Brand New Sony VPL-VW50 (Pearl) In Hand! - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 830 Old 09-20-2006, 10:31 AM
juicelee's Avatar
Originally Posted by bigDvette View Post
Everyone keeps saying it is 700 lumen output, but every site claims 900 lumen output and the sony sight has nothing on this. The Ruby says 800 lumen output.
900 is the maximum according to spec. 700 lumens is after calibration according to the review at cine4home. That's actually not too bad because a lot of pjs rated at 1000+ lumens actually have much lower calibrated output (as low as under 50%).
juicelee is offline
post #362 of 830 Old 09-20-2006, 10:33 AM
Chako's Avatar
ARGH!
Must.....resist.......urge.....to.......buy...........
I got the upgrade bug
Still love my Sanyo Z4 and I still have me free extra bulb unused but man 1080p at half the price of the Ruby and HD-DVD xbox 360 attachment right around the corner is soooo tempting.
Chako is offline
post #363 of 830 Old 09-20-2006, 11:18 AM
ctviggen's Avatar
Quoted: 117 Post(s)
Liked: 33
700 after calibration is a ton. Usually, projectors spec'ed with 1000 get around 400 or so in HT mode after calibration.
Bob
ctviggen is offline
post #364 of 830 Old 09-20-2006, 11:20 AM
vdmai's Avatar
Originally Posted by Chako View Post
ARGH!
Resistance is futile . You will be assimmulated and become part of the collective.
Daniel
vdmai is offline
post #365 of 830 Old 09-20-2006, 11:26 AM
drapp1952's Avatar
Quoted: 14 Post(s)
Originally Posted by linesalomon View Post
If that's not a possibility, will this projector be watchable? I'm obviously new to projectors, so I apologize if this is a stupid question.
It's not a stupid question at all. It's a very important one for front projection setups. Yes, you'd be fine painting the walls a dark color - except maybe with your wife or S.O.
Calculating 700 lumens divided by 27 square feet multiplied by 1.3, you get about 31 foot-Lamberts. That'd be your initial brightness that'd drop to 15 ftL assuming the bulb loses 50% brightness at its endpoint. If all that's true, your overall brightness would be all right. The less light leaking onto the screen especially or into the room (at all, ideally) when watching front projection, the better.
You're simultaneous contrast would suffer some, due to light reflections from the light walls back to the screen lightening dark parts of an image that has both dark and light elements.
Dan
drapp1952 is offline
post #366 of 830 Old 09-20-2006, 11:49 AM
Erik Garci's Avatar
Last night I brought my Pearl over to a friend's place. He has a Ruby, and we compared them on the same screen, a 116"-wide High Power with 2.8 gain.
The first thing we compared was the convergence. A photo comparison is attached below.
This Pearl has very good convergence. Only red is off, to the right by half a pixel, which is consistent over the entire image.
This Ruby has much worse convergence. The left side of the image has red off by 2 pixels to the right of green, and blue off by 1 pixel to the right of green and also below. The right side of the image is better than the left side, since red is off by half a pixel to the right of green, but blue is still off by 1 pixel. The convergence seems to be worse than average for a Ruby.
I will post more findings later.
Erik Garci is offline
post #367 of 830 Old 09-20-2006, 11:51 AM
gremmy's Avatar
Not a stupid question at all. You will tend to have better ANSI contrast in a room with dark colored walls, so I highly suggest it.
Dark walls will also do a better job of absorbing any stray light leaking out of the projector or other light sources, like rope lighting in the walkways, which could impact on/off contrast.
In short, you're better off with dark walls. But yes, the picture will be watchable in a room with light colored walls.
gremmy is offline
post #368 of 830 Old 09-20-2006, 11:55 AM
velvetpoet's Avatar
Linesalomon -
It will be plenty bright. just for reference, I project an h30 on a 110 diagnal screen. The lumens are close to 400 and the gain of the screen is prolly a little under 1 (guessing because i built it myself).
I project it in my living room so as you can imagine my light controll gets as good as closing the blinds and its plenty bright. I watch Tv on it durring the day with little issue unless its a dark show.
