Optoma HD81 1080p DLP official discussion - Page 161 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #4801 of 4830 Old 04-02-2013, 01:58 PM
clubbedougan's Avatar
Ok, thanks. When it arrives I'll give it a tap like it says above and see what happens. It alegedley was dropped on the floor and stopped working. I had an 81LV in the past and regret selling it.
clubbedougan is offline
post #4802 of 4830 Old 04-02-2013, 01:58 PM
Jeff Regan's Avatar
Art, I'm with you, I still haven't seen an LCOS three panel that does it for me, except for the very good CR. I hope you get a chance to see a Runco LS-3 or LS-5 single chip DLP projector. I am absolutely delighted with my LS-3 and short throw lens. It is a more sophisticated image than the HD81-LV, fantastic color, much better CR due to auto iris/bulb control, no RBE compared to the Optoma, great scaling, no banding, good lumens. Most film like image I've seen at the price point. Bought it in June and it has not had any issues whatsoever, unlike the O brand. Optoma service took good care of me, but the products were lemons. I must have gone through over a dozen HD-81/HD81-LV/HD80 units, some serial numbers kept coming back to the refurb pool and to my home theater, with the same issues I returned them for in the first place. The only artifact I've seen with the Runco is occasional flicker due to the AI on flat fields--very subtle and the AI does have a slight effect on color, but even when off, the CR is pretty good.
If you don't want to spend for a new Runco, hunt down a used Planar 8150 or 8130, same projector as the Runco LS-5, LS-3, except for a different scaler. I'm just sorry I didn't dump the O projectors sooner. I am over the moon with the image the LS-3 is giving me! I often watch raw footage of projects I have shot with high end video cameras and the image is very similar to the calibrated broadcast HD monitors I use on set, except with a more subtle, film like quality. Every year I look at the newest JVC model and every year I'm happy that I stayed with single chip DLP, but only the larger DMD size. The .65 is softer, like the LCOS projectors.
Jeff Regan is offline
post #4803 of 4830 Old 04-03-2013, 12:47 AM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 37
You can try connecting the HDMI directly to the projector and the VXD just to the serial port. The VXD can fail in different ways - mine stopped passing video but the controls for powering on and such still worked.
Failing that, if you have a linux computer I can give you some software that I wrote which will allow you to power the projector on and off via the computer's serial port (I use a USB to rs-232 converter). If you find that you could use it, send me a PM because I may not notice a post in this particular thread.
Copyright is not property, it is merely a temporary loan from the public domain.
JerryW is offline
post #4804 of 4830 Old 04-03-2013, 12:58 AM
Excellent. Thanks Jerry.
post #4805 of 4830 Old 04-03-2013, 08:52 AM
MrHifi's Avatar
If the VXD will not start, Jerry's method will not work. I hope the Linux program works for you.
Art Neill
a.k.a.
Mr. HiFi
MrHifi is offline
post #4806 of 4830 Old 04-03-2013, 01:30 PM
Got it today, looks like its been in a car crash. Lid was tight, don't think it has ever been opened. Clean inside. No cables. Is it a standard rs-232 null modem cable I need ?
post #4807 of 4830 Old 04-03-2013, 03:17 PM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 37
I am using the cable that came with it, but I experimented with it a couple of years ago and I think it is a null modem. Not anywhere near 100% confident though.
JerryW is offline
post #4808 of 4830 Old 04-04-2013, 04:04 AM
The label on the base says 'HD81 DLP Projection Display' nothing about LV. Is it an LV model then?
post #4809 of 4830 Old 04-07-2013, 06:56 AM
Does the label/plate on the base of an HD81LV say HD81LV or just HD81?
post #4810 of 4830 Old 06-18-2013, 05:34 AM
folking's Avatar
right,Thanks for all the great info - keep it coming! lJNb
folking is offline
post #4811 of 4830 Old 12-31-2013, 04:44 PM
Infinitenothing's Avatar
Sorry to bump such an old thread but I was able to fix my HDMI problem (none of the HDMI ports worked) by using an EDID cheater . I connected the cheater straight to the projector and used the clone feature, then I installed the cheater between the "to receiver" and "from receiver" ports where the short HDMI cable goes. I guess the part of the projector that outputs EDID died.
CriticalListener likes this.
Infinitenothing is offline
post #4812 of 4830 Old 07-23-2014, 05:38 PM
Liked: 0
Hi there. I am wondering if you could help me. I have an optoma hd81, but I dropped the controller box and now it won't communicate with the projector so can't turn my projector on. Do you still have that program for Linux or better option, do you know how I can turn the projector on through windows?
