Mitsubishi HC5000 (aka HC5000BL) 1080p LCD MSRP $4,495 - Page 65 - AVS Forum | Home Theater Discussions And Reviews
Old 10-18-2009, 12:51 PM
arc trooper's Avatar
ok heres a PROBLEM went to go turn on my pj today...and heard a tiny pop sound...hmmm didnt think anything of of it.. well... now when it trys to turn on and fire all i hear is this annoying clicking sond and the lamp wont turn on... please anyone else have this problem? btw the lamp indicator isnt showing a replace lamp code...im gonna buy a new lamp just to see but anyone else have this issue?
Don't harsh the mellow, man!
Xbox Live GT : ARC TROOP3R
arc trooper is offline
Old 10-18-2009, 01:11 PM
sbg777's Avatar
Although if you replace the lamp and that's not the issue with yours you are out $300+ , it sounds like the same thing that happened to mine. I sent it in for service and it was the lamp.
EDIT: I should add that when I sent mine in for service they upgraded the Filter to the new style for free.
sbg777 is offline
Old 10-18-2009, 02:18 PM
thanks! i found a lamp for 100 bux...think ill go with it
Old 10-18-2009, 05:01 PM
DMJ
DMJ's Avatar
$100!!!
Please post a link so I can buy a spare (or just PM me )
Dan
DMJ is offline
Old 10-18-2009, 08:08 PM
sbg777's Avatar
Originally Posted by DMJ View Post
$100!!!
I would like to know where to get such a great deal too if you could shoot me a PM please.
Jim
sbg777 is offline
Old 10-19-2009, 09:53 PM
its a used one... but gauranteeed 210 hrs on it... but for 100 bux nice to have a spare! just ebay the mod # of your pj
Old 10-20-2009, 08:15 AM
DMJ
DMJ's Avatar
How does the "warranty" work? There's no meter on the bulb, the clock is inside the projector. So there is no way to know if it's used for 1 hour or 1,000 hours. And, if it burns out, won't the seller just say "it happens sometimes"?
Dan
DMJ is offline
Old 11-10-2009, 06:14 PM
ok guys heres my problem AND ITS MESSED UP! i bought a new bulb and attempted to put it in...and whammo....its jammed in there any ideas?
and no its not upside down..
Old 11-11-2009, 03:33 AM
nvm i got it in
Old 11-11-2009, 07:14 AM
DMJ
DMJ's Avatar
Cool! I sure didn't have a suggestion for you
So, how does the warranty on a used bulb work?
Dan
DMJ is offline
Old 11-11-2009, 11:30 AM
well i got the bulb...let me tell ya... messed up! so i sent it back and bought a new one for 244 which was a pain in the ass to get in there was really really really tight
Old 11-12-2009, 11:45 AM
DMJ
DMJ's Avatar
Messed up? How? Which seller did you buy from?
The new one, it's not a perfect match for the OEM size-wise? Where did you buy it?
Dan
DMJ is offline
Old 11-28-2009, 07:41 AM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
VLT-HC5000LP
If the above and Made in Japan are not on the box it's a fakie. This is how it should look like:
And if ebay, make sure it is a high volume Jap dealer, ie thousands or above goood ratings.
bobpaule is offline
Old 11-28-2009, 10:27 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 57
Any 5000 owners that can help me with this problem?;
http://www.avsforum.com/avs-vb/showthread.php?t=1200537
rnrgagne is offline
Old 01-08-2010, 04:55 PM
aakrusen's Avatar
Quoted: 14 Post(s)
I just got my refurbished Mits HC5000 on Tuesday (1/5/10) and I got it all installed and calibrated for my setup. The picture looks great and everything works. However, when I switch sources on my receiver (Onkyo TX-SR705) the projector shuts down with the power and status light blinking a pattern of colors. I referred to the owner's manual and based on the led pattern of the two lights, I come up with an "abnormal" condition and I should "contact the manufacturer". I tried using 3 different lengths of HDMI cables (20ft, 10ft, and 6ft) all with the same results. I also plugged the PS3 directly to the projector and it will do that shutdown thing when changing from the lenshift/focus screen back to the PS3. Has anyone else had this problem?
Panny AE8000U
Seymour AV Screen F100 with UF
Onkyo TX-NR809
Emotiva XPA-5
Klipsch RC-64, RF-35, RCW-3, R-2650-W, RW-12d (2x)
Theater Room Build
aakrusen is offline
Old 01-15-2010, 07:30 PM
DMJ
DMJ's Avatar
That sucks. Did you get it fixed?
Dan
DMJ is offline
Old 01-16-2010, 07:41 AM
aakrusen's Avatar
Quoted: 14 Post(s)
It's at Mitsubishi right now. Hopefully I'll get it back within the week.
Panny AE8000U
Onkyo TX-NR809
Emotiva XPA-5
Theater Room Build
aakrusen is offline
Old 01-15-2011, 03:31 PM
Forceflow's Avatar
good luck. After 2 years of ownership, I finally replaced my bulb. What an adventure. Now I need to recalibrate and adjust. If someone gets a clicking noise after installing their bulb, either their bulb is bad or they didn't shove it into the unit fully. Try to shove (gently) more before freaking out and returning the bulb. Knock-off chinese bulbs seem to work as well as the original japanese one I got. Go figure.
***Warning*** Do not look into laser with remaining eye!!
Forceflow is offline
Old 01-15-2011, 10:47 PM
aakrusen's Avatar
Quoted: 14 Post(s)
I don't recall how fast I got the projector back from Mitsu but it has worked flawlessly ever since. I'm at about 1035 hours in a years' time so hopefully I won't need a new bulb for another 3-4 years.
Panny AE8000U
Onkyo TX-NR809
Emotiva XPA-5
Theater Room Build
aakrusen is offline
Old 01-16-2011, 07:31 AM
rgathright's Avatar
Quoted: 216 Post(s)
Liked: 26
I am having a lamp issue with my HC6000 similar to the ones in this thread. I have had this pj since 2008 and have sent it back to Mits twice. The issue is most of the time (there is no rhyme or reason) the lamp will not fire up fully when I start it. I usually have to turn the pj off and on several times to get it fired up. The first time I sent it to Mits service they was to change out a circuit board, but the problem came back again about 6 months later. The second time they changed the lamp, but the problem started up again a few months later. Instead of sending it back to Mits I just setup a routine to get it started.
Now that I have bought a new Mits lamp (same as the box that is shown in this thread) the startup is different. Now when the pj will not start up I turn it off and (after a minute or two) turn it back on. When I turn it back on it tries to start, but turns itself off instead after trying. No light at all comes out at all when I try the second time. What I do then is to unplug the pj and wait a few minutes and then try again. Most of the time it will start up full then.
Any ideas? I was hoping to keep this pj until the end of the year.
Sony XBR-75X850C - Living Room
Samsung UN60J6300AFXZA - Bedroom
rgathright is offline
