JVC DLA-RS1 Owner's Thread - Page 292 - AVS Forum
post #8731 of 8757 Old 04-22-2014, 06:45 PM
buggdog's Avatar
I bought my last oem replacement bulb from avs. I was thinking of trying one of the Osram bulbs instead of the oem bulb. I PM'd GlennC but not sure if he is still on the forums. he previously conducted the bulb upgrade if you sent him the old housing and bulb.
buggdog is offline
post #8732 of 8757 Old 04-23-2014, 12:33 AM
Buttabean's Avatar
Liked: 24
I've probably gone through 10 bulbs on my RS1. About 2 bulbs a year. Well over 14k hours on it and still works great. I noticed by running the projector in high altitude mode I never have a bulb flicker on me. They seem to last longer and stay bright longer as well.
BUT after changing the bulb so many times and having my fair share of them blowing up, I'd like to try converting it to a LED light source for shits and giggles. Anyone know which wire would allow me to trick the circuit board into thinking that the bulb is fine and then boot up properly? I might need to add a resistor so it tricks the computer into thinking it has a regular working bulb in the path. The resistor would create the same voltage reading as a regular working bulb.
I'm thinking if I can get it to run without a bulb, I can insert an LED with an external power supply. I know it's possible with other projectors as I've seen people do it on youtube with crappy old projectors. I'm curious what kind of light output the RS1 would yield because it has an interesting prism that seems optimized opposed to the ones i've seen converted.
Joe.T
Buttabean is offline
post #8733 of 8757 Old 04-24-2014, 09:56 AM
dla26's Avatar
Interesting. I'm completely in the minority in that I've been using the same bulb on my RS1 since I got it used in 2008 or 2009. I'll have to check how many hours are on it, but I'd say on average I use it about 2 hours/day virtually every day. The picture still looks good to me, but I'm wondering if I were to replace the bulb if the picture would suddenly improve significantly. On the other hand, I keep thinking, if it ain't broke, don't fix it.
dla26 is offline
post #8734 of 8757 Old 04-24-2014, 10:40 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 313 Post(s)
Liked: 406
I would not let the lamp manufacturer's know. They will send someone over to take a hammer to your lamp, since it should have died a while ago. smile.gif RS1 was a great projector in it's time. Many people are still running them. smile.gif
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Brands we sell:
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon & many more.
RBH, Martin Logan, Triad, Atlantic Technology, MK Sound, BG Radia, SVS & Def Tech.
AV Science Sales 5 is online now
post #8735 of 8757 Old 04-24-2014, 11:03 AM
Lylepdx's Avatar
Original RS1 power buy owner. This has been a great projector value after years of upgrade-itis.
I was interested in the Darby comment. What is it and how does it help the RS1? (I'm sure I can search for it but a simple reply would be appreciated smile.gif )
Thank you
Don't lose sight of the Big Picture
Lylepdx is offline
post #8736 of 8757 Old 04-24-2014, 11:43 AM
AVS Club Gold
Quoted: 313 Post(s)
Liked: 406
Thank you
The Darbee is a video image processor. It improves the sharpness and contrast of the image. It really works and would be a good addition to an RS1. Call us if you would like to ask questions or order. I have been using one for nearly 2.5 years.
Email Me:
Brands we sell:
post #8737 of 8757 Old 05-13-2014, 11:38 AM
chriscic's Avatar
My $150 YA purchase of an OSRAM replacement bulb has turned out to be pretty much a failure. 660 hours and it's really dim now on high mode. I guess it's not exactly a terrible failure though given that it was less than half the price of an OEM bulb, the last of which for me lasted >2000 hours.
I see Newegg is selling what is advertised as an OEM JVC bulb for $259. Think I'll go that route next.
Still love my RS1 See no reason to upgrade until 4k.
chriscic is offline
post #8738 of 8757 Old 05-13-2014, 11:52 AM
techman707's Avatar
What is the "rated hours" on the bulb you bought that you say was half the price of the OEM bulb?
I know going back 40 years, when it came to xenon bulbs, Osram was THE BULB for theatres, the rest were all junk! However, the Osram xenon bulbs today appear no better than any other brand. I don't have enough experience to comment on the type bulbs used in the JVC D'ILA projectors.
