Official Optoma HD7100, HD7300 + HD3000 Scaler thread. - Page 96 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2851 of 2852 Old 01-08-2013, 11:34 AM
FlyingBoat's Avatar
I can't help you, but could you pass the file and instructions to me as well? I plan to get around to this at some point as well. I would also wonder if you get this resolved if it would be worthwhile enough for me to pursue. Thanks.
RonBonnell@HCSDW.com
FlyingBoat is offline
post #2852 of 2852 Old 05-24-2015, 11:37 PM
Liked: 0
Bumping an old thread in hope of someone still reading it.
My HD7100 has been working almost perfectly up until this other day. The vga port stopped working a while ago, but now also the DVI is acting strange. Only the signal from the laptop works (hdmi to hdmi/dvi adapter) and the colours in the pictures are distorted. Blue/cyan horizontal lines are moving all over the screen and the screen looks more blue/cyan. I tried different hdmi cables but the result are the same, also tried a DVI cable straight from my desktop but that doesn't give any picture. However, the start image and the menus are not affected and looks completely fine. I ordered another DVI/HDMI adapter to check if that will work, but I'm not feeling optimistic. Does anyone have any idea of what could solve the problem? Should I try dissambling it completely and clean the chips? I took it some of it apart and tried cleaning out all the dust but it didn't help. The lamp has about 600hrs use.
Any feedback would be greatly appreciated!
David Heiner is offline
