Official Optoma HD7100, HD7300 + HD3000 Scaler thread. - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1081 of 2852 Old 10-29-2007, 10:37 PM
Quoted: 40 Post(s)
Here is a limited discussion on HD3000.
Do a google on Gennum gf9351 will bring some info.
Or just gennum get to the source.
http://www.avsforum.com/avs-vb/showthread.php?t=690384
It is all about quality. That is the picture.
JVC DLA-RS20, NEC XG-1352LC 8" CRT, 106" wide StudioTek 130 screen
CaspianM is offline
post #1082 of 2852 Old 10-29-2007, 10:40 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
So what is the offset of the pj?
Can some one help me with a little math. I want to know exactly where on the wall the image will be.
I'll have a 100" (diagonal) image (87 x 49).
The top of the image will need to be 15" down from the ceiling.
According to the Projection Calculator, the farthest back that I can put the lens is 11'10", so that is where I want it.
I have a drop ceiling so I 'm gonna push the pj all the way up to the ceiling.
Am I gonna need lens shift in this situation? Is this do-able?
Thanks for any help.
Smarty-pants is offline
post #1083 of 2852 Old 10-29-2007, 10:59 PM
stevereis's Avatar
Originally Posted by CaspianM View Post
Here is a question I have been pondering to answer maybe Steve can shed some light.
with 1080i source from D*Tv, how does HD3000 will do the downconvert to 720? will it do a 540p and then or else?
CaspianM - found the answer in the thread you provided:
http://www.avsforum.com/avs-vb/showt...89#post7999889
True deinterlacing & scaling, no rescaling of a 540 line field.
stevereis is offline
post #1084 of 2852 Old 10-29-2007, 11:00 PM
stevereis's Avatar
Manual says roughly half the image height (25" in your case), so you should be OK.
post #1085 of 2852 Old 10-29-2007, 11:01 PM
bdbaba's Avatar
So do you think the ones coming with this PJ have the GF9350 VXP or the 9351, and how can you tell?
bdbaba is offline
post #1086 of 2852 Old 10-29-2007, 11:02 PM
Quoted: 747 Post(s)
Liked: 623
I was just going to ask the same thing.
post #1087 of 2852 Old 10-29-2007, 11:02 PM
Quoted: 747 Post(s)
Liked: 623
So will I be able to use the lens shift to get from 25" to 15"?
post #1088 of 2852 Old 10-29-2007, 11:09 PM
stevereis's Avatar
25" is the MAX shift possible for you, so you can shift 15" with no problem.
post #1089 of 2852 Old 10-29-2007, 11:35 PM
Quoted: 40 Post(s)
Gitarman said only earlier batch had the 50 which was replaced with 51 later.
CaspianM is offline
post #1090 of 2852 Old 10-29-2007, 11:45 PM
Quoted: 40 Post(s)
The shift range is 13/20 times the screen hight (H) for up and 1/2xH for down shift.
At neutral (no shift applied) it has zero degree offset meaning the top of the image is line up with center of the lens when ceiling mounted.
Horizontal is 3/40xH for each side.
CaspianM is offline
post #1091 of 2852 Old 10-29-2007, 11:53 PM
Quoted: 40 Post(s)
Smarty,
If pj is 15" above the screen you will need to shift down the image by 15" from null.
1/2 of 49" is 24.5" hence it is doable.
CaspianM is offline
post #1092 of 2852 Old 10-30-2007, 07:50 AM
mkoss's Avatar
Remove the top cover and look if there's no sticker to be broken voiding warranty.
mkoss is offline
post #1093 of 2852 Old 10-30-2007, 08:57 AM
FGM
FGM's Avatar
Can anybody please confirm that the processor that comes with the HD7300 is NOT limited to 720p output and can be set to 1080p output?
FGM is offline
post #1094 of 2852 Old 10-30-2007, 09:10 AM
stevereis's Avatar
The manual says this:
The following are the resolutions and frequencies the HD3000 can output:
  • 1280x720p 50/60/72 Hz (default 60Hz)
  • 1024x768p 50/60/72 Hz (Native resolution for some 16x9 Plasma TVs)
  • 1280x768p 50/60/72 Hz (Native resolution for LCD TV and plasma TV)
  • 1366x768p 50/60 Hz (Native resolution for 16x9 plasma TV)
  • 1920x1080p 48/50/60 Hz
I need to actually crack mine open and confirm the settings are there but will not be able to do this until the weekend. I'll have to validate on my 1080p TV since the PJ is only 720p. (I'll be contacting Optoma for an update if mine cannot do 1080p60.)
post #1095 of 2852 Old 10-30-2007, 09:18 AM
Quoted: 40 Post(s)
Any link to all the updates?
CaspianM is offline
post #1096 of 2852 Old 10-30-2007, 10:14 AM
POLI's Avatar
Hello, I have been reading this thread page for 10 days now, I´m in Spain and I bought 2 weeks ago the Optoma HD7300, I just received it last friday, I hooked up everything up and it was working fine but I have PAL 50 HZ, and the projector with the scaler were working at 60 HZ, I disconected the scaler and hooked my dvd player straight to the projector and it worked perfectly, through component and composite signal. beautiful picture, it was amazing, it really surprised me. after this I found out that my Vincent dvd palyer has progressive scanning.
now I when back and hooked up again the scaler and the projector dont find anything with the DVI INPUT.I took the scaler to my lcd tv and hook the scaler with another dvd palyer (composite) and the tv don´t find anything in HDMI input.
can anybody help me how to fix this problem, why I don´t get any signal from the scaler..
sorry for my mistakes.
