JVC DLA-RS1 Owner's Thread - Page 302 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #9031 of 9045 Old 05-01-2017, 07:02 PM
Mike Garrett's Avatar
Quoted: 6446 Post(s)
Liked: 4162
Originally Posted by Jon S View Post
The newer JVCs are a lot larger than the RS-1... If the old mount is universal, it might fit the newer projector, but it is very likely you will need a new mount.
FYI... I bought a Peerless PRG-UNV mount which is supposed to fit the new JVC but while it does fit the new JVC when the arms are fully extended, the instructions says not to use the mount in that configuration as it is beyond the limits of the design.
Luckily, my old Chief mount could handle the larger JVC. It came with various mounting arms and i used the larger arms which fit the new JVC. Sadly, Chief no longer makes mounts...
Chief still makes mounts. In fact, I think they make the best mount out there.
mjgarrett100@gmail.com
Mike Garrett is online now
post #9032 of 9045 Old 05-01-2017, 08:01 PM
Jon S's Avatar
Quoted: 879 Post(s)
Liked: 279
I should have clarified... Chief no longer makes mounts that will fit the current JVC projectors. The one i have is a huge mount that was nearly the size of the projector. It is an aluminum frame that has slotted holes. You align the mounting holes in the projector to the slotted holes in the frame to fit...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #9033 of 9045 Old 05-02-2017, 05:32 PM
Liked: 4162
What you are saying is not correct. Chief makes mounts for the current JVC's. I think what you are trying to say is the Chief universal mount no longer fits the current line of JVC projectors. Hardly any universal mount fits the current line of JVC projectors. Though some people have extended the arms farther than manufacturer recommendations and or use extension pieces to make them fit. Instead, you should just buy the correct interface plate for your existing Chief mount.
post #9034 of 9045 Old 05-18-2017, 06:07 PM
GlenC's Avatar
This is correct, Chief has custom Mounting Plates for all the JVC Projectors. The only one requiring a new mount is the RS4500K because it is 85lbs ....
Glen Carter<br />
Home Theater Calibration<br />
GlenC is offline
post #9035 of 9045 Old 05-30-2017, 04:59 PM
MelN's Avatar
Liked: 0
Originally Posted by hardvark View Post
If there is anyone on here that is Handy or wants a unit for spare parts, let me know . I have a RS1 that fell off a customers coffee table and seems to have Jammed up the focus ring on the lens . We tried it out and everything works well but I don't have the Patients /skills to disassemble the lens and fix it. I told him with the age of the unit he would be better off replacing it than repair, and he agreed. I took it in for labor and thought I would repair it sometime but ........we know how that song goes,LOL
In reply to Hardvark's post regarding the RS1 that fell off the coffee table. I do happen to have a need for a parts chassis RS1. I've got an RS1 in our office that we're trying to stretch out that just had a power supply failure we think. I'll be happy to fund shipping if your parts unit is still available and powers up. Thanks, Mel
MelN is offline
post #9036 of 9045 Old 06-20-2017, 05:15 PM
Liked: 0
Question
I have an RS-1 with an RSVP with isf calibration.
I'm still super happy with the picture but the cooling is becoming more and more of an issue.
I have a thermal aux fan mounted over the top to supplement to cooling.
I've been through the forums trying to find fan replacements.
So far all I've come up with is either used fans or JVC asking for $425
110 QAR0449-001 DUCT FAN $83.79
59 QAR0447-001 LAMP FAN $144.
21 QAR0446-001 DUCT INTAKE FAN $122.
71 QAR0448-001 DUCT PS FAN $77.75 (Exhaust)
Has anyone been able to source any modern day equivalents?
cosmuk is online now
post #9037 of 9045 Old 06-22-2017, 06:52 AM
Liked: 0
This is the parts list with an exploded view from JVC for the RS-1/2
post #9038 of 9045 Old 06-22-2017, 10:37 AM
Jon S's Avatar
Quoted: 879 Post(s)
Liked: 279
The JVC RS-1 is now ten years old... At that age, manufacturers are no longer required to inventory parts for a product... You might just want to consider buying another projector, used or new that is more recent. You would not want to buy expensive parts for it now and find out shortly another issue arises and there is no parts for it...
Jon S is offline
post #9039 of 9045 Old 06-22-2017, 01:20 PM
fleaman's Avatar
Quoted: 53 Post(s)
Liked: 108
Yeah, I've seen a very low hour RS46 sell for like $700 on ebay recently...
fleaman is offline
post #9040 of 9045 Old 06-22-2017, 02:55 PM
Liked: 0
Whoa! Was hoping the forum had some enthusiastic “fans” of the RS series.
The RSVP with the ISF calibration unlocked and of course a bit’o TLC, still make this a wonderful projector.
Just hoping to swap out some fan’s.
¯\_(ツ)_/¯ ॐ
post #9041 of 9045 Old 06-22-2017, 06:09 PM
Jon S's Avatar
Quoted: 879 Post(s)
Liked: 279
I am not trying to discourage you but just stating some facts that you should consider... I have a RS-1 as well that has served me faithfully but I do notice that the colors are not as rich as before. My guess is that the D-ILA panels are fading over time.
If it breaks, I will not repair it... The RS-1 has almost no value now and the latest models are far superior to the RS-1 in every way, they are a lot brighter with better colors and the contrast is far deeper than the RS-1.
Jon S is offline
post #9042 of 9045 Old 06-22-2017, 07:03 PM
Liked: 0
Hey Thanks Jon,
I’d pull the lamp and examine for any grey spots on the mirror surface of the bulb.
This can turn colors drab.
Then clean the optical block, with a lens cleaning cloth.
I do this with a head mounted flashlight, to see any anomalies
¯\_(ツ)_/¯ ॐ
Here's the SM
post #9043 of 9045 Old Yesterday, 07:37 AM
VTPete's Avatar
Quoted: 14 Post(s)
Update on those inexpensive Osram bulbs from Bulbs America:
After 50 hours I had to bump the power setting to high on my RS1 to keep the brightness optimal.
After 100 hours, I'm now tweaking the picture settings; increasing the brightness and contrast to compensate for the bulb dimming. (And not so successfully, of course.)
I think it's clear now that these bulbs have a more rapid drop-off in brightness than the original JVC models. I still enjoy my RS1 after more than 10 years (has it really been that long?), but I think it's time to replace.
I have a spare, brand new, unused Osram bulb I might slip in. Why not enjoy the brightness if I can?
In the end, the lower price is nice, but I'm not going to keep buying them.
-Pete
VTPete is offline
post #9044 of 9045 Old Yesterday, 10:35 AM
Jon S's Avatar
Quoted: 879 Post(s)
Liked: 279
Colors fade when the D-ILA panels age... The colors are no longer as vibrant as before...
Jon S is offline
post #9045 of 9045 Old Today, 07:37 AM
Liked: 0
Hey Jon,
Okay, although I spoke to an engineer at JVC last week about an install I ws doing and he mentioned that in his experience he's only seen the optical block yellow with age, but that's from smokers. ¯\_(ツ)_/¯ ॐ
Jvc Dla Rs1 Projector
