Samsung H710AE??? 4000MRSP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1071 Old 02-24-2006, 08:33 PM - Thread Starter
stef2's Avatar
Quoted: 422 Post(s)
Liked: 257
I've just read a review of this Projector on Projectors Central. I had never heard of this one before...While reading the review I almost thought it was a joke, the reviewer seems so impressed, it is almost unbelievable...!
Has anyone seen this PJ in action? What do you think of it? How does it compare to other PJs using the same technology (HD2+)? I think I will be watching closely for info about this one. Even the lens shift seems impressive...unusual for a DLP within this price range!
stef2 is offline
post #2 of 1071 Old 02-25-2006, 08:37 AM
gnomey's Avatar
I have seen it and it's awesome. Right out of the box, it looks better than most <$10k projectors after they've been calibrated. The manufacturer's Minimum Advertised Price (MAP) seems to be $3,499, as that is what reputable internet dealers have it listed at. The price is way too low for the performance, but projectors sell largely on specs and this one "only" has an HD2+ chip, not a DC3. HOWEVER, it has been noted that sources at TI and Coretronics (makers of more DLP light engines than anyone in the world) say that the conversion algorithms for the DC3 are not perfect. Therefore, while it does have better contrast and saturation, the DC3 cannot do as accurate colors as the "regular" HD2+. A lot of people can't tell if colors are slightly off, though, so many people will prefer the image of the DC3.
Referring to other HD2+ projectors, it definitely separates itself from the pack. If you have a higher-end HD2+ projector that offers all the adjustments needed for a full ISF C3 calibration, such a projector will make a similar image after calibration. Samsung seems to have upgraded the lens and the firmware from the last generation, and few other HD2+ projectors will be able to match the black levels this unit can generate. It also looks expensive and classy. I have not seen another projector look as good without spending another $2k - $4k.
gnomey is offline
post #3 of 1071 Old 02-25-2006, 09:25 AM - Thread Starter
stef2's Avatar
Quoted: 422 Post(s)
Liked: 257
Thanks for your very detailed informations...of course the price of this PJ makes me want to compare it to the Optoma H78DC3. From a color calibration point of view, the Samsung seems to be a winner. But absolute black levels and shadow details should be better with the Optoma, since it has a DC3 Chip.
Did I interpret your post correctly?
stef2 is offline
post #4 of 1071 Old 02-26-2006, 10:13 AM
jkirk's Avatar
Does anyone know where the vent fan is. If it's in the front, it just may work for me. In the back, it won't.
In-Walls! Manufacturers Please Speak Out.
jkirk is offline
post #5 of 1071 Old 02-26-2006, 12:06 PM
sspears's Avatar
Quoted: 162 Post(s)
Liked: 312
sspears is offline
post #6 of 1071 Old 02-26-2006, 04:10 PM
SAM ZEOLI's Avatar
Quoted: 21 Post(s)
Could anyone tell me if the Samsung is mounted between the top and bottom of the screen like Sharp,or above the screen like Infocus.Thanks. Sam Zeoli
SAM ZEOLI is offline
post #7 of 1071 Old 02-26-2006, 04:14 PM
inky blacks's Avatar
Projector Central rates the Samsung at 465 ANSI lumens when set up in "theater mode," where the colors are most accurate and the contrast is the highest. Projector Central also rates the Epson PowerLite Cinema 550 at just 240 ANSI lumens in its "theater mode." So the Samsung is actually almost twice as bright as the Epson, which is noted as a "bright" projector, in the set-up that most videophiles will want to use.
PS Projector Central rates the Optoma H79 at 450 ANSI lumens with "video-optimized settings."
IB
inky blacks is offline
post #8 of 1071 Old 02-26-2006, 06:20 PM
kktx's Avatar
This PJ has a vertical lens shift, so you should be able to place it conveniently where you wish without using keystoning.
kktx is offline
post #9 of 1071 Old 02-27-2006, 06:32 AM
Efalegalo's Avatar
Quoted: 25 Post(s)
for those who have actually seen the projector in action? Could you please tell us if this projector is work the $$ over the recently released Optoma H72 (which also have rave reviews at projector central - disregarding intalling difficulties). ?
Efalegalo is online now
post #10 of 1071 Old 02-27-2006, 08:45 AM
sspears's Avatar
Quoted: 162 Post(s)
Liked: 312
I have the 700 so I can comment on it compared to an H79, but I can't comment on the H72 as I have not seen it.
