Best code for RS1 using URC remote control? - AVS Forum
post #1 of 4 Old 04-09-2007, 03:32 PM - Thread Starter
noah katz's Avatar
Quoted: 36 Post(s)
Liked: 125
Anyone know which code for URC remotes works best for the RS1?
I don't want to waste pwer cycles finding the code that works the best.
Noah
noah katz is offline
post #2 of 4 Old 04-09-2007, 03:35 PM
MikeSRC's Avatar
I don't know if any of them does. Even if one worked, there'd probably be commands missing. I would just learn the commands from the RS-1 remote. It will take you less time and allow you to have all the commands placed where you want them.
Enjoy!
Mike
Surf Remote Control
Contributing reviewer and THX calibrator, ProjectorReviews.com
MikeSRC is offline
post #3 of 4 Old 04-09-2007, 03:37 PM - Thread Starter
noah katz's Avatar
Quoted: 36 Post(s)
Liked: 125
That was fast!
True, it's not that hard, but I'm lazy
Noah
post #4 of 4 Old 04-09-2007, 03:41 PM
MikeSRC's Avatar
An alarm goes off on my PC whenever someone mentions "remote control".
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
User Tag List