Thank you.
POLI is offline
post #1097 of 2852 Old 10-30-2007, 10:16 AM
FGM
FGM's Avatar
Originally Posted by mkoss View Post
The unit bundled with the 7100 is only 720p Read the HD3000 thread
mkoss, could you please point us to where you have read that? I have read the "Optoma HD3000 with Gennum solution review" thread, under video processors forum, and could not find it.
I assume that when you say "the unit bundled with the HD7100" you mean the processor that comes with the HD7300, right?
FGM is offline
post #1098 of 2852 Old 10-30-2007, 10:27 AM
guitarman's Avatar
Quoted: 13 Post(s)
Thank you.
Read the manual on how to manually adjust the output resolutions with the silver buttons on the front of the scaler. Don't just start hitting the buttons read the manual for the correct sequence.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #1099 of 2852 Old 10-30-2007, 10:54 AM
Quoted: 747 Post(s)
Liked: 623
The prodical son returns...
Guitarman, do you have anything further to add to the discussion? Your association and experience with Optoma is priceless to us. What do you think about wether or not the processors from Newegg are limited to 720p or not? Are you still in posession of the projector and processor?... or are they long gone?
post #1100 of 2852 Old 10-30-2007, 11:10 AM
POLI's Avatar
Thank you for the respond guitarman, you have one of this scaler also right..that´s what i did, I pressed the up botton and wait a few seconds and nothing, anyway I´m going to install my projector tomorrow, I just ordered a 10 meters component cable and when I have everything hooked up nicely I will play with it with no fear, after all I read in this page I was so worried about my projector that I did not want to mess with it. this has been the last part of my home cinema, when I have everything hooked I try to post some pictures.
POLI is offline
post #1101 of 2852 Old 10-30-2007, 01:01 PM
POLI's Avatar
this is in the european intructions:
Use the front panel control buttons, press _ key one at a time. Each pressing of the
HD3000 will change its output resolution from the table shown above. Please allow for a few
seconds for display to try to lock on to the changed output resolution.
What key is "_", is this the down key?
POLI is offline
post #1102 of 2852 Old 10-30-2007, 02:51 PM
ak99999's Avatar
You will need to mount the projector 15 inches down from the ceiling and use maximum lens shift. With no lens shift, the center of the picture will line up with the center of the lens. See page 22 of the user manual and the post below.....
http://www.avsforum.com/avs-vb/showt...0#post11033860
ak99999 is offline
post #1103 of 2852 Old 10-30-2007, 02:56 PM
Quoted: 40 Post(s)
The whole advantage of lens shift flexibility of pj installation.
With that in mind, why does he need to install the pj 15" down from the ceiling and use no lens shift when he can do exactly the opposite?
CaspianM is offline
post #1104 of 2852 Old 10-30-2007, 03:05 PM
gottahavapj's Avatar
You will need to mount the projector 15 inches down from the ceiling and use maximum lens shift. With no lens shift, the center of the picture will line up with the center of the lens. ...[/url]
This isn't true is it??? I thought a ceiling mounted 71/7300 would have the lens center about even with or a couple of inches above the top of the image or the opposite for table mount. If the neutral position is center of lens= center of image/screen, that's about a deal breaker for me. Can someone confirm??
Cheers!
gottahavapj is offline
post #1105 of 2852 Old 10-30-2007, 03:37 PM
Quoted: 40 Post(s)
I would think it is zero offset or lined up with the top of the image witout any shift.
I do not have any hands on experience with this pj so if someone who has this pj would be nice to clear up this issue. And what would be the case with shift all the way up in ceiling position. where would be the lens with respect to screen onto a 110" diag screen.
CaspianM is offline
post #1106 of 2852 Old 10-30-2007, 03:55 PM
Quoted: 747 Post(s)
Liked: 623
See pages 21-23 of the manual.
http://marketing.optomausa.com/PDFs/...300_Manual.pdf
post #1107 of 2852 Old 10-30-2007, 04:09 PM
Quoted: 40 Post(s)
In the manual it does not say what the default (no lens shift) offset is.
Did you find out?
On line calc says the min (with shift all the way up) vertical distance between the lens center to the top of the image is 6" in ceiling mount. But not really certain now.
CaspianM is offline
post #1108 of 2852 Old 10-30-2007, 04:18 PM
Quoted: 747 Post(s)
Liked: 623
From what I can interprate, I think the center of the lens is to be in line with the top of the screen (with no lens shift). From there, if you need to use lens shift, you have 50% of the image height to play with. So if your image is 50" tall, then you could move the image 25" up or 25" down.
I THINK that's how it should work.
post #1109 of 2852 Old 10-30-2007, 04:21 PM
mkoss's Avatar
Read threads 48,67 and 75 under the hd3000. On second reading I'm not sure what these mean for the newer units. Maybe guitarman can elucidate more on this.
mkoss is offline
post #1110 of 2852 Old 10-30-2007, 04:30 PM
Quoted: 40 Post(s)
We already know that upshift is 13/20 of the screen hight. That is .65 of the hight. Down shift is 1/2 of the hight.
What we do not know for sure is the off set at default with no lens shift to be used as a reference point.
CaspianM is offline