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." -Ghandi
techman707 is offline
post #8739 of 8757 Old 05-13-2014, 02:19 PM
chriscic's Avatar
I don't believe the non-JVC bulbs even come with a rated hours quote. Probably a good reason for that. On the Planetbulb website where I bought my OSRAN, JVC original rated at 2000, nothing listed for OSRAM and Philips replacements
chriscic is offline
post #8740 of 8757 Old 05-14-2014, 12:33 AM
techman707's Avatar
The Osram bulbs definitely have a rated hour figure. You can probably email Osram and get the answer. What is probably MORE interesting is what the Luman output is over the "claimed" rated life.
post #8741 of 8757 Old 05-17-2014, 07:00 PM
firebrick's Avatar
Still on my first bulb on my fpj1. Great projector.
firebrick is offline
post #8742 of 8757 Old 05-22-2014, 04:58 PM
CorvetteC5's Avatar
Buttabean, any progress on this lamp substitute? An LED light source is one of my criteria for the projector that will replace my RS-1, and if I had the know how to help you with this then I would. rolleyes.gif What are you finding for a bright LED light source? Anything promising?
CorvetteC5 is offline
post #8743 of 8757 Old 05-23-2014, 09:51 AM
Buttabean's Avatar
Liked: 24
I've been too busy to work on it. Also my helper(brother) broke his foot so i've put it on hold for a few weeks.
Joe.T
post #8744 of 8757 Old 06-26-2014, 03:35 PM
sambou812's Avatar
Talking jvc dla-rs1x parts
i don't know why but i just bought an dla-rs1x i didn't need anymore projectors .
i demo'd one once but ended up going for the Mitsubishi's because of cost
i found one cheap with 640 hours on the projector it self still has the original bulb it came with.
well this one has a problem according to the seller its not accepting input so now i'm on the parts hunt,i would like to start with an input board or maybe a parts machine?
if you have anything parts wise drop me a pm
thanks
sambou812 is online now
post #8745 of 8757 Old 06-26-2014, 07:34 PM
Larry J's Avatar
The Philips Version appears to hold up better than Osram in the RS1 & 2. I don't know why since both companies are usually better than the other's. Its a little harder to find and cost more, especially one that's not fake. It is brighter than the original. Iwasaki (HSCR) made the original JVC, no idea if they still do or not.
It's rare for either one to list hours on just the bulb itself but if they did I'm sure it would be at least equal to the Iwasaki.
Larry J is offline
post #8746 of 8757 Old 06-27-2014, 07:36 AM
sambou812's Avatar
this is the cheapest price i have found on an original bulb.
http://shop.avscience.com/JVC-BHL500...amp_p_353.html
if you have the bulb specs you can find new old stock iwasaki lamp cores at this website.
https://www.interlight.biz/Search.int
post #8747 of 8757 Old 06-27-2014, 08:10 AM
sambou812's Avatar
i like to look at the ballast to see what its capability's are ac/dc pvip uhp nsh ect then get physical measurements of the stock lamp and go from there .
post #8748 of 8757 Old 07-05-2014, 10:40 PM
nebrunner's Avatar
Liked: 26
1100 hours on my JVC bulb purchased from AVS and it just started flickering on me tonight. I switched to high lamp mode and the flicker goes away but the fan noise is brutal on high. Is the flickering a sign of the end of bulb life? I was hoping to get another 900 hours on this thing.
My perpetual home theater build -
nebrunner is offline
post #8749 of 8757 Old 07-06-2014, 09:55 AM
frg
frg's Avatar
No panic, it is well known that this bulb starts flickering for an hour or two a few times during its life. This does not affect its total lifetime.
Envoyé de mon LT26i en utilisant Tapatalk
frg is offline
post #8750 of 8757 Old 07-19-2014, 01:40 PM
Liked: 0
I've had my DLA-RS1 since 2008. Replaced the bulb twice now.
But I have completely forgotten how I should know if the bulb needs replacing.
Today I went to turn on the projector. It made clicking noises. Then stopped. Then more clicking noises. Then stopped.
Then the warning lights came on. The one in the middle (LAMP) was blinking red. The other two indicators (STANDBY/ON and WARNING) were just ON. No blinking.
I looked in the owners manual to check what that means. I couldn't find the exact same scenario. That is confusing to me. I think that I need to replace the bulb, but I am not sure.
Can anyone give me any advice? I would appreciate it.
someguy88 is offline
post #8751 of 8757 Old 07-21-2014, 11:10 AM
nebrunner's Avatar
Liked: 26
I ran for a few weeks in high mode and this weekend switched back to low. The flicker is gone, we'll see how long we can go now until it dies or flickers again.
post #8752 of 8757 Old 07-21-2014, 02:27 PM
frg
frg's Avatar
When it happens, about two hours in high mode is usually more than enough.
frg is offline
post #8753 of 8757 Old 08-12-2014, 10:08 PM
vrvideo's Avatar
Since we are talking about bulbs, I have a JVC RS1 bulb question that requires a lot of background history:
I have a 220" diagonal 16:9 screen in a pitch black room with black walls, ceiling, floor, and chairs room. Just a single door and no windows.
