RS2/ PRO-FPJ1 Owners: Setup Discussion Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #361 of 4321 Old 02-17-2008, 03:54 PM
lectricman's Avatar
Thanks Cameron, My room is 29' deep and 12' wide. The room is really about 20' wide but the width is limited by columns so it got split up unfortunetly
lectricman is offline
post #362 of 4321 Old 02-17-2008, 04:10 PM
Phil Olson's Avatar
I think with your 1.5 gain screen material and 10.5' width you should be fine assuming an anamorph lens. Without the lens, using zoom only, I think you'd be dissapointed as the lamp aged.
I'd suggest mounting it at the back of the room for max contrast as well as min lens anomalies.
Of course that's just me!
I have a .85 gain old GrayHawk microperf 12' wide and I will definitely have to upgrade to at least a 1.3 Studiotek soon since the lamp is 200+ hours.
I have mine at the back of the room and have approx. 21' throw with in ISCO2.
Phil Olson is offline
post #363 of 4321 Old 02-17-2008, 04:39 PM
Cameron's Avatar
OK I just went down to the basement to look at the projector. Rob is right. The knobs are on the bottom of the projector if you are table mounting. Chris had me confused there.
-- Well I have really blown my budget now. --
Cameron is offline
post #364 of 4321 Old 02-17-2008, 04:40 PM
Cameron's Avatar
OK not super wide. Are you going to put speakers on the side or are you planning on going with an Acoustically transparent material?
If not going for the AT, how wide are your speakers?
Cameron is offline
post #365 of 4321 Old 02-17-2008, 05:09 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1011
Phil. Why not just buy a new lamp(s) quicker? Those lamps are cheap and a LOT cheaper than a new screen. You will, however, as you know, get a significant increasein brightness by going from .8 to 1.3.
mark haflich is offline
post #366 of 4321 Old 02-17-2008, 05:14 PM - Thread Starter
CCLAY's Avatar
Sorry for the confusion, guys. I didn't catch that Rich was 'tabletop' mounting. This is about as close as I can get with my camera. My pj is obviously inverted. It hangs by it's feet. In a Panamorph situation, the lens almost has to be in the 'out' position for you to get to the knobs.
Chris
My Home Theater is a work in progress.
CCLAY is offline
post #367 of 4321 Old 02-17-2008, 05:24 PM - Thread Starter
CCLAY's Avatar
Phil, you're noticing a big drop in light at 200 hours?
CCLAY is offline
post #368 of 4321 Old 02-17-2008, 08:28 PM
R Harkness's Avatar
Quoted: 2024 Post(s)
Liked: 1719
Thanks a lot Chris. It was very helpful of you to take that photo on my behalf. I can see the knobs so it will help my design.
Cheers,
R Harkness is offline
post #369 of 4321 Old 02-17-2008, 08:52 PM
lectricman's Avatar
The speakers are Def Tech BP2000 and will be at each side of the screen. Putting them behind the screen won't work in my situation.
post #370 of 4321 Old 02-17-2008, 09:49 PM
Cameron's Avatar
Well crud a 12' wide .85 gain screen. Any light drop would be significant.
Cameron is offline
post #371 of 4321 Old 02-17-2008, 10:00 PM
Cameron's Avatar
OK I see that the speakers are 9" each and you probably want a few more inches on each side too. So that takes out 2' or so.
I would shoot for 9' to 9.5' wide with the Stewart 1.3 gain. (or carada 1.4)
I have a 1.35 gain equivalent 10' wide stewart screen with my RS2. It is plenty bright for my semi-batcave.
So are you going to use an Anamorphic lens with this setup?
Cameron is offline
post #372 of 4321 Old 02-18-2008, 03:25 AM
cortega's Avatar
Thanks Phil. Mounting it at the back of the room as per your suggestion would leave a similar set up as the one you seem to have, which is good news. With a screen which is even a bit larger than mine, is the lumens output enough in your setup? I see your concern about both the gain of the screen and the lamp life...
Since mounting it at the back would leave the projector close to where we would sit, should I be concerned about the projector noise above my head?
I'll be using a Schneider anamorphic lens (per my dealer's suggestion since he doesn't seem to carry ISCO), but for 16:9 content I plan to take the lens out. Without the lens do I have to use the zoom for 16:9? (apologies for the very basic question). In your experience, for 16:9 content do we need to plan for lamp replacements at around 200+hours not to be too disappointed? At this level of expenditure, the last thing I'd like is to feel disappointed with my image...
Thank you all for your help and comments!
cortega is offline
post #373 of 4321 Old 02-18-2008, 07:59 AM
Cameron's Avatar
If you have a sled for the lens (or any way to remove it), you won't need to zoom at all for 16:9. You will need switch VStretch to off.
Cameron is offline
post #374 of 4321 Old 02-18-2008, 09:27 AM
lectricman's Avatar
Thanks Cameron, Yes I'm definitely going Anamorphic. Any specific screen material from Stewart?
post #375 of 4321 Old 02-18-2008, 09:34 AM
Cameron's Avatar
I would go with the Studiotek 130 G3. It is pretty much the benchmark for screens.
Nice pretty uniform. Great screen.
I rank the Carada up there with it too at 1/4 the price.
