Projector Central Panasonic PT-AE2000U Review is Up! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 65 Old 11-10-2007, 05:25 AM
Renatim's Avatar
I've almost decided to go gray because for movies a think the 350 to 400 lumens panny provides on best modes are enough to illuminate a 84" screen using min throw distance(1,85 to 1,90x zoom). I'm just a little bit worried about the gray whites you mentioned.
For viewing with some ambient light i believe the normal mode has plenty enough light too(900 lumens).
Do you agree?
Renatim is offline
post #62 of 65 Old 11-10-2007, 05:20 PM
jacksonian's Avatar
Don't worry too much about the whites. I've used a gray screen for almost 5 years now and whites have never bothered me. Now, if you hold up a white screen next to it, then yes, the whites look worse on mine, but without the direct side by side comparison, you'll never notice it.
jacksonian is offline
post #63 of 65 Old 11-10-2007, 05:55 PM
R Harkness's Avatar
Quoted: 1971 Post(s)
Liked: 1681
Yep, and on the other hand if you hold up a white screen next to yours the blacks will look better on your screen.
R Harkness is offline
post #64 of 65 Old 11-10-2007, 06:58 PM
Brett CR's Avatar
Will the 2000 be able to pump out at 1080p through vga??
Brett CR is offline
post #65 of 65 Old 11-10-2007, 07:33 PM
tvted's Avatar
Quoted: 23 Post(s)
Fixed pixel displays, display at their native resolution so they will take whatever you feed it and map it to the panel rez - in this case 1920 x 1080.
A good display should be able to 1:1 pixel map, that is if you feed it a source at its native rez it should display all those pixels without scaling.
So the question is your vidcard up to snuff?
ted
tvted is offline
