Mitsubishi HC5000 set for Enhanced or Normal? - AVS Forum
post #1 of 4 Old 01-09-2007, 02:58 PM - Thread Starter
70MM's Avatar
The black look fantastic on the HC5000 if I have it set to normal but I cant get a full grayscale in. If I set it to Enhanced I get the complete grayscale but loose the lovely blacks. What are others using please?
Thanks in advance
70MM is offline
post #2 of 4 Old 01-09-2007, 04:07 PM
briandx's Avatar
Normal, but I did not get a chance to experiment much with this setting. Hopefully when my new unit (without horizontal banding) arrives I'll check into it more.
briandx is offline
post #3 of 4 Old 01-09-2007, 05:30 PM - Thread Starter
70MM's Avatar
Let me know then if you can get a full grayscale through normal as I cant!
70MM is offline
post #4 of 4 Old 01-10-2007, 02:35 AM
capitano's Avatar
I too use enhanced to get full grayscale with my HTPC (TT2)
Which source do you use?
capitano is offline
User Tag List
