JVC DLA-RS1 Owner's Thread - Page 298 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #8911 of 8913 Old 07-11-2016, 01:36 PM
krholmberg's Avatar
Quoted: 68 Post(s)
Originally Posted by dreamer View Post
I always reset the timer. Never had a lamp blow on me in 8 lamps. Still, it is really dim by 2000 hours so unless you run a really small screen in a completely dark room, I can't imagine waiting on a new lamp. The OSRAM lamp at Amazon is only $87. Just be sure you wear gloves while handling the lamp or oils from fingers on a bare bulb will cause early failure.
https://www.amazon.com/Osram-P-VIP-Q..._2&s=hi&sr=1-2
Looking back in this thread suggests the Philips bulb might be a better but more expensive choice (30% brighter initially according to some posts).
I found this https://www.amazon.com/dp/B00C74M0TQ..._ugaHxbQV364WY
How difficult is it to install a new bulb in an old housing? I've replaced plenty of the complete units but they were the knock offs and haven't lasted long. Now im looking for a better option.
Sent from my SM-G935T using Tapatalk
Krister
krholmberg is offline
post #8912 of 8913 Old 07-11-2016, 07:26 PM
dreamer's Avatar
Quoted: 788 Post(s)
Liked: 203
It isn't difficult if you have an old knockoff housing. The OEM housing on mine had the old bulb soldered in, which would mean adding lug connectors and screws to attach to a new bare bulb. My knockoff housings had the lugs screw-attached to the lamp and was a simple swap.
I had purchased what was supposedly a Philips bare bulb but it may have been a knockoff. It was not as bright as a new OSRAM and the color seemed a bit green to me.
krholmberg likes this.
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
post #8913 of 8913 Old 08-14-2016, 07:49 AM
CorvetteC5's Avatar
Looking at that Amazon link provided for the Philips UHP lamp; it appears to be a 150 watt bulb. The original JVC lamp and the Osram I presently use are both 200 watts. With all things being equal I would expect the Philips to be the dimmer lamp. FWIW.
Hey, what do you think of the Olympic images provided by NBC? I held off on over using a fresh Osram lamp in my RS-1, keeping it at about 10 hours. Then went gung-ho with it with my HTPC since the Olympics started. For the first time, I even ran the lamp at normal (low) brightness for about 40 to 45 hours before the brightness fell off on my 180" diagonal screen. I adjusted the color, brightness, contrast, HDMI level, etc for my local NBC broadcast. It is broadcasting over the air out of Indianapolis and the clarity and depth is awesome.
CorvetteC5 is offline
Jvc Dla Rs1 Projector