The H79 and even Sharp 12000 have visible contouring when looking at a smooth gradient. You can see this pretty well on a gray ramp from AVIA. The 700 has a smooth gradient when looking at the same clip.
The Sharp 12000 has a lower black level and higher contrast ratio with its adjustable IRIS in high contrast mode.
sspears is offline
post #11 of 1071 Old 02-27-2006, 08:54 AM
jkirk's Avatar
If this projector has so many positives, why all the buzz about Optoma H79 and Benq 8720? Why not this one.
jkirk is offline
post #12 of 1071 Old 02-27-2006, 09:16 AM
bubbawilly's Avatar
For one, Samsung doesn't have the visibility in front projection like either BenQ or Optoma.
Second, the product was just recently reviewed for the first time
I'll also speculate that there was little build-up hype, like there is for many pre-release projectors, because on paper (HD2+ at $4K), it doesn't appear to be a particularly good value. High value DC3 models, and those sporting the new dual-mode chip are all the rage.
bubbawilly is offline
post #13 of 1071 Old 02-27-2006, 09:24 AM
Kris Deering's Avatar
Quoted: 2219 Post(s)
Liked: 3411
This is the projector that was designed in part by Joe Kane for Samsung. It's calibrated performance is superb, especially in color rendition. It also has some really cool calibration tricks.
For anyone that has gone to Joe's demo at CEDIA the last two years this is the PJ he's been showing.
My Home Theater
Kris Deering is offline
post #14 of 1071 Old 02-27-2006, 10:24 AM - Thread Starter
stef2's Avatar
Quoted: 422 Post(s)
Liked: 257
Do you mean this PJ has been around for two years? Things change so fast...
Can any Samsung H710AE owner comment about how this PJ compare to the H78DC3-H79 from optoma ? The samsung seems VERY bright but I am mostly interested in contrast and shadow details. It is probably not on par with those DC3 projectors, but who knows...
stef2 is offline
post #15 of 1071 Old 02-28-2006, 08:18 AM
jkirk's Avatar
What Stef said. I am very interested in this. I was considering the Benq 8720 and the Optoma H79 but this seems awfully good. So, if anyone has an opinion, please chime in.
Does AVS carry this?
jkirk is offline
post #16 of 1071 Old 02-28-2006, 09:10 AM
BRADH's Avatar
Quoted: 37 Post(s)
Iam getting ready to get a new projector my CRT is on it way out. Iam interested in getting a bigger screen, the one Iam using now is studiotek 130 80". Iam going with the 710AE I have total light control in my room. http://gallery.avsforum.com/showgall...0/ppuser/39383
Size 102" to 104" diagonal is the max I want to go. I would like to get a screen for the 710AE and be able to use it in the furture with a 1080p projector hopefully 3 chipper. So the High Contrast Grey would be nice for a future projector but will make the 710AE to dim?
Thanks for the Help
Brad
BRADH is offline
post #17 of 1071 Old 02-28-2006, 10:23 AM
Mountaineer's Avatar
I've seen all these pjs and what I can say is that the 710AE is rated at 2800:1 contrast (maximum for HD2+). Black levels are good, but black levels on a DC3 pj e.g. H79 are better BUT (and this is a big BUT), shadow DETAIL on 710AE is superior to any DC3 pj I have seen, even Samsung 800AE.
Mountaineer is offline
post #18 of 1071 Old 02-28-2006, 10:46 AM
jkirk's Avatar
Okay then Mr. Mountaineer, which would you buy for yourself?
jkirk is offline
post #19 of 1071 Old 02-28-2006, 11:31 AM
MrWigggles's Avatar
Do you think some of that could be do to the increased contrast and thus presumably increased gamma of the 12000?
Asked in a different way, each step in input signal from (16,16,16) to (235,235,235) into 12000 should create more actual change in output lumens. More contrast would make subtle gradients harder to create?
-Mr. Wigggles
The Mothership is now boarding.
MrWigggles is offline
post #20 of 1071 Old 02-28-2006, 10:14 PM
sspears's Avatar
Quoted: 162 Post(s)
Liked: 312
With that said, would you expect the gradient to change based on the IRIS setting of the 12000? I will talk with Kris and see if this is something we can do.
sspears is offline
post #21 of 1071 Old 03-01-2006, 09:07 AM
jkirk, I am pretty finicky about front projection, but at $3499 with its filmlike PQ it's the Samsung, hands down. If I actually had an appropriate room in my house, I would buy it.
post #22 of 1071 Old 03-01-2006, 01:35 PM
jkirk's Avatar
Thanks Mountaineer, good straightforward answer. Now if only AVS sold it.
jkirk is offline
post #23 of 1071 Old 03-01-2006, 09:52 PM
gnomey's Avatar
I saw it at Electrograph's show in So Cal. Oh my! It's like a revelation every time I see it. The image had a 3D quality I normally associate with a high end 3-chip DLP that has been calibrated. Some of the comments people made while I was standing at the tent:
"It's a 3-chip (DLP), right?"