Obvously im not a videophile =)
You could always get away with having two settings an uncalibrated setting and get 900 lumens out of the projector during the day and a calibrated one for night time viewing if you have light controll problems like myself.
velvetpoet is offline
post #369 of 830 Old 09-20-2006, 12:04 PM
gremmy's Avatar
If you've taken a bunch more pictures comparing these two machines, this is good enough to warrant its own thread.
gremmy is offline
post #370 of 830 Old 09-20-2006, 12:12 PM
linesalomon's Avatar
gremmy, velvetpoet, drapp1952, SOWK, and others:
Thank you all for you helpful posts. I really appreciate the info you've given me...it makes spending $5K a little easier.
linesalomon is offline
post #371 of 830 Old 09-20-2006, 12:16 PM
nathan_h's Avatar
Quoted: 1038 Post(s)
Liked: 625
Wow, those pictures make me feel VERY GOOD about my Pearl order. Here's hoping my unit is at least that well converged. Thanks for posting.
Any other impressions or comparisions between the two?
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
post #372 of 830 Old 09-20-2006, 12:19 PM
romanesq's Avatar
http://www.soundandvisionmag.com/fea...ts-part-1.html
For example, Sony debuted its VPL-VW50 projector, a sleek SXRD-based model with 1080p resolution. The company actually drew cheers from the audience when it announced the price: $5,000. It joins Sony's two existing 1080p SXRD front projectors, the Qualia 004R1 and the VPL-VW100. The VPL-VW50 boasts a new single-chip video processing engine, enabling the use of an all-digital chassis, which the company says eliminates signal noise caused by analog-to-digital or digital-to-analog conversion. It also sports dual HDMI inputs with 1080p support at both 60 and 24 frames per second.
It's all just a game. I just play to win.
romanesq is offline
post #373 of 830 Old 09-20-2006, 12:20 PM
Rob Tomlin's Avatar
Wow! Huge difference in convergence! Round 1 goes to the Pearl!
Rob Tomlin is offline
post #374 of 830 Old 09-20-2006, 12:26 PM
Grubert's Avatar
Useless question:
What size is the box it comes in?
Freedom is the freedom to say that two plus two make four. If that is granted, all else follows.
-George Orwell, Nineteen Eighty-Four
Grubert is offline
post #375 of 830 Old 09-20-2006, 12:33 PM
SOWK's Avatar
Quoted: 481 Post(s)
Liked: 383
GOD I hope my convergance is that good! if not better!
I HOPE I HOPE!
I'm Praying!
SOWK is offline
post #376 of 830 Old 09-20-2006, 12:37 PM
Erik Garci's Avatar
I only have one more photo. It shows a fullscreen white image on the Pearl. I went ahead and attached it below.
There is some slight color shifting. It is slightly greenish along the top of the image, and it gradually becomes pinkish towards the bottom.
post #377 of 830 Old 09-20-2006, 12:38 PM
SOWK's Avatar
Quoted: 481 Post(s)
Liked: 383
SOWK is offline
post #378 of 830 Old 09-20-2006, 12:38 PM
Rob Tomlin's Avatar
Ugh. That pink at the bottom is quite noticeable. Let us know if you can see this while viewing a bright image.
post #379 of 830 Old 09-20-2006, 12:42 PM
Tom Bley's Avatar
Quoted: 600 Post(s)
Liked: 533
Reminds me of my old Sony VPL-400Q LCD projector pink in one corner and green ish in another. I mostly noticed it in black and white sequences or movies, well, maybe a little in dark scenes as well.
Tom Bley is online now
post #380 of 830 Old 09-20-2006, 12:44 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
Will be very interested to hear how the brightness of the Pearl handles this very large (133"diag) highpower. If you are indeed getting 700 lumens out of the pj, and you have it set in the optimum position, this amounts to 37 ftL--which ought to be BRIGHT!
millerwill is online now
post #381 of 830 Old 09-20-2006, 12:46 PM
Ohlson's Avatar
I am not surprised if wm ports his shading tool to work on Pearl.
A single Ruby and a single Pearl is not a very big sample.
Mattias Ohlson
Ohlson is offline
post #382 of 830 Old 09-20-2006, 01:24 PM
John Ballentine's Avatar
Originally Posted by SOWK View Post
Is it noticeable during a movie?
It sure would be during a B&W film. Less so on a color film. My Panny 700 has shading issues like this.
SOWK - you must be a nervous wreck (w/ anticipation)
John Ballentine is offline
post #383 of 830 Old 09-20-2006, 01:26 PM
gremmy's Avatar
Well, we've seen two different Pearls with white-fields posted. And both have had color uniformity problems. Of course, the picture of the unit at CEDIA was much worse than this.