Cameron is offline
post #376 of 4321 Old 02-18-2008, 09:47 AM
lectricman's Avatar
Cool, I'll post any more questions as they come up. Thanks for the advice.
post #377 of 4321 Old 02-18-2008, 09:51 AM
cortega's Avatar
Cameron, do you think there are size limitations for the Studiotek130 G3? I'm trying to get an electric one of 10.5' base with a 2.35 aspect ratio and the local dealer tells me that there is a size limitation for the Studiotek130 and can't do one of this size. Any idea?
cortega is offline
post #378 of 4321 Old 02-18-2008, 09:57 AM
lectricman's Avatar
Just came up with another quest. Givin my low 7'4" ceiling height, what height off the floor for the screen bottom do you recommend?
post #379 of 4321 Old 02-18-2008, 10:05 PM
Cameron's Avatar
How many rows of seats? I try to get a hold of the screen first. Then I place the seating and adjust to what feels best.
Cameron is offline
post #380 of 4321 Old 02-19-2008, 01:46 AM
Franky74's Avatar
Hello .
I should get my RS2 quite soon and I'd like to prepare a bit the installation. I have a 16/9 92'' wide screen (about 2.35m). My seats are at around 3.80 from the screen and the RS2 should be at 4m from the screen right above seats. The center of the screen is at 1.5m from the ground. My question is what would be the best height for the RS2 to be? (I planned it to be at 2.10m). I would understand noone would like to do the (correct) math for me but maybe you would have some links for accurate calculators .
Thanks in advance.
PS: a special hello to Alan Gouger, from the frenchie he sold a vpl-w400 to (a loooong time ago ). This one is still working athough not used anymore.
Franky74 is offline
post #381 of 4321 Old 02-19-2008, 06:48 AM
Alan Gouger's Avatar
Quoted: 38 Post(s)
Liked: 71
Bonjour
I remember that projector very well. It was one of the first 16x9 HD projectors.
For its day it had a very good picture and considered on the cutting edge.
Good hearing from you. Also nice to hear you still have the machine. That was a lonnnggg time ago
merci
Alan Gouger is offline
post #382 of 4321 Old 02-19-2008, 12:21 PM
bobbi15's Avatar
Hi all,
I recall reading that some projectors perform better in such areas as deflecting stray light away from the screen when they are ceiling mounted (turned upside down). Is that true with respect to the RS2 or is there no difference in performance if table-top/shelf mounted right-side up?
bobbi15 is offline
post #383 of 4321 Old 02-19-2008, 12:28 PM
Franky74's Avatar
I found the link for the nice calculator for jvc projectors (link also posted on some other threads here): http://www.jvcdig.com/ . It seems to answer most of my questions .
(the VPL-W400 had this special structure of the pixel matrix (honeycom like) so you had no line effects. I never understood why this idea hadn't been used anymore)
Franky74 is offline
post #384 of 4321 Old 02-19-2008, 12:59 PM
Wireless member
pepar's Avatar
Quoted: 1035 Post(s)
Liked: 540
Thanks, that is a handy link!
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #385 of 4321 Old 02-19-2008, 08:06 PM
Phil Olson's Avatar
I need to check in here more often!
Actually upgrading the lamp would be much less expensive but I've been wanting to move to a Studiotek ever since the RS's came out. It is the reference standard afterall!
My 12'x5' GrayHawk is still quite watchable but I have noticed a slight roll off in output. My concern is that after I order the Studiotek it could take 6-8 weeks to get so it's not about the output now but what it might drop to a couple of months from now or whenever I order it.
I'll probably pull the trigger in a month or so which could put me as much as 3 months out for the upgrade.
I think the closer to the center of the screen the better to reduce lens effects but from your seating area with normal viewing material you'd be very unlikely to notice any problems.
The reason I don't check in too often is that I'm too busy watching movies! I find myself looking for dark movies just to enjoy the amazing detail and it's not even tweaked to perfection yet. This is one great product!
post #386 of 4321 Old 02-19-2008, 10:28 PM
Cameron's Avatar
Wow that screen is going to cost a few bucks. At least it isn't a microperfed one!
I'm sure there will be a good bit of difference with the 1.3 gain screen.
So what projector did you originally get that grayhawk for?
Cameron is offline
post #387 of 4321 Old 02-20-2008, 10:05 AM - Thread Starter
CCLAY's Avatar
My favorite dark scene to watch so far has got to be in SW Attack of the Clones(HD) where Obi Wan is being chased thru the minefield. WOW, total eye candy!!
CCLAY is offline
post #388 of 4321 Old 02-20-2008, 10:38 AM
Quoted: 38 Post(s)
Liked: 71
Guys add a FL day filter and increase on/off & dynamic contrast even further. You will have to re calibrate but its worth it.
post #389 of 4321 Old 02-20-2008, 10:50 AM
millerwill's Avatar
Quoted: 472 Post(s)
Liked: 267
Alan, can you say more specifically what filter this is (for someone quite ignorant on the matter)? Would this filter also perhaps be helpful for a RS1?
PS I have an ND2 77mm Hoya filter that fits my RS1 just right. But I don't see a FL Day Hoya filter that is larger than 72 mm. Is there?
millerwill is offline
post #390 of 4321 Old 02-20-2008, 10:59 AM - Thread Starter
CCLAY's Avatar
Does that do anything to affect the image brightness?
CCLAY is offline
