RS2/ PRO-FPJ1 Owners: Setup Discussion Thread - Page 143 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #4261 of 4288 Old 02-06-2015, 08:31 AM
marchewd's Avatar
Is the bulb on Amazon better than the Osram P-VIP 200 bulb that was recommended earlier in the thread? Here is the bulb:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
It is just the bare bulb, so you have to fit it into an old casing, but that isn't too difficult.
marchewd is offline
post #4262 of 4288 Old 04-21-2015, 10:26 PM
Liked: 0
Do you still have the LCR 10 Gold grills? I need 3. I will buy them. Interested? Sorry I'm not on topic but couldn't find any other way to contact you.
Roger 505.450.7888
Albuquerque, NM
rcrosley51 is offline
post #4263 of 4288 Old 05-13-2015, 11:05 AM
bsuave's Avatar
Quoted: 125 Post(s)
Question,
Do you have to have an Anamorphic Lens to get this projector(JVC RS2) to display on a 120" screen less than 18 feet??? BTW i a noob! lol I have this projector connected to my ps3 for testing distance and played a blu-ray and netflix. biggest i could get the screen to go was for a 100" screen at 18'. I saw no zoom feature. Am i correct that this projector will only hit 120" beyond 18 feet?? The calculators all show this to be possible before 18'.
bsuave is offline
post #4264 of 4288 Old 05-13-2015, 11:40 AM
tilallr1's Avatar
So what is everyone else doing in terms of replacement lamps these days. Don't feel like paying $400 for a new lamp, but would love a good deal on a JVC OEM lamp.
TIL ALL ARE ONE
tilallr1 is offline
post #4265 of 4288 Old 05-13-2015, 11:51 AM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 3229 Post(s)
Liked: 1919
Originally Posted by bsuave View Post
Question,
You do not say if you are talking 120" diagonal or width, nor what aspect ratio. For a 120" wide image the throw range is 13'-6" to 27'-9". See page 20 of the owners manual: http://www.projectorcentral.com/pdf/...anual_3894.pdf
You have to hit the test pattern button. It is labeled as test on the remote.
bsuave likes this.
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Triad, Atlantic Tech, M&K, RBH, SVS, Polk, Stewart, Seymour, Falcon, DNP, SI, Screen Excellence, Carada & more.
Mike Garrett is online now
post #4266 of 4288 Old 05-13-2015, 11:56 AM
bsuave's Avatar
Quoted: 125 Post(s)
Thumbs up
My apologies, i meant 120" diagonal. You know, i sat in my soon to be HT and thumbed through that whole book and looked right over this. THANK YOU SOOOOO MUCH!!! I shall try when i get home.
bsuave is offline
post #4267 of 4288 Old 05-13-2015, 12:22 PM
AVS Club Gold
Liked: 1919
For 120" diagonal 16:9, the range is 11'-8" to 24'-2".
bsuave likes this.
mike@avscience.com
post #4268 of 4288 Old 05-13-2015, 04:47 PM
bsuave's Avatar
Quoted: 125 Post(s)
bsuave is offline
post #4269 of 4288 Old 05-13-2015, 07:51 PM
bsuave's Avatar
Quoted: 125 Post(s)
You guys rock. This is at 12' 3". Awesome
bsuave is offline
post #4270 of 4288 Old 05-13-2015, 08:06 PM
AVS Club Gold
Liked: 1919
You are welcome.
bsuave likes this.
mike@avscience.com
post #4271 of 4288 Old 05-13-2015, 08:08 PM
bsuave's Avatar
Quoted: 125 Post(s)
Now what's the best mount for the RS2. Need to order it. Me and the wife are painting the room hopefully this weekend.
bsuave is offline
post #4272 of 4288 Old 05-13-2015, 08:24 PM
AVS Club Gold
Liked: 1919
RPMA184 would be the best mount. RPA184 would be second choice and RPAU would be third choice. Need to know distance from ceiling to top of image and ceiling height. Also need to know if you have a riser under your seats. Call to discuss and for pricing.
bsuave likes this.
mike@avscience.com
post #4273 of 4288 Old 05-18-2015, 07:56 PM
bsuave's Avatar
Quoted: 125 Post(s)
Big Thanks to Mike at AV Science for helping me with my purchase with my mount!