MrHollywood is offline
post #4813 of 4830 Old 09-28-2014, 07:05 AM
Rycher10's Avatar
I just received an HD81 projector and the controller from a friend. When connected together the controller had no response other than a blinking red power light...nothing else. The projector had a solid red power light and blinking blue lamp light. No other functions would work....no power, no light from lamp, nothing. I am using a 50 ft length of male to female serial cable with a gender changer on one end if that matters. I've read all the issues about the lamp dying early, or the controller's HDMI problems, or the controller dying early as well. I don't really need the controller as my pioneer Elite receiver handles all the HDMI switching for me, and I was looking for a way to connect the receiver directly to the projectors single HDMI input and let the receiver handle everything else. Problem is that as it is the projector and the controller are married together with that serial cable and neither will work independent or each other.....or so I thought.
I opened my projector to see if I could find a remote IR sensor connection so that I could just rig an IR blaster to control power on/off. What I did find inside the projector are 3 surface mount momentary switches - one of them being a power on/off switch. I connected my bluray player directly into the projectors single HDMI input, left the serial cables unplugged, and pressed that little power switch.....BAM! The projector powered up just fine and was playing my bluray with no issues, and more importantly without that POS controller. Better still is that all previous calibration and color settings have been retained inside the projector! So at this point I purchased a small momentary switch and soldered 2 small wires to the switch on the board itself, and mounted that switch on the rear of the projector panel. Sure, I have to manually turn on the projector by pressing that new switch, but a $2.00 switch, and the removal of that processor, I think I can live with that.
I'm still trying to figure out a way to get am IR sensor attached to the projector. There has to be a plug somewhere inside as the HD81 and HD80 are basically the same units and share the same interior, and the HD80 has the sensor. Finding this IR sensor is the only way to access the projectors color settings, etc.
Anyway, easy fix if you lost your processor, and a definitive answer about the projector being used without the processor - it can be used standalone without the processor.
Jimmy
OBoucard likes this.
Rycher10 is offline
post #4814 of 4830 Old 10-07-2014, 04:39 AM
Liked: 0
Jimmy
I confirm this. I found this "Power on" button inside. It is here for service. If you power it on with it and plug something in the HDMI port it works fine.
I have bought a Null-Modem RS232 USB/Serial cable to try to control the lense shift and other functionnality. No chance, I don't know the protocol. I found the one for HD81 (non LV) but it does not work.
OBoucard is offline
post #4815 of 4830 Old 10-15-2014, 08:56 PM
Liked: 1
I was wondering if anyone had this problem:
My HD 81 has been working perfectly for several years, and 1700 hours on the bulb. I turned it on the other day, it ran fine through the startup process and picture startup, then shut off. After cycling the AC, it worked for a bit longer one time, but now it just does the same thing...turns on, powers up, then off.
Any help would be appreciated!
Optoma say they don't service these any longer!
Thanks, SebasSF.
SebasSF is offline
post #4816 of 4830 Old 10-16-2014, 05:33 AM
SimpleTheater's Avatar
Quoted: 203 Post(s)
Liked: 96
Thanks, SebasSF.
Stupid thing to check is the HDMI and serial cables. If they aren't making a perfect connection they will cause the projector to shut down. Worst case scenario, I could sell you mine as I just fell in love with the Epson 6030 at a friends house.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
post #4817 of 4830 Old 10-16-2014, 10:11 AM
sstephen's Avatar
Liked: 24
yes, Optoma seems to think spending $1000+ per year on their mediocre projectors makes sense for the consumer.
This is my LAST Optoma product.
Anyway, you don't tune in to hear me rant.
1. Check or just replace the rs232 cable. If that stops communicating the projector shuts off as far as I can tell.
2. Open the controller box and blow some air across things. Don't use too high pressure air. I find this helps me.
Mine shuts off at seemingly random intervals. Usually shortly after startup, but sometimes after an hour or more. Blowing air seems to help for a few days anyhow.
I'm going to open mine up and wire in some switch and see if I can bypass the controller. But I watch movies with a scope screen and external lens and need to stretch the image vertically to compensate. If I use the computer I can do it there, but my bd player has no option to do that so I'd have to use the controller box anyhow.
Scott Stephens
sstephen is offline
post #4818 of 4830 Old 10-17-2014, 02:08 PM
Liked: 1
Thanks for the feedback and ideas. I took the controller out and blew it out...looks clean and new on the inside. Checked all the cables and connections...looks fine. Reinstalled, but still the same problem. Frustrating that I did not touch anything, and it turns on and looks perfect until it turns off! I guess next up is to remove the projector and check it out...a real pain as its in a lift with the mounting screw only available from the top- a long crawl through the attic! Some of the newer projectors I'm looking at if this is a bust won't fit in the custom lift...should have made it larger I guess!
Any thoughts on how the hd81 compares to a newer hd25e?
Thanks, Sebastian
SebasSF is offline
post #4819 of 4830 Old 10-17-2014, 09:03 PM
Liked: 1
Ok, took a really nasty crawl and took the projector down. Opened it up and tested it using hdmi in and the service on switch...runs fine!
Bad controller I guess?
Any other ideas for controller issue repair?
Has anyone figured out a way to use the controller IR on switch and bypass some of the other parts so you can turn on the unit with controller IR? Figuring out a way to use the switch in the projector does not sound like fun...
