What are the best 720p projectors for ambient light? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-03-2007, 01:58 PM - Thread Starter
Desmond34's Avatar
I have wooden blinds, so I have some ambient light. It's for a 100 inch 16:9 screen.
What are the best 720p projectors?
Desmond34 is offline
post #2 of 10 Old 01-03-2007, 03:32 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Sim2 C3X, Infocus 777, C3X Lite would probably work fine with that size screen. Pricey though.
GetGray is offline
post #3 of 10 Old 01-03-2007, 11:20 PM
dangc's Avatar
Panasonic AX100 is the only affordable choice which I know is below the price of this forum but just wanted to suggest it.
I use this projector in fairly high ambient light and it can fight through it, even with direct sunlight shining from the back of the room onto the screen when watching bright vivid HDTV programming.
For movies however, please don't expect to have a great picture with ambient light as it simply destroys the blacks and washes out dark scenes and no amount of lumens will help that. A gray screen with extra lumens will help but still not great...
Look in the <$3000 forum for plenty of information on this projector.
dangc is offline
post #4 of 10 Old 01-04-2007, 12:23 AM
Xylon's Avatar
The last two generations of Panasonic 720p LCD PJs and also the Infocus IN76 (pricey unfortunately). These PJs are what I call "Torch projectors".
Xylon is offline
post #5 of 10 Old 01-04-2007, 04:55 AM
Wet1's Avatar
I'm yet to see any FP that's worth a crap when direct sunlight is hitting the screen... period.
With that said, dangc has a valid recommendation with this PJ... it offers a lot of bang for the buck and is quite impressive. The other one I'd suggest you look into is the Mits HD1000U. The HD1000U is basically just a bright as the AX100 in real world use and offers a picture that's nearly as good (the AX100 does have slightly better black levels because it has a DI... which is a trade-off in itself). The real beauty of the HD1000U is it can be bought for under $900!!! Don't let the price fool you though, it's a very impressive PJ that just happens to be very inexpensive... Don't write it off until you've seen it, it's that good! I can say the same about the AX100, but for half the price the HD1000U is hard to pass up. The AX100 is certainly a more flexible PJ as it has a lot more bells and whistles, but if you don't need the lens shifting and powered features, the HD1000U is a far better deal.
Here a review that's worth reading which gets into more details if you're interested:
http://www.projectorreviews.com/Manu...000U/index.asp
Sorry, I didn't mean to get into a less than $3000 discussion in this forum, but I think many just assume that PJs in the <$3000 forum just aren't worthwhile to even consider (and I WAS one of those people) until they've seen what the star performers can really do. The AX100 and the HD1000U are both very bright PJs that throw a great picture, the same can't be said for a lot of more expensive models...
Wet1 is offline
post #6 of 10 Old 01-04-2007, 05:54 AM
Pedro2's Avatar
Try the epson 810. Should be plenty bright, and impressive PQ.
Pedro2 is offline
post #7 of 10 Old 01-04-2007, 07:14 AM
DanHouck's Avatar
Quoted: 64 Post(s)
Combine one of the bright projectors with a screen that does a good job of rejecting ambient light like the Firehawk. Works for me.
My HT is an oldie but goodie!
DanHouck is offline
post #8 of 10 Old 01-04-2007, 01:16 PM
Will Binegar's Avatar
Liked: 29
The Infocus 7210 doesn't seem to have been mentioned, so I'll lob it in. Among single chip 720p DLPs, it's probably at or near the top in terms of brightness, and it's reputed to have very good grayscale and colors right out of the box.
Will Binegar is offline
post #9 of 10 Old 01-04-2007, 04:55 PM
Scott Gammans's Avatar
Don't forget the InFocus 333!
Scott Gammans is offline
post #10 of 10 Old 01-04-2007, 06:03 PM
ac388's Avatar
Quoted: 118 Post(s)
Liked: 41
Don't forget the Mit. HC3100 too !!!
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
