RS-1, Radiance Primary Gamut Correction - AVS Forum | Home Theater Discussions And Reviews
post #1 of 839 Old 10-19-2007, 06:28 PM - Thread Starter
sfogg's Avatar
Because this is going to get forgotten...
THIS IS THE FIRST VERSION OF LUMAGEN'S Color Gamut Control!!!!
As it is right now the controls don't have enough range to get the blue/red in the RS-1 completely in line. I posted that on the beta forum and Lumagen has already responded that they will double the available range of their controls.
Again... LUMAGEN HAS ALREADY SAID THEY ARE GOING TO DOUBLE THE RANGE OF THEIR CONTROLS!!!!
Shawn
sfogg is offline
post #2 of 839 Old 10-19-2007, 06:40 PM - Thread Starter
sfogg's Avatar
Tweaked blue a little bit more....
sfogg is offline
post #3 of 839 Old 10-19-2007, 07:03 PM
mikela's Avatar
Quoted: 195 Post(s)
Liked: 231
Shawn,
Thanks for posting this. I guess this means the RS2 will be even harder to pull in, unless the range extends far enough.
Mike
mikela is offline
post #4 of 839 Old 10-19-2007, 07:26 PM - Thread Starter
sfogg's Avatar
"Thanks for posting this. I guess this means the RS2 will be even harder to pull in, unless the range extends far enough."
Lumagen is going to double the range and it will probably happen pretty quickly knowing Lumagen.
Shawn
sfogg is offline
post #5 of 839 Old 10-19-2007, 07:31 PM - Thread Starter
sfogg's Avatar
I've been watching a little of Casino Royal. I setup Lumagen Output Config0 to have the Gamut adjustments and Output Config1 not to. I then set Config0 to Input MemA and Config1 to InputMemB. This way I can switch between the two with a press of the button.
The color difference is dramatic. With the correction in place I had to back down on the Contrast level a little as it looks like I was getting white crush. The color correction literally adds color to the color being corrected. For example on GREEN the controls are ADD Red and ADD Blue.
Not that screen shots show everything but this should gives an idea on what the difference looks like.
Shawn
sfogg is offline
post #6 of 839 Old 10-19-2007, 07:32 PM - Thread Starter
sfogg's Avatar
Two more...
sfogg is offline
post #7 of 839 Old 10-19-2007, 08:15 PM - Thread Starter
sfogg's Avatar
Bob,
The Color Gamut Control is based on Red, Green and Blue.
The options in Red are Add Green Add Blue
Green is Add Red and Add Blue
Blue is Add Red and Add Green
There is no saturation control.
Shawn
sfogg is offline
post #8 of 839 Old 10-19-2007, 10:25 PM - Thread Starter
sfogg's Avatar
Few more pics...
sfogg is offline
post #9 of 839 Old 10-19-2007, 10:26 PM - Thread Starter
sfogg's Avatar
Another pair...
sfogg is offline
post #10 of 839 Old 10-19-2007, 10:26 PM - Thread Starter
sfogg's Avatar
Last pair..
sfogg is offline
post #11 of 839 Old 10-19-2007, 10:37 PM
Rob Tomlin's Avatar
Great stuff Shawn.
Ironically I would be willing to bet that the majority of jsp's would greatly prefer the over saturated shots to the more accurate ones. No doubt JVC believes this as well.
Kudos to Lumagen for doing this upgrade.
Rob Tomlin is offline
post #12 of 839 Old 10-19-2007, 10:49 PM
QQQ
QQQ's Avatar
I'll take the correctly saturated on the first two and the oversaturated on the last one .
QQQ is offline
post #13 of 839 Old 10-19-2007, 10:57 PM
Rob Tomlin's Avatar
Another pair...
Those pics were not what I was expecting based on your description!
post #14 of 839 Old 10-19-2007, 11:17 PM
shamus's Avatar
Quoted: 23 Post(s)
Maybe Im just ignorant, but I prefer the oversaturated ones....
Whats the Lumagen cost?
shamus is offline
post #15 of 839 Old 10-20-2007, 03:08 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Bravo Lumagen! The no-ring scaling looks great as well. I never noticed the "ringing" before until I saw it corrected in Lumagen shot. Then I could clearly see it on the RS1. If you consider how much HDMI adds to the cost, the CMS, and the improvement made by the no ring scaling, the Lumagen seems like a good choice especially at the AVS pre-production price.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #16 of 839 Old 10-20-2007, 03:48 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
At least with the CMS you will get to decide how much saturation you want. Maybe some will chose to eliminate some percentage of the oversaturation and not all. The RS1 has too much for my taste. When I purchase the Lumagen, I am just going to calibrate to the standards and let the director of the film decide how much oversaturation he wants to present if any in his film and not JVC. I can live with that.
post #17 of 839 Old 10-20-2007, 03:53 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Shawn
What type of signal are you outputting? 10 bit? Wondering if you can finally settle the concern about that. Great job with the pics.
post #18 of 839 Old 10-20-2007, 05:20 AM
Ohlson's Avatar
Yes what kind of signal does the Lumagen box send out?