Does image suffer without the controller?
Thanks, Sebastian
SebasSF is offline
post #4820 of 4830 Old 10-29-2014, 05:13 PM
Liked: 1
So no ideas? I guess I have a large paperweight. Anyone need a working projector and not working so well controller for parts?
Any thoughts on how an Optoma HD25e will compare to an 81? I need a small, lint projector to fit in my lift, and this could be a good option...
Thanks, Sebas
SebasSF is offline
post #4821 of 4830 Old 11-07-2014, 12:24 PM
Quoted: 203 Post(s)
Liked: 96
I could sell you my HD81. Everything is working fine.
post #4822 of 4830 Old 11-14-2014, 03:13 PM
Liked: 0
hi there, are you selling the optoma hd81 scaler?
post #4823 of 4830 Old 11-14-2014, 03:15 PM
Liked: 0
Jimmy
hi are you selling the hd81 scaler?
post #4824 of 4830 Old 11-14-2014, 04:57 PM
Liked: 1
I ended up buying an Optoma HD 50. Why another Optoma...well, it fits in my custom projector lift and the throw works. The image is great for home theater after calibration...I would call it an upgrade from the HD81 in many ways.
So long HD81 thread, and thanks!
SimpleTheater likes this.
SebasSF is offline
post #4825 of 4830 Old 11-14-2014, 07:42 PM
urbeenjammin's Avatar
Quoted: 66 Post(s)
Can you give us your perspective of the brightness in 3D with the HD50?
urbeenjammin is offline
post #4826 of 4830 Old 11-18-2014, 01:54 PM
Liked: 1
The HD50 is much brighter, but I had an HD81, not the LV. I'm really enjoying the HD50.
SebasSF is offline
post #4827 of 4830 Old 12-29-2014, 03:57 PM
Nav Sandhu's Avatar
Projector no lights, controller is blinking red
The kids were watching the projector and the projector just shut off. There are no lights on the projector, on the controller I have a blinking red light. I rebooted the equipment and it's still not working. The bulb is fairly new (<400hrs).
Any ideas? I've never seen the projector have no lights on. The manual doesn't say anything about this situation. Please help.
Nav Sandhu is offline
post #4828 of 4830 Old 12-30-2014, 04:27 PM
Nav Sandhu's Avatar
Update:
The VXD is blinking RED, while the projector has no lights. I opened the unit and found the On button, that didn't work either. Do I need to have an HDMI signal to get that to work? I just had power. Please help.
post #4829 of 4830 Old 01-17-2015, 09:58 PM
Liked: 0
Where on projector are service mini-switches?
Thanks, Sebastian
My LV-81 has the classic won't turn on problem. Hitting it worked for a while, but no longer.
I was wondering if someone could tell me where the mini-switches are located on the projector itself. Are they accessible from behind the rear panel? Or does the projector shell have to be removed to access them? My projector is ceiling mounted upside down, and I'd like to know if I have to dismount it to get internally into the mini-switch location?
Thank you very much in advance...Alan
alzullig is offline
post #4830 of 4830 Old 09-30-2015, 09:54 AM
hdcl's Avatar
Quoted: 12 Post(s)
Originally Posted by MrHifi View Post
I have two projectors and two controller boxes. Both have exhibited the "failure to start" phenomenon. When i experienced the original failure of this type, i returned the whole system to Optoma. They changed boards in the projector and repaired the controller. They charged $800.00 for the repair. The returned projector worked well for 4 months then failed. I bought a refurb projector and controller from Optoma for $2,450.00. That controller worked fine with the old projector but eventually failed. I had two good projectors and 2 bad controllers. One night I gave one of the controllers are hard smack on its top. After that, it has worked for 6 months. The bulb in the projector I use, the one Optoma returned for the $800.00 repair, has 2400 hours on it. Picture is OK. The other controller box has not worked regardless of how I hit it. I suspect that a relay in the box becomes stuck but who knows. My son in law just bought a new Epson 5220 3D projector with 3 panels. I swear that my picture is sharper and does not suffer from the convergence issues that are clearly apparent on 3 panel units.
I just had the issue where my HD81 would fail to power up. Both with the remote and the front panel switch, the VXD would go from red to blue but then after about 30 - 45 seconds would go back to red. The Projector has a red light and would not power up. I figured the VXD was not transmitting the on/off signal to the projector and was going to try all sorts of diagnostic steps till I rediscovered this thread again. I gave the VXD a couple of good hard smacks with a rubber mallet and voila - the projector powered up just fine.
Time will tell if this is a temporary fix or if the VXD is on its last legs. I was looking to replace the HD81 in about 3 - 6 months anyway so I hope I can get that much mileage out of it. I am on my 5th bulb now and it is getting pretty dim. I don't want to pony up another $500 for a bulb on a dying unit.
hdcl is offline
Optoma , Vivitek D950hd 3000 Lumen 1080p Office And Home Theater Projector , Casio Rs 232 Adapter Catalog Category Projectors Accessories
