Viewsonic Pro8100 1080p Projector - Page 309 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #9241 of 9416 Old 10-10-2014, 01:41 PM
sebberry's Avatar
Quoted: 28 Post(s)
Liked: 31
I see that the thermostat connects directly to the power supply.
Would a faulty or disconnected thermostat cause a no-power condition?
sebberry is offline
post #9242 of 9416 Old 10-10-2014, 02:29 PM
73shark's Avatar
Quoted: 410 Post(s)
Liked: 208
I would think any tech that works on this type of hardware could determine if it's the power supply or components surrounding it.
They should be able to determine if it's the thermostat or not.
73shark is offline
post #9243 of 9416 Old 10-10-2014, 05:00 PM
sebberry's Avatar
Quoted: 28 Post(s)
Liked: 31
Heh... just realized that the bulb (original) outlasted the power supply. He even bought a spare lamp. Should have bought a spare PSU.
Let's hope my 8100 doesn't suffer the same fate any time soon. I've only put 800hrs on mine over the last 4.5 years.
sebberry is offline
post #9244 of 9416 Old 11-15-2014, 02:19 PM
jtheman's Avatar
hi guys
I had to change my basement setup and now have to hang my precious viewsonic 8100 from the ceiling
Any good recommendations for a ceiling mount that you are currently using
thanks
J
jtheman is offline
post #9245 of 9416 Old 11-16-2014, 10:18 PM
73shark's Avatar
Quoted: 410 Post(s)
Liked: 208
Originally Posted by jtheman View Post
hi guys
thanks
J
I got mine from Mounts and More on-line but I don't remember the part number for it. I doubt they carry it anymore anyway.
73shark is offline
post #9246 of 9416 Old 11-17-2014, 06:46 AM
Mike Garrett's Avatar
Quoted: 6933 Post(s)
Liked: 4615
hi guys
thanks
J
My first choice would be an RPMA217. My second choice would be an RPA217 and my third choice would be an RPAU. If we can help you, give us a call.
mjgarrett100@gmail.com
Mike Garrett is online now
post #9247 of 9416 Old 11-17-2014, 01:59 PM
mgkdragn's Avatar
Quoted: 2031 Post(s)
Liked: 2405
hi guys
thanks
J
MonoPrice has a good selection of inexpensive mounts ...
http://www.monoprice.com/Search/Inde...rojector+mount
Myself, I'd just fabricate one since it's pretty easy ..
Uncle Willie
Oddball: Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
mgkdragn is offline
post #9248 of 9416 Old 11-19-2014, 09:37 AM
257roberts's Avatar
Thumbs up
Just make a test wire and wire around the thermostat/high temp limiter. That way you can determine if the thermostat is the source of the problem. If you are not comfortable doing it yourself most any electronic tech could try it for you. I still like my Pro8100. I have around 3000 hours on the original bulb, but about 500 hours or so ago I had to bump the bulb settings off of "Eco" and set it to "Normal". The fan runs a little harder and make a little more noise, but the image quality is just as good. I will however, have some decision making to do if it needs a new bulb. My friend has a new Optoma entry-level 1080p machine and it sure looks nice for what he paid for it. What do you guess it will cost to get a top quality bulb, OEM or not, to replace in the Viewsonic? Thanks and hope your projector can be repaired and enjoyed!
257roberts is offline
post #9249 of 9416 Old 11-19-2014, 09:51 AM
sebberry's Avatar
Quoted: 28 Post(s)
Liked: 31
The first repair shop wanted to replace the PSU - part not available from VS.
The second shop didn't want to probe the PSU and test it at all.
The third shop pulled some diodes and transistors out of circuit but they all tested OK.
The fourth shop suspects one of the ICs and has a part on order I think and will let me know in a day or two if it can be fixed. If anyone can fix it, this guy can. He's an older Chinese fellow and his shop is stacked to the nines with electronics. I have to turn sideways to walk through the place.