Will this CMS feature come to a range of Lumagen products. Correcting the color at many thousands of dollars is kind of expensive for those on a budget.
Mattias Ohlson
Ohlson is offline
post #19 of 839 Old 10-20-2007, 06:22 AM - Thread Starter
sfogg's Avatar
"What type of signal are you outputting? 10 bit?"
Right now I think just 8 bit RGB. The options for 10 and 12 bit 4:2:2 are not in the software yet.
Shawn
sfogg is offline
post #20 of 839 Old 10-20-2007, 06:24 AM - Thread Starter
sfogg's Avatar
"The no-ring scaling looks great as well. I never noticed the "ringing" before until I saw it corrected in Lumagen shot."
FWIW even those these are 1080p24 out of the RS1 they have all been scaled because of my ISCO II that is always in the light path.
Shawn
sfogg is offline
post #21 of 839 Old 10-20-2007, 06:49 AM
kthacher's Avatar
Where do I find further information on this?
Kerry
kthacher is offline
post #22 of 839 Old 10-20-2007, 06:49 AM
Ohlson's Avatar
sfogg
Is it clear that Lumagen will improve the softare to finally use 12 bit 4:2:2?
Radiance is an overkill for many. Do you know if there are plans for a product accepting only a couple of hdms and component with hdmi out, this with the CMS and a lower price?
Mattias Ohlson
Ohlson is offline
post #23 of 839 Old 10-20-2007, 06:54 AM
aaron_hinni's Avatar
The Unofficial RadianceXD FAQ has more info.
aaron_hinni is offline
post #24 of 839 Old 10-20-2007, 06:57 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Shawn
I saw the pic of no ring scaling on the Lumagen thread.
post #25 of 839 Old 10-20-2007, 07:00 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Originally Posted by Ohlson View Post
sfogg
I asked this question about 6 months ago. I was told that yes there are other products planned in the new line they will be lower priced. As to when to expect them, I was told it would be some time out because they were still developing the Radiance XD. If your figure in the cost of having HDMI then even a lower priced solution is still going to cost a bit. A small company like Lumagen is not really going to be able to sell such a volume as to not pass the significant cost of having HDMI. Even at half the price it is still a lot more than what JVC could have done it. Here from the unoffical thread, "...Anyhow, on top of the XD and the Pro, Lumagen is also planning a RadianceXS - that would be the 'light' (aka cheaper) version of the XD. No feature list, no schedule, but fewer inputs is pretty much a certainty.
post #26 of 839 Old 10-20-2007, 07:02 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
I called Jason here on AVS and he gave me the price.
post #27 of 839 Old 10-20-2007, 07:05 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
http://www.avsforum.com/avs-vb/showt...5#post11473155 No ring scaling. Just scroll down so that you can only see the last two pics. You can clearly see the ringing on the VP50 shot. No ringing on the Lumagen Radiance shot.
post #28 of 839 Old 10-20-2007, 07:25 AM
Hughman's Avatar
Sfogg,
Thanks for the info. The end results look very promising, even with a half-way fix things look much better. Since many of us have jury-rigged reduced saturation using the color control I'd be interested to see what relative differences your camera portrays with the no primary correction but the color control at -15 or so. Could you snap a few pics using a couple of the same scenes already posted?
Also, using Lumagens CMS are the secondaries untouched?
Hughman is offline
post #29 of 839 Old 10-20-2007, 07:37 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
One last comment about ringing on the RS1, from the Projector Central review,"The RS1's sharpness control has a range of -30 to +30, with a factory default at zero. Settings above zero introduce progressively more ringing and edge effects. But settings toward the softer end of the scale introduce excessive blurriness.."
post #30 of 839 Old 10-20-2007, 08:19 AM
Hughman's Avatar
Bulldogger,
In my setup ringing is completely eliminated only when the RS1's sharpness control is at -30. I suspect JVC has added a little sharpening to all settings except -30 to help offset some acuity issues elswhere. At times -30 works great other times I prefer much higher settings. Using resolution patterns have noticed that JVC's sharpness control, apart from typical and significant moire, introduces coloring to high frequency patterns. Further testing with my XA2's edge enhancement feature has shown it to be superior to the JVC's sharpness control by not introducing coloring to the same patterns so I use this at level 1 with JVC's sharpness control at -30.
Perhaps this discussion should be moved to owners thread.
Hughman is offline
