Firehawk vs. StudioTek 130 and room reflections? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
Old 01-05-2007, 08:27 AM
AVS Club Gold
J.Mike Ferrara's Avatar
Quoted: 151 Post(s)
Liked: 179
Originally Posted by GlenC View Post
Depends, if you have 6 people wearing white there will be more reflections, if they wear black, probably a non-issue.
LOL!!!
I can see it now - STRICT DRESS CODE for my home theater.
J.Mike
Those who die with the most toys ... are still dead!
J.Mike Ferrara is offline
Old 01-10-2007, 02:00 PM - Thread Starter
lovingdvd's Avatar
Quoted: 1653 Post(s)
Liked: 269
I recently spoke with Don Stewart to get his opinions on this as well. In summary his recommendation was to stick with the Firehawk, even though it would cost him a sale.
He was saying that despite the great advancement in black levels in pjs recently, that if I put up an ANSI checkerboard pattern and held up a piece of StudioTek material half way in one of the dark squares, that I would be surprised to see how much lighter the black level was on the ST material compared to the FH.
His main point was that people do not have a very good reference for bright white in their mind and have a hard time judging bright white without a simultaneous direct comparison to something even brighter. And that on the contrary, people do know what dark black looks like without any such reference.
He was saying that for his tastes at least, for home viewing he would rather have blacker looking blacks because the better black level is more satisfying since it is easily identifiable as such, whereas the whites will still look bright white even if they are a bit dimmer than they would appear on the StudioTek (and you wouldn't realize a difference, whereas with brighter blacks you would).
He also felt like the StudioTek would no doubt lower my ANSI CR and intra-scene CR compared to the Firehawk despite my room treatments unless it was close to a total bat cave (which I do not have).
Considering how much effort I've put into making adjustments to the room (velvet, rugs etc) to bring up my ANSI and intra-scene CR, and his point about having a bit better blacks with the Firehawk I've decided for now at least to stick with the Firehawk. Fortunately this is the cheaper option!
lovingdvd is offline
Old 01-10-2007, 02:49 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 145 Post(s)
Liked: 125
Thanks for posting his input. I feel better now. I had a similar albeit less experienced opinion and this thread was making me doubt my own eyes.
GetGray is offline
Old 01-10-2007, 08:20 PM
wm
wm's Avatar
Location: Spaceship Earth, usually on the California deck
So your choice then is all based on the blacks, and nothing about the color and saturation and the rest of the things that make up a good picture. This makes me very sad. Based on that argument we should all have grey screens! I have a great deal of respect for Don and his product, but in this case I think he's very wrong.
I wish I could show you what I see with a white screen.
wm_avs6 (at) meier-phelps (dot) com (Note - new address! Please do not use AVS PM)
Optimized by William PhelpsÂ
wm is offline
Old 01-10-2007, 08:29 PM - Thread Starter
lovingdvd's Avatar
Liked: 269
Thanks for the input William. Since I take my calibration measurements off the screen (or at least based on a trained meter that was based off measurements at the screen), is it possible that I have calibrated my color and saturation etc to counter-act the affects of the screen?
The other key deciding factor was related to ANSI CR and intra-scene CR that I've been working so hard to maximize. I know you feel that takes a lower priority to these other characteristics. However I just don't want to take a chance that I'll be "undoing" so much of my hard work to try and get the reflections under control. My room is in good shape now reflection control-wise, but far from a cave.
Old 01-10-2007, 08:34 PM
Catdaddy67's Avatar
Ric,
Have you considered the Silverstar? Or is it a non-consideration for you because of how reflective it is of direct ambient light?
Mike
Catdaddy67 is offline
Old 01-10-2007, 08:49 PM - Thread Starter
lovingdvd's Avatar
Liked: 269
I understand the SilverStar also has an elevated black level and also some sheen to it. I'm very happy with the FH and content sticking with it. It'll be PLENTY bright for my tastes even with an aged lamp for the RS1 (106" diag FH should get 25-30ftL on a new bulb with the RS1 in high lamp mode).
I was mainly looking into the StudioTek because I heard the better black levels for current pjs are negating the need to get help from the screen in this regard.