I am very sensitive to this sort of color discontinuity. We need everyone who buys one of these to post a whitefield picture so we can get a bigger sample. Sony seems to have trouble getting this ironed out in their lower cost units. For me it's a big deal. For others it may not be.
The thing about these color shift issues in SXRD is that there is a history in the RPTVs of the issue getting worse over time on some sets.
gremmy is offline
post #384 of 830 Old 09-20-2006, 01:39 PM
I don't think Andrew P or djzelos reported any color discontinuity (shading) issues w/ their new Pearls. Unless I missed it.
post #385 of 830 Old 09-20-2006, 01:45 PM
Erik Garci's Avatar
The Pearl's "Low" color temperature setting is already very close to D65 out of the box. It was measured by ColorFacts at 6490K, only about 1 or 2 % too green.
To calibrate to D65, we used the "Custom3" setting (which starts out similar to "Low") and ended up with the following.
Gain: R = 1, G = -2, B = 3
Bias: R = -4, G = 8, B = 0
After calibration, it was within 50K of 6500K from 30 IRE to 100 IRE.
The calibrated brightness was measured with a light meter. "High" lamp power gives 576 lumens, and "Low" gives 382 lumens. (By the way, the fan noise changes to a lower pitch when you switch from "High" to "Low", but it did not seem to be any quieter.) By comparison, the Ruby has 283 lumens, although there are 870 hours on its Xenon lamp, and less than 5 hours on the Pearl's UHP lamp.
To test inverse telecine (IVTC) on 1080i, we used the vertrezivtc test pattern (see other thread) over DVI/HDMI from a HiPix HDTV card. When the Pearl's DDE setting is "Film", the top strip is fully resolved as the white bar moves across it, which suggests that inverse telecine works properly for 1080i. When DDE is "Progressive", the top strip is fully resolved except that the white bar has jagged edges and a black trail, which suggests that a motion adaptive deinterlacer is being used, but without inverse telecine. When DDE is "Off", the top strip becomes a flickering gray area, which suggests that a simple "bob" deinterlacer is being used.
We also tested 1080/48p and 1080/24p signals over DVI/HDMI from an iScan VP30. The Pearl can display both at their native frame rate (i.e, without converting them to another frame rate, such as 60p). However, 24p showed tearing along the bottom 5% of the image, although it is unclear whether the iScan or the Pearl is causing it. In any case, the tearing can be covered up by using the Pearl's Blanking feature, and it is not noticeable on letterboxed 2.35:1 images. By comparison, the Ruby can display 48p natively, but it cannot display 24p at all.
Another difference is the colors. The Ruby's colors appear to be somewhat more vibrant overall. In particular, skin tones are rosier on the Ruby, but more yellowish/greenish on the Pearl. I'm not sure which are more accurate, but I prefer them on the Ruby. It might be worthwhile to experiment with the Pearl's RCP feature to tweak the skin tones.
post #386 of 830 Old 09-20-2006, 01:52 PM
SOWK's Avatar
Quoted: 481 Post(s)
Liked: 383
You answered many questions people were having in this one post, thank you!
SOWK is offline
post #387 of 830 Old 09-20-2006, 01:55 PM
Erik Garci's Avatar
I did not notice the color shifting during the movies, although none of them were black & white. I only noticed it on the test patterns.
post #388 of 830 Old 09-20-2006, 01:59 PM
Quoted: 64 Post(s)
Great info. I think I may have even understood some of it.
Any chance of taking a screen-shot of the Ruby and Pearl paused on the same scene (with the camera on a tripod and in manual mode to eliminate any differences there) so we can compare?
-tony
tbacos is offline
post #389 of 830 Old 09-20-2006, 02:01 PM
gremmy's Avatar
No, I don't believe they did.
Andrew and djzelos, if you guys plan on posting any more pictures, could you include one of a white-field? Thanks guys!
gremmy is offline
post #390 of 830 Old 09-20-2006, 02:05 PM
Gary Lightfoot's Avatar
Quoted: 666 Post(s)
Liked: 404
Great info Eric, thanks.
Can you take a spectral scan of both the Ruby and Pearl while they are at D65 and post the images for us to see? I was going to do something along similar lines with the pj with and without fl-day filter, but then found my colorimiter can;t do that (I need a spectroradiaometer like the GMB).
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is online now
