Can I use AE2000 in China with 240 Volts power? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-30-2007, 01:00 AM - Thread Starter
adaseng's Avatar
Hi Guys,
I was wondering if I take this projector with me to china or other european countries and use it with an adaptor? as you know the power there is different than ours 120 volts. also what if I take the blue ray player, will it also play? thanks
sean
adaseng is offline
post #2 of 3 Old 11-30-2007, 04:06 AM
Jones_Rush's Avatar
It says on the AE2000 manual that it can take 120-240 volts. It also says that the cable supplied with the AE2000 should only be used with 120V sockets, so if you are in a 240V country, the cord should be replaced.
Jones_Rush is offline
post #3 of 3 Old 11-30-2007, 08:47 AM
ferbal's Avatar
Originally Posted by Jones_Rush View Post
...so if you are in a 240V country, the cord should be replaced.
Or, like we do in the 220V countries, get a good (110 to 240) plug adapter
ferbal is offline