It amazes me that the RS1 does really well on such a large screen despite the 700 lumens rating. I had to maximize the lumen output by placing the projector at the minimum throw distance and utilizing no lens shift since any deviation from this setup cuts into your lumens.
2 years ago I bought a bulb directly from the JVC online store and installed it. With the new JVC bulb, my full white lux reading at the screen was 52.0 lux which calculates to be 682 lumens. So I was quite happy.
Next I purchased a backup bulb from AVS just in case the JVC bulb popped unexpectedly. The JVC bulb never broke, so my AVS bulb has simply been sitting on the shelf for two years.
I recently thought my image was getting dim, so I checked the bulb life menu and found that I had reached 1500 hours on the JVC bulb. I measured the lux and read 14.2 which calcs to 187 lumens. At 1500 hours I would have expected it to me more in the 300 ~400 lumen range given that at 2000 hours it should have been down 50%.
So I installed my AVS backup bulb that has been sitting on the shelf for 2 years. I measured the lux and read 27.5 lux which calcs to 361 lumens. I had expected it to be twice that much.
So here is my question:
I am worried that something else inside the projector is reducing my lumens by 50%. On the JVC bulb with 1500 hours I should have read around 360 lumens but got 187. On the AVS bulb with 0 hours I should have read 680 lumens but read 361 instead. Had it not been an AVS bulb, I would simply say that I got a cheap bulb. But the fact that the lumens for the JVC at 1500 hours and the AVS at 0 hours were both almost exactly half of what you would expect leads me to believe that it is something other than the bulb itself.
Has anyone else experienced this issue? I double checked all my projector settings and they are all normal. The bulb setting is set to high.
I don't want to spend another $400 on another JVC bulb just to find out if the AVS bulb lumen output is too low because I had planned on upgrading my projector in the next few months and not purchasing any more RS1 bulbs. I would rather the $400 go towards my new projector.
vrvideo is offline
post #8754 of 8757 Old 08-12-2014, 10:31 PM
derek51's Avatar
vrvideo,
If you have not already cleaned the prism that directly faces the lamp, then you will see an increase in lumens after you do that. You can search this thread or via google to find instructions. Some people appear to have also gone as far as to clean the side of the prism opposite the lamp, inside the projector. This involves more than just wiping the side of the prism that's up against the lamp.
After cleaning the prism I noticed a difference in brightness (just using my eyes, I don't have a light meter).
derek51 is offline
post #8755 of 8757 Old 08-13-2014, 10:28 AM
vrvideo's Avatar
I cleaned the surface of the glass where the bulb mounts and it made quite a difference! The LUX at the screen went from 27.5 lux to 41.5 lux yielding 544 lumens. I suspect if I were able to clean the rest of the glass surfaces, I would get the rest of the lumens back as well.
I used Kimwipes. Attached are some pics of the glass surface before and after, and pics of the dirt on the Kimwipes.
Name:	Surface with film.jpg
ID:	210457   Click image for larger version
Name:	Surface after cleaning.jpg
ID:	210465   Click image for larger version
Name:	Kimwipes after cleaning.jpg
vrvideo is offline
post #8756 of 8757 Old 08-25-2014, 10:45 AM
ekko star's Avatar
Could someone kindly forward me the v62 firmware and uploader for this PJ please?
I've tried all the links but it appears they are no longer live?
Many thanks
ES
ekko star is offline
post #8757 of 8757 Old 08-28-2014, 04:36 PM
chriscic's Avatar
After seven wonderful years, the HDMI ports on my beloved RS1 have stopped working with no explanation. I've tried multiple cables and devices. Component is still working.
Anyone seen this problem? Wondering if some sort of repair is economical. While I'm interested to see what 4k projectors are announced at CEDIA, I still love my RS1 and was planning on keeping it at least another year.
If I can't get the HDMI ports going again I'll have to see if there are still any PC video cards out there that can output component. That could at least be a stopgap until a PJ upgrade.
Update: Got a HDMI to component box which works well. Can only connect at 1080p 50i for some reason. perhaps due to cable length, but it works.
chriscic is offline
Jvc Dla Rs1 Projector
User Tag List
