Viewsonic Pro8100 1080p Projector - Page 308 - AVS Forum
post #9211 of 9231 Old 09-04-2014, 09:42 AM
hmcewin's Avatar
No one has tried the mwave bulbs?
hmcewin is offline
post #9212 of 9231 Old 09-04-2014, 10:05 AM
zachfine's Avatar
I bought an mwave bulb. It works, though I'll never manage to get it back out of the projector without damage (it's stuck in there real good) and I could never manage to calibrate the thing to get skin tones to look decent after installation. I think the new bulb or reflector are bluer than the original.
That and the fact that the projector stopped accepting signal from the remote indicated to me that it was time for a new projector.
zachfine is offline
post #9213 of 9231 Old 09-04-2014, 05:51 PM
old corps's Avatar
Quoted: 18 Post(s)
Liked: 40
I tried 2 of them. The 1st one was much dimmer than an OEM lamp with about 1000 hours on it. The 2nd one was worse than the 1st. I could barely see the screen! Both of these were only $79 or so but were the same ones others here had reported being quite happy with.
I will say that mwave was very good in taking them back and refunding my $$$ in both cases. They even provided a UPS prepaid label to return them.
Good luck!
Ed
old corps is offline
post #9214 of 9231 Old 09-04-2014, 06:25 PM
hmcewin's Avatar
I appreciate your feedback.
Henry
hmcewin is offline
post #9215 of 9231 Old 09-04-2014, 06:28 PM
hmcewin's Avatar
Replacement projectors?
For those who are replacing their Pro 8100's, which projectors have caught your fancy?
Henry
hmcewin is offline
post #9216 of 9231 Old 09-04-2014, 06:28 PM
73shark's Avatar
Quoted: 30 Post(s)
Liked: 48
I have had good luck with mine for over 2600 hours.
I believe that mgkdragn (Uncle Willie) has had similar experience.
Waiting for a 1080p 3D PJ. I haven't seen anything in the <$1,500 price point that can compare with the Pro8100.
In space, no one can hear you scream . . .
73shark is offline
post #9217 of 9231 Old 09-05-2014, 02:37 PM
mgkdragn's Avatar
Quoted: 249 Post(s)
Liked: 623
In for the re re re vitalization of the thread .. I have personally used 2 of the MWAVE lamps now with great luck, each slightly brighter than the VS lamps .. I have also installed 3 lamps in other folks units with great results ..
Currently, I have about 3000 hours on the last lamp, and the PJ itself has about 10,000 hours on it .. I've cleaned the filter once, I clean the lens about once a year .. I sold my spare unit for more than I paid but had to install it for the guy ..
Mine is still working flawlessly and with a well mastered BD, it still holds up well against the lower end new stuff that's out there .. and feature wise, it still can't be beat price wise considering what I paid ..
I just can't talk myself into any real compelling reason to ditch it and buy a current model of something .. if it ain't broke ..
old corps likes this.
Uncle Willie
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
: Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
mgkdragn is offline
post #9218 of 9231 Old 09-05-2014, 03:32 PM
hmcewin's Avatar
Thanks Uncle Willie
Mine is still projecting a nice image with about 6000 hours on the projector and apprx. 3000 hours on the original bulb. I used another bulb from an internet source the other 3000 hours. There is no compelling reason for me to "upgrade" at this time. Just wondering what other owners are doing. My original question was about the bulbs available on mwave site. They have on at $149 and others at $105. Anyone know what the difference is? Considering buying one for a backup.
Thanks everybody.
Henry
hmcewin is offline
post #9219 of 9231 Old 09-15-2014, 08:25 AM
Dark Rider's Avatar
Hey all, was just checking in, as it's been quite some time since I last posted... I'm up to 2000 hours on my MWave replacement lamp and about 6000 total hours on my projector, and it's going every bit as strong since the day I bought it. I've noticed less dimming on the MWave replacement than on my original, so I haven't had to recalibrate it as much either. Personally, at this rate, I've stopped looking at replacements. The reliability and image quality from the Pro8100 have been fantastic. In this day of throw away electronics, my Pro8100 still reigns as my center piece and the best single purchase I've ever made in AV gear!
Dark Rider is offline
post #9220 of 9231 Old 09-15-2014, 07:06 PM
73shark's Avatar
Quoted: 30 Post(s)
Liked: 48
I agree but I do remember it took several units before I got one that worked reliably and it had vertical banding that the timer fixes.
I have about 3,000 hours on my mwave bulb and still can't tell the difference between normal and economy mode. Took my original bulb out at 2,000 hours to have as spare. I guess Viewsonic got out of the home theater pj business.
73shark is offline
post #9221 of 9231 Old 09-18-2014, 11:37 AM
sebberry's Avatar
Liked: 27
Has anyone had their projector not power up? Normally there's a flashing green light indicating standby mode, but one belonging to a client of mine won't turn on and there's no flashing light.
He tested the outlet and it's fine. I'll replace the power cord but I doubt that's a problem.
sebberry is offline
post #9222 of 9231 Old 09-18-2014, 01:05 PM
257roberts's Avatar
Unplug the unit for a hour or so and then try it again if you havent done that already.
257roberts is offline
post #9223 of 9231 Old 09-18-2014, 01:26 PM
73shark's Avatar
Quoted: 30 Post(s)
Liked: 48
That has worked for me a few times also.
73shark is offline
post #9224 of 9231 Old 09-18-2014, 01:50 PM
sebberry's Avatar
Liked: 27
I had him unplug it for a while, not sure how long for.
sebberry is offline
post #9225 of 9231 Old 09-19-2014, 03:56 PM
Meret's Avatar
Yea, mine did that once. I had to ship it back to Viewsonic for repair. They repaired and returned it in 4 days.
Meret is offline
post #9226 of 9231 Old 09-19-2014, 07:32 PM
73shark's Avatar
Quoted: 30 Post(s)
Liked: 48
Long time, no see. Do you still have your Pro8100?
For those of you that weren't around at the beginning of the Pro8100, Meret created this thread that contains a treasure trove of Pro8100 info.
73shark is offline
post #9227 of 9231 Old 09-20-2014, 07:03 AM
old corps's Avatar
Quoted: 18 Post(s)
Liked: 40
Yes he did and it was a great help to me when I was a Pro8100 newbie!
Ed
post #9228 of 9231 Old 09-21-2014, 07:06 AM
Fabricator's Avatar
hayya guys. i still have mine, with no plans to replace it. but it only has about 675 hours on it. the last few years it has been only 1 movie a week during the winter months.
anyway. i am glad that there is still guys rock'n this unit
chasing rattles ......
Pro8100 Cult member
Fabricator is offline
post #9229 of 9231 Old 09-21-2014, 07:36 AM
Meret's Avatar
Yea, I do. It just got packed away in July during house renovations (we're moving later this year). It still looks and works like new. I am debating on upgrading to something newer next year but we'll see.
Meret is offline
post #9230 of 9231 Old 09-21-2014, 10:06 AM
sebberry's Avatar
Liked: 27
Thanks for the reply.
This one is out of warranty so I am going to take it to a local electronics repair shop.
Do you happen to know what failed and was repaired on yours? It might help the local shop pinpoint the problem.
sebberry is offline
post #9231 of 9231 Old 09-21-2014, 10:08 AM
sebberry's Avatar
Liked: 27
I'm still using mine. Same bulb for the last 4.5 years. Couple of movies per week on it.
(Same green dust blob for 4.5 years too )
sebberry is offline
Viewsonic Pro8100 Full Hd 1080p Home Theater Projector , Viewsonic
Gear in this thread - Pro8100 by PriceGrabber.com