Thank you for taking my call so late and helping me purchase the correct mount for my RS2. Bonus for me is that i got to talk and get information needed to keep me moving in the right direction for my HT.
bsuave is offline
post #4274 of 4288 Old 05-18-2015, 08:37 PM
AVS Club Gold
Liked: 1919
You are welcome.
bsuave likes this.
mike@avscience.com
post #4275 of 4288 Old 06-28-2015, 09:06 PM
patricksull's Avatar
Originally Posted by dreamer View Post
Will this lamp work for the DLA-RS2?
patricksull is offline
post #4276 of 4288 Old 06-28-2015, 09:40 PM
dreamer's Avatar
Quoted: 754 Post(s)
Liked: 197
Yes. Both the RS1 and RS2 use the same lamp.
patricksull likes this.
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
post #4277 of 4288 Old 06-28-2015, 10:00 PM
Any specific instructions for a first timer?
Cheers,
Patrick
post #4278 of 4288 Old 07-01-2015, 11:59 AM
bsuave's Avatar
Quoted: 125 Post(s)
@dreamer , have you used this bulb before??
bsuave is offline
post #4279 of 4288 Old 07-01-2015, 12:00 PM
bsuave's Avatar
Quoted: 125 Post(s)
Cheers,
Patrick
x2??
bsuave is offline
post #4280 of 4288 Old 07-01-2015, 01:37 PM
Does the bulb just come right out or is there a certain way to get it out of the casing?
post #4281 of 4288 Old 07-01-2015, 09:38 PM
dreamer's Avatar
Quoted: 754 Post(s)
Liked: 197
Yes.
Kirk Ellis
dreamer is offline
post #4282 of 4288 Old 07-01-2015, 10:03 PM
dreamer's Avatar
Quoted: 754 Post(s)
Liked: 197
There are four small philips head screws holding the module together. Then there are metal spring clips holding the lamp against the open end of the housing. The spring clips are loose and one of the more frustrating aspects is getting them to stay in place while reassembling the module so they hold the corners of the lamp in place.
Search youtube and you can find a video for relamping this module.
bsuave likes this.
Kirk Ellis
dreamer is offline
post #4283 of 4288 Old 07-01-2015, 10:13 PM
Very helpful indeed. Thank you. I'll order up the amazon one and give it a go. Thanks again!
post #4284 of 4288 Old 08-12-2015, 02:28 PM
tilallr1's Avatar
So it seems that the BHL5009 was replaced with the BHL5012 which prevents out-gassing and film buildup on the prism. Anyone find this lamp for a good price? I can only find it on the AVS store, can't even see this lamp for sale at JVC which is weird.
TIL ALL ARE ONE
tilallr1 is offline
post #4285 of 4288 Old 09-07-2015, 04:30 PM
"The screen will go blue for a second"
I have read this in a few places, and am having the same issue. However, mine does not happen when I switch inputs, it happens during playback. It happens on both the xbox and htpc. I replaced the processor, and that did not fix it. I run a very long HDMI cable, but it's the same cable that I have had for 5 years. This started about 6 months ago. Is this something that anyone has seen? I could replace the cable, but it will be a monumental task, as it is all hidden within the soffit. My next step was to buy one and just have it laying on the floor to test. The funny thing is how random this is. I can go weeks without any blue screen, then it will happen constantly. I can have it happen while watching one movie, but if I come back an hour later, that same movie plays just fine without any blue screen. I guess I could try replacing the bulb, although I'm only at 1700 hours. Any suggestions would be appreciated.
Cheers
Patrick
post #4286 of 4288 Old 10-21-2015, 10:12 PM
mnr929rr's Avatar
Cheers
Patrick
Replace the cable it will be fine.
mnr929rr is offline
post #4287 of 4288 Old 10-28-2015, 01:56 PM
Thank you
That did it. How did I not think of that? Regardless, thank you. Now, I just need to figure out how to do that. It's hidden in my soffit! Poor planning years ago.....
Cheers!
post #4288 of 4288 Old 10-28-2015, 03:22 PM
AVS Club Gold
Liked: 1919
Cheers!
I assume that it is not stapled in place? Then attach the two together, using the old cable to pull in the new cable.
mike@avscience.com