"Is this Samsung's new 1080p projector?"
"I don't like these projectors that cost over 10k. Real people can't afford them." (sorry, dude, but it's not even close)
stef2 - yes, you did interpret my post correctly. Any good DC3 projector will have an edge in black levels, and potential contrast, but not necessarily in shadow detail, as noted by Mountaineer. After seeing the 710 again, I have to say the black levels are better than any HD2+ pj I've seen, possibly better than some DC3 models. Even better is how TRUE the blacks and grays are. Not a hint of color, unless it's in the source material that way.
jkirk - I asked Joe Kane your question for you! Apparently, this was the first product Samsung has released that wasn't initiated by the marketing department. It was actually developed and released before the marketing department even knew it existed. Now they don't know how to market it. He also said everything that bubbawilly pointed out in his post. AND - I'm sure AVS could source it, or do a power buy with TVAuthority. (hint, hint, hint)
Kris Deering - If you like this projector calibrated, you should see it out of the box. The first one I saw was pulled straight from a sealed box and looked better than most calibrated projectors I have seen. Uncalibrated, it is never more than 10% off of 6500k at any point along the grayscale ramp. Calibration brings it under 5% variance at any point. Those are the numbers Joe Kane was throwing out, at least.
I've never seen the H79 and the SP-H710AE side-by-side, with the same source. That would be the only way to draw a proper comparison. However, I did get to see the H79 at a trade show. The 710 seems to have more "depth" to the image and more accurate colors, while the H79 (as I remember) would have a slight edge in black levels. They are both excellent representatives of their TI chips. If price were no object, it would be a tough choice, but I'd still go with the Samsung. Factoring in price, it's Samsung all the way.
I still love my Brillian 720p RPTV, but I'm trying to decide if I can a) fit a 100" - 110" screen above it, and b) how I can get the wife to understand the need for an even larger display...
gnomey is offline
post #24 of 1071 Old 03-02-2006, 01:46 AM
D_B_0673's Avatar
Quoted: 92 Post(s)
Front exhaust makes hushboxes harder to configure if you are ducting the heat out
Dan
D_B_0673 is offline
post #25 of 1071 Old 03-02-2006, 06:58 AM
Ursa's Avatar
You really shouldn't need a hushbox with this PJ, though.
Ursa is offline
post #26 of 1071 Old 03-02-2006, 07:39 AM
BRADH's Avatar
Quoted: 37 Post(s)
I order my 710AE last night cant wait to get it. I posted in this thread about screen white or grey with out any response. For those of you that have seen this projector what type of screen did you see it on?
Thanks for the help
Brad
BRADH is offline
post #27 of 1071 Old 03-02-2006, 08:13 AM
jkirk's Avatar
I'm also ordering one from AVS and would like similar screen advice for a mostly darkened room. Need an electric tensioned. Love Steward but a little pricey.
jkirk is offline
post #28 of 1071 Old 03-02-2006, 09:55 AM
sspears's Avatar
Quoted: 162 Post(s)
Liked: 312
Brad
If you are using a 6' wide 16x9, then the Grayhawk RS is a good choice. If you are using > 6' wide, then a Studiotek130 is a good choice. At least those are Joe's recommendations based on trade show demos. He usually sets up a 72" wide GH RS and 87" wide ST130 side-by-side for his demos.
sspears is offline
post #29 of 1071 Old 03-02-2006, 10:12 AM
jkirk, I understand AVS is going to carry the 710AE (maybe they already are).
Stewart makes a great screen, but I've also seen it on Da-Lite and Vutech screens and it looks great on those, too.
post #30 of 1071 Old 03-02-2006, 10:31 AM
guptown's Avatar
stef2,
thanks for posting about this projector. i have been considering the H79 and the 8720 but I have to admit being very intrigued by the H710AE.
would love to hear more comments from people who have seen all three projectors or those who have the Samsung installed and calibrated (although it appears to be pretty close out of the box).
gup
guptown is offline