Oh the effort I go to to ensure I have happy customers
sebberry is offline
post #9250 of 9416 Old 11-19-2014, 10:20 AM
257roberts's Avatar
I guess the high temperature cutout was working then. Good luck and hope you can repair the PSU. Like Dragonman said, I would not have thought that the PSU was proprietary to Viewsonic, but I guess so.
post #9251 of 9416 Old 11-22-2014, 08:47 AM
257roberts's Avatar
I am needing to replace my bulb. Any ideas other than the Viewsonic Lamp Module? I am pretty handy and could swap just the bulbs if I had to.
post #9252 of 9416 Old 11-22-2014, 09:04 AM
mgkdragn's Avatar
Liked: 2405
The MWAVE lamps have had mixed reviews here .. although my experience has been good ..
otherwise :
http://www.projectorlampsource.com/V...sYOxoC58_w_wcB
http://www.amazon.com/Viewsonic-Repl.../dp/B00A553PWK
http://www.newegg.com/Product/Produc...9SIA15412S5524
If, at my next lamp change, I don't have a good experience with an inexpensive lamp, I'll probably begin seriously considering moving on, I had the opportunity to check out an LG PF85U and an Optoma HD50, either of which I think I can place in my HT ..
Uncle Willie
mgkdragn is offline
post #9253 of 9416 Old 11-22-2014, 05:57 PM
mizedog's Avatar
hi guys
thanks
J
I made a shelf type out of beach plywood. It's been there go about 4 years. I'd like to build a new one but just for a different style.
mizedog is offline
post #9254 of 9416 Old 11-22-2014, 07:50 PM
257roberts's Avatar
Thanks Dragonman, I hope an inexpensive bulb will work, I doubt I would put in $350 in the Viewsonic. The LG machine looks nice with LED's and no bulbs, but wouldn't be bright enough for my room. I may try the mwave bulb.
post #9255 of 9416 Old 12-09-2014, 12:13 PM
Superman2's Avatar
Quoted: 16 Post(s)
Hello Folks!
Been awhile. Just stopped in to say I've ordered a lamp off amazon.ca (clt imports) and will report back my findings in the coming weeks. $155+shipping. Says it's original Phillips/osram bulb with generic housing.
Over 3500hrs on original bulb and it's gotten dimmer (used mostly on normal), so decided to go for it after holding off last year.
Hope this goes well!!!
old corps likes this.
Superman2 is offline
post #9256 of 9416 Old 12-09-2014, 01:01 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
Originally Posted by Superman2 View Post
Hello Folks!
Will be looking forward to your review, but I believe the actual original lamp is a Ushio. Good luck!
Ed
old corps is offline
post #9257 of 9416 Old 12-09-2014, 03:42 PM
Superman2's Avatar
Quoted: 16 Post(s)
Ed
Great, starting off well already!
post #9258 of 9416 Old 12-16-2014, 04:11 PM
sebberry's Avatar
Quoted: 28 Post(s)
Liked: 31
Update:
Two ICs replaced on the under-side of the board, but still no power. The technician says he's getting about 1.2v where there should be 5v standby power.
He says without the schematic diagram there's nothing more he can do Of course, the service manual doesn't have the PSU in it.
Viewsonic's help on this has been nonexistent. Last VS projector I buy or recommend for my clients.
sebberry is offline
post #9259 of 9416 Old 12-16-2014, 06:06 PM
73shark's Avatar
Quoted: 410 Post(s)
Liked: 208
Assuming the 5V PS is putting out 5V, he needs to find what's dragging it down. Suspect a bad capacitor somewhere.
In space, no one can hear you scream . . .
73shark is offline
post #9260 of 9416 Old 12-16-2014, 06:37 PM
sebberry's Avatar
Quoted: 28 Post(s)
Liked: 31
He's an older Chinese gentleman and I'm having a little difficulty understanding him sometimes. I can see the solder where he's pulled and tested various components out of the circuit.
The nice thing is that he didn't charge me for anything. I think he saw this as a personal challenge
One thing I just discovered is that the service manual that is floating around here lists one of the connectors in the PS as not used. (This is the page he was working from). Taking a look into the projector I see that the door switch (over the bulb) is wired into this connector and it needs a closed circuit. I tried on my projector and sure enough opening the bulb door took the PJ out of standby.
Maybe I'll take it back to him and tell him that connector needs to be shorted. (He did have the other thermostat connector shorted).
On another note, DigiKey shipped the two ICs we needed from Minnesota to the west coast of BC so quickly I had them in less than 24 hrs of ordering them.
sebberry is offline
post #9261 of 9416 Old 12-19-2014, 04:31 PM
Superman2's Avatar
Quoted: 16 Post(s)
Lamp update:
Received the new lamp this week. Quick shipping, but I felt the packaging was rather skimpy.... maybe thats just me. I couldn't tell any diff between the original and new one. I'll post some pics later.
Installed today. Pretty easy enough. The new lamp/housing had to be forced in a bit more than I felt comfortable. The two screws lined up well though, and no issues closing it up.
Fired her up and wow... bright as hell. I even left all my basement spot lights on and I immediately noticed the difference. Pretty sure this is just as bright as when I first got my bulb.
