2.8 gain from the High Power. People using ceiling mounted projectors with the High Power won't get that nor will viewers off to the side.
- David
dna is offline
post #480 of 487 Old 01-13-2006, 08:57 AM
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
Theoretically speaking... ;)
I predict much worse actual results.
Nothing is what I want - a true Zen saying.
Marantz AV7005 pre/pro cheap
Bob Sorel is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
