External Scaler necessary with new breed of Projectors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-10-2007, 10:42 AM - Thread Starter
Beach_Guy's Avatar
I know there is a separate forum for Scalers/Video processors but I wanted to get some feedback from the people in this thread that have experimented with some of the newer projectors like the RS1, Marantz VP-15S1, and Sim2 HT3000e.
Basically, I wanted to know if you think the external scalers give a "noticeable" benefit over the new projectors' internal scalers. I am looking to upgrade from a Dwin TV3E which is the two box solution with a separate scaler/video switcher to one of these new projectors and I was wondering if I should invest in a new external scaler/switcher or just get a dedicated preamp/hdmi video switcher.
My primary sources are DirecTV(HD DVR) and a Toshiba XA2 HD DVD. This makes up 99% of my viewing material.
Thanks in advance.
Beach_Guy is offline
post #2 of 8 Old 10-10-2007, 11:46 AM
rmccormack's Avatar
im sure it looks nicer, 2-3,000 dollars nicer, no..but i guess if money is no object than its not a big investment. I wish i had a scaler but it would really only help me for my lower res stuff.
rmccormack is offline
post #3 of 8 Old 10-10-2007, 12:21 PM - Thread Starter
Beach_Guy's Avatar
Thanks. That's kind of what I was thinking. I think external scalers made a lot more sense when we were primarily dealing with various 480i sources and projectors had minimal or no scaling. -but now that most of the stuff I watch in the theater is either native HD or upconverted to HD via the DVD scaler, combined with the fact that most good projectors have decent internal scalers, I really don't think I need it. On the other hand, it is evident in the "Video Processors" forum that there is definitely still a market for these products so...
post #4 of 8 Old 10-10-2007, 07:03 PM
Jason Turk's Avatar
I think that there is no question a video processor helps. But, I think that the improvements are becoming more subtle as the projectors are utilizing better and better internal processors. Thus, the value goes down.
Jason Turk is offline
post #5 of 8 Old 10-10-2007, 07:15 PM
SJHT's Avatar
Quoted: 244 Post(s)
Liked: 124
I also think video processors give you more options on what you can do with picture than maybe the standard scalers built into the projector.
SJHT is offline
post #6 of 8 Old 10-10-2007, 07:20 PM
Jason Turk's Avatar
Very true. Most allow custom aspect ratios, change of refresh rates/timings, etc...
Plus there is no question a 2 box setup is an easier installation.
post #7 of 8 Old 10-10-2007, 08:08 PM
TomHuffman's Avatar
Quoted: 685 Post(s)
Liked: 613
Having owned a couple of high-end scalers, I am of the opinion that their simple ability to scale and deinterlace often does NOT provide a visible image improvement over what you get from the processors in many of the newer projectors. For example, I thought that the HQV processing in the Vantage HD product noticeably improved the image I saw from a SIM2 HT3000, but offered little in the way of improvement to the Sharp 20K.
Where an external processor can really make a difference is when it includes controls that allow you to calibrate the image better than what the projector's native controls allow.
For example, the VXP-based Optoma HD3000 has both a full compliment of gray scale and color decoding controls that can make a real difference to image quality if you are willing to have the projector calibrated. Also, the endlessly always-around-the-corner Lumagen Radiance will have both of these features and they promise to add a complete CMS that would allow you to dial in nearly perfect color. Either could make a profound difference.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #8 of 8 Old 10-13-2007, 06:52 AM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
The Reon VX in my HC5000 does a superior job with component video compared to the ABT in my Yamaha receiver, better than my former DVDO and Lumagens.
bobpaule is offline
