The Official Sony VPL-VW50 (Pearl) Calibration/Tweak Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 623 Old 10-04-2006, 11:26 AM
gremmy's Avatar
Originally Posted by nathan_h View Post
I haven't seen this? What input using what as a source? Running test patterns into the PEARL from a 1080i source (HD-DVD home burned test patterns input from a Toshiba HD-DVD via HDMI) and setting sharpness to zero, I see no outlining at all.
I'm running all inputs via component, and I see the effect on all inputs. This is one of the things that they tested for in the Cine4Home review -- I can't remember the test results.
Is setting sharpness to zero really the recommendation? Does that destroy any "real"detail on an LCOS device?
gremmy is offline
post #92 of 623 Old 10-04-2006, 12:06 PM
gremmy's Avatar
Nice fine. I owe you 2 dollars and a biscuit!
I sent a PM to Erik asking for his color saturation, hue, and other settings.
gremmy is offline
post #93 of 623 Old 10-04-2006, 12:09 PM
toddbee's Avatar
gremmy,
can you post them when you get them?
toddbee is offline
post #94 of 623 Old 10-04-2006, 12:12 PM
gremmy's Avatar
Originally Posted by toddbee View Post
gremmy,
Sure, no problem. Or maybe luck will lead Erik in here to deliver the info to all of us personally.
gremmy is offline
post #95 of 623 Old 10-04-2006, 12:19 PM
gremmy's Avatar
Can someone explain to me the definition of "gain" and "bias"?
gremmy is offline
post #96 of 623 Old 10-04-2006, 12:28 PM
drapp1952's Avatar
One really KISS operational answer is bias controls affect low IREs and gain affects higher ones. There are, of course, more complete or advanced definitions.
http://www.poynton.com/notes/brightness_and_contrast/
Dan
drapp1952 is offline
post #97 of 623 Old 10-04-2006, 12:39 PM
shodoug's Avatar
In general, if you understand algebra and the standard formula of a line (y=mx+b), the gain is the slope of the line (m) and the bias is the offset (b) when x is zero.
So if you have an error where all numbers are 5 too low, you would increase the bias to shift the line five spots higher.
If you have an error where the answer is correct at the zero crossing, but deviates steadily as you get farther away from it, then you want to adjust the gain.
If you have both errors, you adjust the zero corssing and then the gain.
In practice, it is not always that easy, because you cannot always get data at the zero crossing.
Also, somtimes the controls are not truly independent, and when you adjust the bias it slightly changes the gain, and/or vice versa.
Sometimes you go back and forth between two points, adjusting bias and gain until you approach a good enough solution.
I have very little experience with adjusting a pj, but that is what gain and bias are, in general. I just hoped that a very general overview of gain and bias might be helpful.
If it is not, don't worry about it. I am sure others can give very good descriptions of what to do with gain and bias in particular, when adjusting a display device.
Best Regards,
Doug
shodoug is offline
post #98 of 623 Old 10-04-2006, 12:47 PM
gremmy's Avatar
Best Regards,
Doug
From a mathematics point of view, this makes sense to me. Without fancy meters and other gadgets, I probably am at the mercy of tinkering with other people's settings to see how they look. Thankfully, I can always reset to the defaults.
gremmy is offline
post #99 of 623 Old 10-04-2006, 01:08 PM
nathan_h's Avatar
Quoted: 1640 Post(s)
Liked: 1084
On the HDMI input, I don't see any loss of detail when setting sharpness to zero. I haven't tried the component input, yet.
My current setup.
My favorite movie review podcast, the Next Picture Show.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is offline
post #100 of 623 Old 10-04-2006, 01:11 PM
toddbee's Avatar
i have found the component input to be very good on the pearl. can someone give me there experience component vs. hdmi?
toddbee is offline
post #101 of 623 Old 10-04-2006, 01:15 PM
shodoug's Avatar
I believe that you can use different patterns to determine what to adjust, but that is just what I have always supposed.
Best Regards,
Doug
shodoug is offline
post #102 of 623 Old 10-04-2006, 01:18 PM
drapp1952's Avatar
From the Cine4Home.com Pearl review:
3.9.1 Signal processing
The signal processing must convert the incoming analog and digital picture signals, and if necessary convert the analog signal to digital before the signal processing. Annoying double outlines are to be avoided.
With analog feeds, the signal processing of the VW50 visibly tends to show double outlines (screen shot above), but they can be clearly improved using the Sharpness adjustment, without sacrificing sharpness. The results are intrinsically better when a digital signal is fed:
Here the double outlines are very subtle from the factory, however they can not be adjusted with a HDMI input signal. During movie operation, no annoying outlines are visible.
Dan
My Edit: Service menu adjustments might address remaining subtle double outlines with a HDMI input.
post #103 of 623 Old 10-04-2006, 01:24 PM
gremmy's Avatar
gremmy,
Drumroll Please...