So far so good. I'll report back every few hundred hrs just to keep those looking for a new bulb in the know.
post #9262 of 9416 Old 12-21-2014, 06:16 PM
257roberts's Avatar
I replaced my bulb (not cage) also. I purchased mine from replacementlightbulbs.com It is a genuine Ushio branded bulb, like the original OEM bulb. This one however says NSH160D, the original said NSH160HO. Not sure what the difference is but this bulb is nice and bright, my old bulb said 1500 hours, but I bought a refurb and I'm not sure if the bulb was new when shipped to me. Anyway it looks like it did when I first received my projector. I will need to tweak the calibration some, seems like the skin tones might be a little too red. I may need to turn down the saturation some also. Thanks to all who gave advice on the lamps and bulbs. Unless something happens to the projector, I intend to keep it, I have not seen anything that will throw a nice image like the Pro8100 without spending a quite a lot of money. I see some brighter projectors and ones that have 3D, but none that have the color rendering and pleasing sharpness that the Viewsonic does.
post #9263 of 9416 Old 12-26-2014, 02:34 PM
Superman2's Avatar
Quoted: 16 Post(s)
Updating with pics: 25hrs on new lamp and all is well.
ID:	442954 original one
ID:	442962 new one
ID:	442970 packaging
post #9264 of 9416 Old 12-26-2014, 07:14 PM
73shark's Avatar
Quoted: 410 Post(s)
Liked: 208
About every 3-4 months I get the red flashing status LED which means Lamp Error. The lamp doesn't come on, so I shut it off and wait a few minutes and it comes on normally. Not sure what's happening but I guess as long as it comes on, I'm happy. Would like to know what causes it tho.
73shark is offline
post #9265 of 9416 Old 12-29-2014, 08:37 PM
--DANNY--'s Avatar
Quoted: 24 Post(s)
Liked: 31
While setting up my Xbox One I noticed it has settings for color depth of 24, 30, or 36 bits per pixel. I searched through the Pro8100's pdf manual and web searches turned up nothing... I'm assuming this projector only supports 24 bits per pixel color depth?
--DANNY-- is offline
post #9266 of 9416 Old 01-13-2015, 09:53 PM
--DANNY--'s Avatar
Quoted: 24 Post(s)
Liked: 31
I installed a bulb from mwave and it was super dim, RMA'd for a replacement.
I just installed the replacement and as soon as the image is displayed when turning the projector on it starts to brighten up but as soon as it reaches maybe 75% of normal brightness after about 10 seconds of being on it instantly cuts back to maybe 10% brightness/light output. I've tried resetting the projector, removing and reinstalling, etc. installed the 3500 hr old viewsonic bulb and it works just fine as it should (only replacing due to light output being slightly less than desirable and with 3500 hours it'll likely die any day now).
Any ideas before I return for a refund and purchase a bulb from replacementlightbulbs.com?
post #9267 of 9416 Old 01-13-2015, 10:01 PM
AgentHEX's Avatar
I have one of these projectors that's been neglected lately, but I can mirror the experience just above. The generic replacement bulbs are rather worthless, and a direct OEM bulb (in lesser housing is ok) is necessary to reach anywhere original spec. I've had to return the generics even though I wasn't expecting much for less than $100. The latter are probably the same Ushio though the descriptions sometimes say Philips or whatever. They're not cheap at closer to 200, but still less than Viewsonic or Mitsu brand.
AgentHEX is offline
post #9268 of 9416 Old 01-14-2015, 09:25 AM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
That was pretty much my experience with the mwave lamps. 1st one was much dimmer than an OEM with about 1k hours on it. The 2nd one was so dim I could hardly see the image on the screen. Good luck!
Ed
post #9269 of 9416 Old 01-14-2015, 09:32 AM
73shark's Avatar
Quoted: 410 Post(s)
Liked: 208
I guess Uncle Willie and I got the last two good Mwave bulbs.
73shark is offline
post #9270 of 9416 Old 01-14-2015, 12:19 PM
mgkdragn's Avatar
Liked: 2405
I've bought and used more than one that all worked out great and, in fact, measured slightly brighter that the Viewsonic original .. apparently, YMMV .. I've got 3000 hours on my latest, and it's still holding strong ... 11,000 hours now on the 8100 ...
Dark Rider also had good experience with the Mwave product ..
Uncle Willie
mgkdragn is offline
Viewsonic Pro8100 Full Hd 1080p Home Theater Projector , Viewsonic
