JVC DLA-RS1 Owner's Thread - Page 296 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #8851 of 8858 Old Yesterday, 08:45 AM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 2169 Post(s)
Liked: 1158
Originally Posted by abontrager View Post
Thanks, you were right, it was my iSCAN VP50 pro that was causing the image issues. I am now running everything just through the Denon AVP and then to the PJ for now. Works fine, though I lose the full anamorphic control that the iSCAN gave me (lens shift AND vert stretch).
Is there anyway you can RS232 control the vertical stretch directly on the JVC?
Also, any suggestions on the bulb? I thought 2,000 hours was the recommended max.
Thanks again.
Luckily the RS1 and RS2 use the same lamp, since not sure what you have. I would use an OEM JVC lamp. Two model numbers are listed for that projector.
AV Geek for life. :) Contact for advice and help.
My Baffle wall Build: http://www.avsforum.com/forum/155-di...-tpl-150h.html
Mike Garrett is online now
post #8852 of 8858 Old Yesterday, 01:22 PM
Jon S's Avatar
Quoted: 332 Post(s)
Liked: 132
Not sure, I thought the bulb life was less... I know I am on my third lamp....
On a side note, I noticed the colors on my RS1 seems to be a bit faded now... I wonder if the colors on the panels fade from long term use... I should have it recalibrated to confirm....
If it's not a BIG screen, it's not a theater...
Jon S is online now
post #8853 of 8858 Unread Today, 10:27 AM
drunkpenguin's Avatar
Quoted: 725 Post(s)
Liked: 667
Do the bulbs really explode? Amazon is selling replacement bulbs that state 2000 hours.
I just searched this entire thread for the word "explode" and the only 4 references come from people saying it "could" explode. I don't see anyone claiming to have actually experienced this.
I caved!
drunkpenguin is online now
post #8854 of 8858 Unread Today, 10:34 AM
AVS Club Gold
Liked: 1158
Many people have experienced this. I have had a lamp explode in one of my projectors before. If you are in the room watching the projector, you will know exactly what happened. The loud pop will clearly tell you the lamp exploded.
post #8855 of 8858 Unread Today, 10:39 AM
Quoted: 725 Post(s)
Liked: 667
Hmm. Well bulbs are cheap maybe I'll think about replacing mine. I think I'm at 1500. Are they easy to put it? My PJ is ceiling mounted can I do it without taking it down?
I caved!
post #8856 of 8858 Unread Today, 10:39 AM
Jon S's Avatar
Quoted: 332 Post(s)
Liked: 132
I work at a utility company and we have a lot of projectors in conference rooms... A lot of them had their bulbs explode because they are used way past their lifetime. Users tend to ignore the warning and poof...
Older projectors had bare bulbs, newer ones may have housings for the bulbs which helps...
Jon S is online now
post #8857 of 8858 Unread Today, 10:42 AM
Quoted: 725 Post(s)
Liked: 667
Also what bulb are you guys buying for these and where do you get them? I see a number of them on Amazon but I don't know if they are original or re-productions.
I caved!
post #8858 of 8858 Unread Today, 10:42 AM
Jon S's Avatar
Quoted: 332 Post(s)
Liked: 132
They are very easy to replace. Clean the contacts in the projector... They tend to oxidize. It also causes the bulb to flicker if contact is poor. Found that out from my dealer. After 800 hours the bulb flickered. I removed the lamp and cleaned the contacts and voila... no flicker!
You might want to see if the optical block needs cleaning as well. It tends to haze after a while....
Jon S is online now
Jvc Dla Rs1 Projector