And the answer is:
Erik left his color saturation, contrast, and hue at the default settings. 80, 50, 50.
gremmy is offline
post #104 of 623 Old 10-04-2006, 01:46 PM
nathan_h's Avatar
Liked: 1084
Dan
Hmmm. I don't recall seeing those outlines when feeding the Pearl 1080i from HD-DVD, or 1080p from an HTPC. I'll have to check again.
My current setup.
nathan_h is offline
post #105 of 623 Old 10-04-2006, 01:50 PM
sage's Avatar
I think you're probably asking in relation to R, G, B settings for each. On the Sony professional CRT on my desk, Bias is the low IRE part of the curve and Gain is the high IRE part of the curve. Now, that said, there is quite a bit of interaction between them. (Think curve, not shelf). I would presume that the Pearl uses the same language as the my reference display at work.
Very short answer: these are the controls that you use to set the grayscale.
sage is offline
post #106 of 623 Old 10-04-2006, 03:01 PM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 43
Will this mount work with the Pearl? Mount
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
post #107 of 623 Old 10-04-2006, 03:19 PM
shodoug's Avatar
From the link...
"Weight capacity: 25 lbs"
Isn't the Pearl 30 lbs?
Best Regards,
Doug
shodoug is offline
post #108 of 623 Old 10-04-2006, 03:22 PM
mblank's Avatar
My baby weighed in at 24 pounds, 4 ounces.
Marc
mblank is offline
post #109 of 623 Old 10-04-2006, 03:33 PM
drapp1952's Avatar
Drumroll Please...
And the answer is:
That confirms recommendations to keep these controls where they are.
But how about color temp? What are his RGB bias and gain settings? (OK, all you calibration-savvy AVSers, what's wrong with these questions and which is most dangerous?)
Dan
post #110 of 623 Old 10-04-2006, 03:37 PM
sage's Avatar
Marc
And was it delivered by a guy in brown shorts?
sage is offline
post #111 of 623 Old 10-04-2006, 03:52 PM
shodoug's Avatar
Marc
that is a little too close to maximium for me.
I am more careful than most.
The chief mount that Jason sent ahs a max spec of 50 lbs.
Best Regards,
Doug
shodoug is offline
post #112 of 623 Old 10-04-2006, 04:14 PM
gregr's Avatar
Quoted: 20 Post(s)
That one is the most dangerous. Particularly on a projector with a dynamic iris. It is not like adjusting a projector with a fixed iris. Unless you have the equipment and experience at adjusting grayscale, and are ready to learn new methods to do it with a dynamic iris, I suggest you leave it alone. In any event, knowing what worked for someone else, assuming it really worked for someone else, won't help you unless many other things (service level adjustments) are also adjusted the same on both projectors, the lamps are the same, age the same, etc.
Greg Rogers
Video Engineer/Product Designer
gregr is offline
post #113 of 623 Old 10-04-2006, 04:55 PM
toddbee's Avatar
gremmy,
what component are you feeding with these new settings? eg. dvd player? hdmi?
toddbee is offline
post #114 of 623 Old 10-04-2006, 05:58 PM
toddbee's Avatar
yeah those setting look amazing on the component input. for some reason the hdmi input seems slightly less saturated and a hair to the green yellow side. not sure why. possibly the different process going on.
toddbee is offline
post #115 of 623 Old 10-04-2006, 06:02 PM
nathan_h's Avatar
Liked: 1084
You mean after using the suggested settings, your HDMI performance was worse than before you started? Or it just didn't improve as much as the component input performance, but was still better than before the settings change?
My current setup.
nathan_h is offline
post #116 of 623 Old 10-04-2006, 06:55 PM
toddbee's Avatar
color seem slightly different via hdmi. i dont know why. a slight green push overall
toddbee is offline
post #117 of 623 Old 10-04-2006, 07:12 PM
nathan_h's Avatar
Liked: 1084
sorry to be obtuse, but do you mean the color is slightly different between component cf hdmi, or color via hdmi is different now (after the tweak) from where it was before and it has gotten worse (after the tweak)?
My current setup.
nathan_h is offline
post #118 of 623 Old 10-04-2006, 08:35 PM
gremmy's Avatar
I don't know if the settings should be different for HDMI or not, but I can say one thing with absolute certainty. As far as I'm concerned, these settings are the definitive settings (even if it turns out to be restricted to component input). I just watched Dexter and Weeds on Showtime HD, and it was the very first "looking through a window" experience I've ever had on any display device in my home. Totally amazing.
Maybe we should add them to the original post?
gremmy is offline
post #119 of 623 Old 10-04-2006, 09:02 PM
nathan_h's Avatar
Liked: 1084
Hmmm. Okay, I'll give them a try, once the machine starts being nice, again. For some reason, the left side of the screen now has a few bands of vertical lines. Should cycle the power and see if that helps!
My current setup.
nathan_h is offline
post #120 of 623 Old 10-04-2006, 09:18 PM
gremmy's Avatar
Good lord. What the heck *is* that?
I hope it goes away!
gremmy is offline
Sony Vpl Vw50 Sxrd 1080p Home Theater Front Projector
