Sony VPL-VW60 Tweakers Thread - Page 54 - AVS Forum | Home Theater Discussions And Reviews
post #1591 of 1607 Old 01-02-2015, 03:45 PM
jwhart's Avatar
Quoted: 28 Post(s)
Originally Posted by Verge2 View Post
Thank you Verge! Have a great weekend and Happy New Year.
jwhart is offline
post #1592 of 1607 Old 01-02-2015, 05:19 PM
Jive Turkey's Avatar
Quoted: 274 Post(s)
Liked: 162
Originally Posted by aham23 View Post
i need a bulb and wondering where you folks were purchasing them from? much thanks!
I ended up buying the 55ES after having the 60 recalibrated with a new lamp. Very happy with the 55ES after approx. 200 hours.
I'll sell my 60 to anyone in the continental states for $500 plus freight. Jeff Meier did a great job with his calibration, but the issues that age has brung in the darker scenes led me to the new projector.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #1593 of 1607 Old 01-06-2015, 06:25 AM
aham23's Avatar
I got mine from the abs store, it was competitively priced with the only other website I could find selling genuine oem bulbs, and, they give me a place to waste time on my phone.
it seems like purelandsupply and a few others suggest they sell OEM bulbs. or at least they indicate that the bulb is a Phillips.
http://www.purelandsupply.com/lmp-h2...ctor-lamp.html
would this bulb not be the same as the OEM?
much thanks.
aham23 is offline
post #1594 of 1607 Old 01-06-2015, 08:38 AM
Michael9009's Avatar
Quoted: 296 Post(s)
Liked: 79
much thanks.
Try Sony, e.g.: http://www.sonybiz.ca/pro/lang/en/ca...h200/overview/
Manufacturers should be able to deliver original spare parts for their products for at least 10 years after the product was discontinued. For the CPL-VW60 this should be April 2019.
Michael9009 is offline
post #1595 of 1607 Old 01-06-2015, 11:07 AM
Mike Garrett's Avatar
Quoted: 6712 Post(s)
Liked: 4399
much thanks.
Ask if it comes in a factory sealed Sony box.
mjgarrett100@gmail.com
Mike Garrett is offline
post #1596 of 1607 Old 01-07-2015, 11:09 AM
aham23's Avatar
i asked and the responded in less than 30 minutes. it does not. it is a generic housing but an original Phillips bulb. so same bulb and since plastic is plastic i am going to give it a try. ill post back my results. much thanks.
aham23 is offline
post #1597 of 1607 Old 01-08-2015, 09:17 PM
Quoted: 296 Post(s)
Liked: 79
Please let us know. I have heard many horror stories with non-OEM bulbs that personally I would not risk the hassle. Sony still has the LMP-H200 available (see the link in my previous post above), so it should not be too difficult to get on OEM bulb.
post #1598 of 1607 Old 01-08-2015, 09:29 PM
aham23's Avatar
It's a real Phillips Bulb/Lamp according to them. Sony doesn't make bulbs. So they claim to buy the same bulb/lamp from Phillips and put it in their own housing. They bulb/lamp is the same.
aham23 is offline
post #1599 of 1607 Old 01-08-2015, 09:33 PM
Quoted: 296 Post(s)
Liked: 79
Well, as I said, please let us know. Don't forget you'd also have to change the filter when you replace the lamp.
post #1600 of 1607 Old 01-08-2015, 09:40 PM
aham23's Avatar
Damn. I thought I could just "clean"
the one in it. No?
aham23 is offline
post #1601 of 1607 Old 01-10-2015, 06:26 AM
aham23's Avatar
That's a serious question on the filter. Unless a lamp just comes with one I didn't order one. Thought it could be pulled and cleaned or washed out. If not where does one purchase one? Much thanks.
aham23 is offline
post #1602 of 1607 Old 01-10-2015, 07:10 AM
aham23's Avatar
Pulled it and cleaned it. Actually not that dusty considering it's never been done. Yes, I am a bad PJ owner.
aham23 is offline
post #1603 of 1607 Old 03-22-2015, 02:41 PM
jwhart's Avatar
Quoted: 28 Post(s)
Is it possible for the VW 60 display the resolution of the video signal it's receiving?
Jack
jwhart is offline
post #1604 of 1607 Old 03-25-2015, 08:56 AM
southlakedad's Avatar
Quoted: 30 Post(s)
Liked: 7
Hours counter?
I acquired a VPL-VW60 by buying the house around it.
The hours counter (not sure what else to call it) says it's at a little over 1500 hours. I bought a spare bulb from AVS because I want to wait to replace the PJ for an affordable 4k option.
I'm wondering whether the counter is displaying the total hours the PJ has been used, or if it resets when the bulb is changed (i.e. is 1500 hours the lamp time, or the total PJ time). Can anyone answer this simple question?
Also, since I didn't see it when it was new I'm not exactly sure how much if at all the picture has degraded due to lamp aging. What should I look for to determine whether I need to replace the bulb now or wait a bit longer?
southlakedad is offline
post #1605 of 1607 Old 03-25-2015, 04:33 PM
jwhart's Avatar
Quoted: 28 Post(s)
I'm no expert but fairly certain that the hours are what's been accumulated since the last reset.
jwhart is offline
post #1606 of 1607 Old 03-25-2015, 05:54 PM
dragonbud0's Avatar
Quoted: 119 Post(s)
Liked: 62
Go to the Service Menu, by pressing
{ENTER} {ENTER} {UP ARROW} {DOWN ARROW} {ENTER}
This should tell you the cumulative hours on this projector's usage.
dragonbud0 is offline
post #1607 of 1607 Old 03-25-2015, 07:19 PM
Quoted: 30 Post(s)
Liked: 7
Thank you!
Sony Vpl Vw60 Home Cinema Projector