But if the blacks are really getting as black as what Tryg was reporting on the RS1, I may need to rethink this eventually. My plan for now is to be content with the FH. Then once I have my RS1 I'll try some experiments with StudioTek samples to see just how elevated the black level looks with some fairly low level APL scenes and the ANSI CR pattern and go from there.
Old 01-10-2007, 09:07 PM
Catdaddy67's Avatar
That sounds like a great idea. I wish I still had my old firehawk screen, but I sold it off when we moved to Dallas while we were having our new house built (before it fell through because of a contract contingency.) 8(
Oh well, I am more than likely gonna want a bigger screen anyways.
Old 06-02-2013, 08:28 AM
Pawellang's Avatar
http://www.youtube.com/watch?v=EE_dRPoh8J0
This video shows differences between these screens. Please note that HT in which they showed it had light walls and ceiling.
Pawellang is offline
Old 06-02-2013, 09:49 AM
Seegs108's Avatar
Quoted: 3771 Post(s)
Liked: 1770
You realize that no one has posted in this thread for over 6 years, right? tongue.gif
Seegs108 is online now
Old 06-02-2013, 10:22 AM
Pawellang's Avatar
Yes indeed :-)
I am also a person who has a problem with choosing a right screen and I found this post via google. Although it is so old it might be still helpfull for people who are looking for a solution ;-)
Old 06-02-2013, 01:34 PM
wm
wm's Avatar
Why anyone would even consider a grey screen given today's projectors is beyond my understanding.
William
wm is offline
Old 06-02-2013, 03:26 PM
mark haflich's Avatar
Quoted: 1416 Post(s)
Liked: 1006
Hey William. Nice to see you posting here. What are you up to now?
mark haflich is offline
Old 06-06-2013, 10:18 AM
Home Theater Lover!
Craig Peer's Avatar
Quoted: 2556 Post(s)
Liked: 2335
William
While I would have to agree with you that compared to a white screen, a grey screen will have compromised colors and whites, if your watching a projector in a a white room with some lights on ( a typical senario for using a grey screen ), you're already compromising the picture. So, you choose your poison so to speak. Especially if your wife says black walls and ceilings = divorce ! eek.gif
AV Science, Inc. Direct (585) 671-2972 craig@avscience.com www.avscience.com Like us on Facebook
Epson 5040 / 6040 now available The new JVC RS4500 available for pre order !
JVC RS400 500 600 Cedia Special pricing - call !
Craig Peer is offline
Old 06-06-2013, 10:44 AM
Pawellang's Avatar
I got samples of ST130, GrayHawk and Firehawk from Stewart dealer.
I really was toward the ST130, but when I saw difference in black with FH I couldn't accept it (although colors and white looked much better on ST130).
As Craig wrote above my wife said "Black walls and ceiling = divorce" smile.gif
I cannot wait a day when I'll create a dedicated HT room (black cave) and put ST130 inside it frown.gif
Old 06-06-2013, 02:49 PM
Home Theater Lover!
Craig Peer's Avatar
Liked: 2335
Yes, but until that comes, enjoy a pretty damn decent picture on a Firehawk. I'd rather have a not perfect home theater than no home theater. smile.gif
If I ever become homeless, look for a guy pushing a shopping cart with a projector mounted to it along with a Honda 1000 generator. That will be me, shining The Big Lebowski on the side of a building - refusing to give up my home theater - no matter what ! eek.gif
Old 06-06-2013, 02:51 PM
ivanhoek's Avatar
Liked: 24
LOL.. that's actually a pretty disturbing mental picture :-)
Well done.
ivanhoek is offline
Old 06-06-2013, 03:20 PM
Liked: 1006
My picture is you free climbing a Yosemite Decimal System 13.4d plus rock wall with a Sim2 Lumis strapped to your back.
Old 06-06-2013, 05:15 PM
Home Theater Lover!
Craig Peer's Avatar
Liked: 2335
Maybe I'll haul that shopping cart up like Warren Hardings " Dolt Cart " and show Capt. Kirk climbing El Cap.....on El Cap !!.
